Author Topic: Hello from Washington  (Read 2922 times)
Offline Doublejack
« on: January 08, 2017, 09:47:04 PM »
Just picked up an old 72 CB500 chopper today.
Figure I'll be doing quite a bit of research as I don't know much at all about this thing.
Seems like a good place to start!
Offline jcooper
Re: Hello from Washington
« Reply #1 on: January 09, 2017, 06:38:00 AM »
Hello! And welcome!
Sounds like a good project....are you going to keep the raked front end or go more standard?
« Reply #2 on: January 09, 2017, 06:49:28 AM »
Welcome!
Offline Doublejack
« Reply #3 on: January 09, 2017, 11:01:59 AM »
Hello! And welcome!
Its a full blown 70s custom chopper. Molded frame w/ girder front end so it's definately staying a chopper!
Although I must admit these older CBs look pretty neat all restored.
« Reply #4 on: January 09, 2017, 02:44:36 PM »
Hey Doublejack...where you from?
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: January 09, 2017, 02:53:44 PM »
Welcome, and you are correct in that this is one of the best resources...Larry
Offline Doublejack
« Reply #6 on: January 09, 2017, 05:47:59 PM »
Maple Valley WA
Offline Doublejack
« Reply #7 on: January 09, 2017, 05:51:27 PM »
Test
Offline MoMo
« Reply #8 on: January 09, 2017, 07:33:51 PM »
You are right, that is about as 70's as it gets, and it looks nicely finishe ;)...Larry
« Reply #9 on: January 09, 2017, 09:54:10 PM »
Welcome to the forums.
David
« Reply #10 on: January 11, 2017, 08:43:53 AM »
Maple Valley WA
Nice.  I'm up just east of Everett.
A few members scattered all around the sound.
Jump on over here....
http://forums.sohc4.net/index.php/topic,158360.0.html
« Reply #11 on: January 11, 2017, 11:27:54 AM »
Welcome aboard.. I like choppers ,but I would be adding a front brake..
 Looks good..
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #12 on: January 16, 2017, 07:25:37 AM »
That is a sick looking chopper! Very cool. Welcome to the forum.
--Evan
1975 CB750K "Rhonda"
« Reply #13 on: January 16, 2017, 08:06:07 PM »
Frank,  how would you go about a brake to this front end design?  If you thought the stock brakes sucked therefor this bike with only rear brakes would far exceed that pitiful amount. Can you say accident waiting to happen?
It is definitely a child of the 70s. Cool example worth cleaning up and maintaining its patina and aged look.
David
« Reply #14 on: January 16, 2017, 09:29:26 PM »
You have to build bracket that fit either side of the girder legs, then spacers in the middle and bolt it together.  Some came with small bracket or bushing welded to girder legs.
Offline Doublejack
« Reply #15 on: January 17, 2017, 12:23:23 AM »
Yea front brake is going to happen.
Too many deer and wet roads where I live.
I'll probably throw a drum on it until I figure out a good disk setup.
Offline JB360Tbobber- 750chopper
« Reply #16 on: January 17, 2017, 07:26:52 AM »
my chopper
Offline Doublejack
« Reply #17 on: January 17, 2017, 10:12:30 PM »
my chopper
That's badass.  My wife wants a big king/queen seat like that.
By chance do you know much about those period frames?  Who was the main manufacturer for these rigid CB choppers at that time?
I've got literally zero numbers on this frame and I wouldnt even know where to look.   This bike is registered as a stock 72 CB500.   Kinda nervous about it.
« Reply #18 on: January 17, 2017, 10:20:32 PM »
Both your and his are hardtail sections added to stock frames.
So your frame should have numbers.. Could have paint or bondo over them.
In WA state, is the reggie number off the motor...or off the frame ?
« Reply #19 on: January 18, 2017, 09:22:21 AM »
In WA, they issue the title to the frame VIN, which for our CB's is stamped on the right side of the neck.
« Reply #20 on: January 18, 2017, 11:42:32 AM »
i have the neck stamped just have to get to the dmv.. by chance does any know anyone that has 360t parts?
I need some
« Reply #21 on: January 18, 2017, 02:05:50 PM »
Post a wanted list in the Wanted section for your 360T parts, some may be able to help you...
Offline MoMo
« Reply #22 on: January 18, 2017, 05:17:34 PM »
[/quote
hondatwins is also an option
Offline Old Scrambler
« Reply #23 on: January 23, 2017, 08:29:17 AM »
Nice Find ;) You may want to take a look at a mechanical disk brake sourced from a CB200T...................but any small drum unit is better than none ;)  Since the 21" spool will go........consider an 18 or 19-inch wheel to help with slow-speed handling and to somewhat level the motor.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #24 on: January 23, 2017, 04:29:44 PM »
The cb125 manual disc brake was a nightmare, did they fix its ussues so the cb200 did not have those issues?
