Author Topic: CB 750 Project 1 - Rides Well but a few tweaks needed  (Read 140173 times)
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
Re: CB 750 Project 1 - Getting engine ready for assembly
« Reply #300 on: August 20, 2015, 06:18:45 AM »
timbo750,
How about a picture of the finished product????:)
The lacing and truing is the EASY part.  :)
I know once I figured out the secret, it only took 20 minutes to do the lacing.
If you need the secret, just let me know.
Charlie
Offline timbo750
« Reply #301 on: August 20, 2015, 02:37:18 PM »
timbo750,
Charlie
I will get a picture up tonight hopefully. I have read heaps on the lacing but anymore help is always appreciated.
Sent from my GT-I9505 using Tapatalk
Offline oldhatt45
« Reply #302 on: August 20, 2015, 03:11:23 PM »
timbo750,
OK, here is the secret.  Look at the Picture attached.  (Click on it to make it bigger and Print it out.  :)  )
Doesn't matter if it's a front or rear as long as it's a 40 spoke wheel.
Valve stem at the bottom.
Spoke to the Right of the Valve Stem goes to the BOTTOM of the Hub and is what everyone calls an "INNER".  Green Outline Arrow points to it.
Blue Outlined White Arrow points to the Spoke hole in the TOP of the Hub, just to the left of the Bottom spoke with the Green Arrow.
Purple lines show the approximate space.
Starting with the Spoke hole with the Blue Outlined arrow as HOLE NUMBER 1, count to the LEFT to the Spoke hole pointed to by the RED Arrow.  It's number 5.  That is where the SPOKE to the LEFT of the VALVE STEM goes on the TOP of the Hub (also an "INNER").
So, Start your Lacing with Bottom of the hub, using the spoke hole to the right of the valve stem. When done with the Bottom then locate the TOP spoke hole per what I just said and you are done correctly.  Every post on lacing shows a good procedure but doesn't give you what I show in the picture.  If you don't understand, just ask.
Hope this helps.
Charlie
Hope this makes sense.
« Last Edit: August 20, 2015, 03:14:55 PM by oldhatt45 »
Offline timbo750
« Reply #303 on: August 22, 2015, 11:23:15 PM »
Got all the spokes installed,  starts out awkward as they flop around everywhere buts gets easier as they stay in place.
Started truing the rim now and luck is on my side as its within 0.5mm. However I dont think it's torqued enough yet.
Can anyone tell me how to know if the torque is enough without a spoke torque wrench.
Offline timbo750
« Reply #304 on: August 23, 2015, 01:13:36 AM »
Ok, found some info that said to tap all the spokes and make sure they all have the same high pitched 'ting' when tapped with a long screwdriver. So I tried it and made some more adjustments and I think I got it right.
All the spokes seem tight and is true within 0.4mm.
« Reply #305 on: August 23, 2015, 05:41:37 PM »
Well done Timbo, how close are you to finishing your build? Cheers, Terry. ;D
Offline timbo750
« Reply #306 on: August 23, 2015, 10:50:48 PM »
Terry, unfortunately not much closer than a couple of months ago. The cold weather has dwindled the motivation and having to redo this wheel took mund away from the engine.
But now that the weather is warming up I am hoping to getthings moving again.
« Reply #307 on: August 24, 2015, 12:53:20 AM »
No worries mate, you'll have it done by the time the weather's nice enough to ride it. ;D
Offline timbo750
« Reply #308 on: August 24, 2015, 11:35:30 PM »
Here are some photos of the finished rim and some close ups of the clear powder coated hub.
« Reply #309 on: August 25, 2015, 06:13:34 AM »
Purty.
Offline timbo750
« Reply #310 on: August 25, 2015, 04:41:51 PM »
The clear powder coat actually improved the polished look, it gives it some depth. The stainless spokes are also a great finish.
« Reply #311 on: September 14, 2015, 01:39:22 AM »
If the rest of your bike looks as good as that Tim, it'll be a show stopper! ;D
Offline timbo750
« Reply #312 on: September 19, 2015, 06:58:29 PM »
After looking at the front wheel, I now think that the rear needs doing. But I will wait till its on the road and do it over a winter.
For the moment though no progress till we get back from 2 weeks camping. Then I will focus on getting the engine assembled.
Offline timbo750
« Reply #313 on: October 23, 2015, 08:51:20 PM »
Finally got back in the shed. I got the wheel back on and started reassembling the brakes when somehow I stuffed the PC on one of the calipers. So I stripped it back and I am trying to refinish with caliper paint, should be close enough to a match.
Also started on getting the engine cases ready for assembly, the JB weld I was using to patch around a broken thread just wouldn't go hard. It set a stuck well but was like firm rubber and I can guarantee that there was a minimum of 50% hardner. So I found another product that is far better called Sun Fix. It's 2 parts that are like plasticine, cut of equal parts a mix in your hand. You get 20min to work it and goes hard in approx 3 hrs, it can be drilled, machined and tapped.
I  am also making the most of the fact that the wife and kids are out for a few hours and I am cleaning the cases in the dishwasher.
« Reply #314 on: October 24, 2015, 12:25:55 AM »
Well done mate, I haven't had a problem with JB Weld before, so maybe you got a bad batch? I used to use Devcon, which was horribly expensive, but space shuttle quality, I knew a guy in Brisbane who put a rod thru the block of a V8 Torana and just patched the hole with Devcon, and it was still running when I again made contact with him a few years later.
The Sun Fix sounds a bit like the radiator and fuel tank repair stuff I used many years ago on a hole in my XA Fairmont's fuel tank, it leaked all the way to Dubbo, I patched it with this stuff hoping it'd make it to Brisbane, and it was still blocking the hole when I replaced the tank 2 years later. Good stuff.
Let us know how well the dishwasher cleaned your cases, there was a journo for a British bike mag who swore by it. Cheers, Terry. ;D
Offline timbo750
« Reply #315 on: October 24, 2015, 04:51:59 PM »
Dish washer worked a treat.the only thing is I have powdery residue on the cases, I think its from the old paint as it wipes off real easy.
Discovered something else i forgot to fix. The small rubber plug on the oil gallery thats missing and unobtanium.
So here is the plan. The hole is not round so I plan to do some minor tweaking to get it close to round with a dremel. The drill the appropriate size for an 8mm thread and then plug it with a grub screw. I also thought about plugging it with the sun fix but couldn't think of a way to ensure the galleries didn't get blocked.
Offline Davez134
« Reply #316 on: October 24, 2015, 05:19:24 PM »
I had a powdery residue on mine after dishwasher as well. Best I could figure it was residue from detergent or minerals from the water. Either way, a final acetone wipe easily got rid of it.
« Reply #317 on: October 24, 2015, 05:52:03 PM »
(Tongue and cheek, of course)
I think that's "Tongue in Cheek" Cal............. ;D
« Reply #318 on: October 24, 2015, 05:56:16 PM »
Geez, I didn't know they were unobtainable Tim, I had a bag of them that I bought on eBay a few years ago, I gave the last one to Cliff to rebuild his K2 only a month ago. In the past I turned up a plug from aluminium and used a bit of sealant around it, and it was fine, but I'm sure a threaded plug would be good too. Cheers, Terry. ;D
Offline timbo750
« Reply #319 on: October 24, 2015, 06:58:41 PM »
Terry, it's only what I read and they are  not listed on Yamiya. The odd thing is that the hole is not round and has a flat side. I am certain that my other case has a round hole.
Offline timbo750
« Reply #320 on: October 24, 2015, 08:20:19 PM »
Got the plug sorted. Didn't need a tap once the flat spot was removed but there is not much thread biting into the case so I guess the sealant will do most of the work.
The cases came out clean after the dishwasher treatment with only a few spot missed, must be the jet angle and the position of the case in the tray. But it has highlighted how the tophalf of the case needs the old paint removed. Most of it is actually gone but whats left will cause any new paint to peel off eventually. I have a small blaster so I am going to try some soda with it and see how it comes out. Plan is start engine assembly in 2 weeks.
« Last Edit: October 24, 2015, 08:22:01 PM by timbo750 »
« Reply #321 on: October 24, 2015, 09:51:38 PM »
Go to Bunnings and buy a pint of their paint stripper Tim, it'll rip the paint off and leave the cases shiny and clean.
 I first used it on my F2 cases that had been painted several times, (badly) had been in a fire, and had been painted again in the frame. The Bunnings stripper ripped the paint off. Cheers, Terry. ;D
Offline timbo750
« Reply #322 on: October 24, 2015, 09:56:39 PM »
I have got some Diggers brand in the shed, I will use that.
Offline edwardmorris
  • Youngish
« Reply #323 on: October 25, 2015, 11:00:25 AM »
Yea, those oil galley plugs are unobtanium. I lucked out and located two at a dealership. I've asked Elan to look into building reproductions but its seems like its too costly to do.
Offline timbo750
« Reply #324 on: October 27, 2015, 12:44:20 AM »
Well I don't know what the coating is on the engine but the paint stripper is not touching it. It will come of with a wire wheel on the dremel but that is going drive me nuts. I will try brushing the paint stripper with a small wire brush and see what happens.
