Author Topic: Palepainter's 750f project.. Al Fine'  (Read 68771 times)
Re: My first CB 750f project has started
« Reply #225 on: January 18, 2017, 05:37:17 PM »
This is my winter racers.   Vintage ovals.  51 one had not been taken on the circuit, so I ran it.   :)
I didn't know JD made snowmobiles.
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #226 on: January 18, 2017, 06:04:30 PM »
Oh ya.  They were quite popular in the 70s.  A variety of models with different performance levels.  They excelled in the cross country events.  Mine was extensively modified for flat ice track.
« Reply #227 on: January 19, 2017, 12:42:39 PM »
We had one here..for hillclimb....
Blown Kawi dragbike motor, hilborn injection..  Crazy. Kid that built it...
It is called X Rated or Rated X...its on Youtube
Gotta be a huge rush topping  a hillclimb at 90 or 100mph, and getting 50 feet of air...
Offline palepainter
« Reply #228 on: January 21, 2017, 11:15:12 AM »
Today I assembled the front fork tubes with all new goodies.
Offline palepainter
« Reply #229 on: January 21, 2017, 01:38:39 PM »
Installed the All Balls racing bearing conversion.  Cleaned all necessary contact areas for ground.   Polished all hardware.  Replaced what needed to be.  Threw the trees together.
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #230 on: January 21, 2017, 03:08:41 PM »
Looking good.  I drilled a hole in the bottom of my headlight housing and ran a small bolt through it to use as a grounding lug for all the forward circuits and then ran a wire to the frame under the tank.
Bud
1973 CB750K3 Chopper (in pieces)
Offline palepainter
« Reply #231 on: January 21, 2017, 04:37:38 PM »
Great idea Bud.     I threw a few more items on.
Offline budman
  • 1914X
« Reply #232 on: January 21, 2017, 05:01:43 PM »
Thickness planer.  Thickness sander.  Dust collector.  Looks like my shop.
Bud
Offline palepainter
« Reply #233 on: January 21, 2017, 05:19:13 PM »
You know...You can never have enough tools.  :)
Offline budman
  • 1914X
« Reply #234 on: January 21, 2017, 05:57:48 PM »
Not many people own a thickness sander.
Bud
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #235 on: January 21, 2017, 06:55:25 PM »
      Nice!!!!!  8) You have got some Serious Skills there.
Member # 1969
Offline palepainter
« Reply #236 on: January 22, 2017, 07:43:16 AM »
Thank you Bill.  Always learning.
Offline palepainter
« Reply #237 on: January 23, 2017, 06:37:06 PM »
Moving forward until I am finished with motor.
« Last Edit: January 23, 2017, 06:53:47 PM by palepainter »
Offline palepainter
« Reply #238 on: January 23, 2017, 06:52:37 PM »
Nah...Most of this stuff is going to come off.  Sheetmetal, front end, side covers will be coming off when putting motor in.  I am about as far as I am going to go until motor is ready.  I want to lay motor on it's side and drop frame over.  The tubes are just in the trees just to balance out the weight.  Not in permanently.  I will do the wiring after motor is in.
Edit.  But if the blasting media and VHT stuff doesn't show up soon...I will be wiring.   :)
« Last Edit: January 23, 2017, 07:44:37 PM by palepainter »
Offline palepainter
« Reply #239 on: January 26, 2017, 04:31:11 PM »
Holy moly.    50 lbs of soda bicarbonate to blast down the motor.  I looked like Al Pacino in Scarface when I was done.   No photos.  Too incriminating.
« Reply #240 on: January 26, 2017, 04:34:38 PM »
Funny!
« Reply #241 on: January 26, 2017, 06:48:33 PM »
Offline palepainter
« Reply #242 on: January 26, 2017, 07:03:50 PM »
Yes....Exactly.  :)
Offline palepainter
« Reply #243 on: January 28, 2017, 11:09:25 AM »
Watching wrinkle paint dry.     I also finished up side covers and stainless mesh inserts.
« Last Edit: January 28, 2017, 11:48:27 AM by palepainter »
Offline palepainter
« Reply #244 on: January 28, 2017, 04:03:35 PM »
 Took the rocker box.  Blasted then painted it.  I will file down the embossing after it is all cured nicely.  This wrinkly stuff will take several days.
Offline Godffery
  • Godffery's Garage
« Reply #245 on: January 28, 2017, 06:06:38 PM »
That motor is look'n Real Good!
« Reply #246 on: January 28, 2017, 06:34:07 PM »
Are you blocksanding the fins ?
Offline palepainter
« Reply #247 on: January 28, 2017, 06:49:13 PM »
I will when the paint is cured.  I scraped off the excess with a blade to make the job a bit easier when the time comes.  I will also block sand the ribs and SOHC 750 markings on valve cover.
Offline riverfever
« Reply #248 on: January 28, 2017, 07:04:06 PM »
The side covers turned out great!
Pale is the seat just fastened to the frame rails? Did you just drill and tap the frame? Also...how will you secure the upholstery and padding to the base?
Offline palepainter
« Reply #249 on: January 28, 2017, 07:12:17 PM »
Yes Sir,  The tail section is bolted to the frame.  I welded two flanged nuts to the top of frame just behind the rear of tank.  That is how the front of tail mounts.  The rear bolts pass through the rear cross member of the frame where the existing mounts for batter and tool box mount toward rear of bike.  I am debating on a couple different approaches on the seat.  I am considering making a fiberglass pan that will lock into place over the bolts that hold the tail section into place. I have also considered simply using Velcro to secure seat to tail section.  That will be about the last thing I get into, I believe.   I am certainly open to ideas though.  :)
