Author Topic: The Lost Socket Garage  (Read 105225 times)
Offline Scott S
Re: The Lost Socket Garage
« Reply #250 on: September 02, 2018, 06:04:28 PM »
Same with the rear fender and chain guard. New Shinko tires. YSS shocks. I'll touch up the frame soon, too.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #251 on: September 02, 2018, 06:18:13 PM »
I love following your posts. I wasnt on the forum for years but am very glad when i came back i saw you still here. I went back a re-read the whole STF thread the other night. Great stuff and you have only upped you game since!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Fezzler
« Reply #252 on: September 02, 2018, 06:58:00 PM »
Great write-ups!  A true inspiration to keep learning and having fun restoring and building bikes of all sizes.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
« Reply #253 on: September 02, 2018, 10:45:18 PM »
Congrats on getting the print on the two bikes...
Very cool.  David
Offline flatlander
« Reply #254 on: September 03, 2018, 05:04:17 AM »
yes, really cool articles. congratulations!
Offline Scott S
« Reply #255 on: September 03, 2018, 07:07:02 AM »
Tried to fit the Winning/Kerker exhaust onto the SR500 tonight and the collar won't pull up tight on the head. Or, rather, it will pull up and bottom out before securing the header.
 It looks like there was a split collar or ring there, maybe? Similar to Honda exhausts? You can see a bit of discoloration there, and it's about the same size as the ring on the stock header.
 What am I missing? Is there a collar or ring available to make this fit?
 Made my own. I had this piece of muffler piping in the garage from a leftover project. It fit perfectly.
 I made two collars 19mm wide, same as the ring on the stock header.
 Tightened up perfectly! Since I only have two hands, I had to use a little grease on the gasket and collars, and a rubber band that I later cut off.
 I'm really happy with the look and fit. I hope it sounds and performs just as well!
 I also replaced the hose clamp at the muffler/header junction with a T-bolt clamp.
'71 CB500 K0
'81 Yamaha XS650
« Reply #256 on: September 03, 2018, 09:21:54 AM »
The '73 CB500/550 was featured with a six page spread in this months VJMC magazine, too!
Congrats on the feature. Oh my - now I remember that roached tank!! She's all pretty now.
Offline Scott S
« Reply #257 on: November 15, 2018, 09:04:21 AM »
As often happens with projects, the work it takes to get it done doesn't look like much. But now the tank clears the carbs, the lines of the tank and seat are nice, the seat latch works, and the petcock (mostly) clears the air filter.
 I ended up using BST-36 carbs, Bandit 1200 manifolds, RamAir filters and Bandit 1200 rubber velocity stacks. The OldSkoolSuzuki guys swear that the RamAir filters/velocity stack combo makes for MUCH easier tuning. The RA filter squishes just enough to clear the petcock and leaves more than an inch behind the stack on the #1 throat.
 I also re-did the top triple. I put the bar risers in a different spot and used a Bandit 400 dash. It's nearly invisible in the pic, but that black area between the gauges and the triple are idiot lights. The 4oo gauges use a cable drive speedo and the plug is (supposedly) nearly identical to the Katana plug and is supposed to be easy to swap around a wire or two to make it plug and play.
 They also have nice cups to hide the rear of the gauges, and it keeps it all in the Suzuki family.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #258 on: November 15, 2018, 09:13:59 AM »
 I've been pretty side tracked on projects lately. Been thinking about moving in a year or so and spent several weeks doing a "purge" around the house and garage. MASSIVE amounts of stuff to the dump and to Goodwill.
 Anyway, I've decided to work on the 1980 GS550 donor/spare parts bike this Winter. That way, I can maybe move it out next Spring and have one less thing in the garage. And one less project to worry about.
 Got the stock GS550 engine on the stand. It doesn't need a rebuild, but it was a leaker, so I'll re-seal it this Winter with fresh gaskets and such. The carbs are currently getting rebuilt with new diaphragms.
 The frame is a 1980 GS550E frame but, unbeknownst to me, that was the year that Suzuki stopped differentiating between the E and L bikes on the VIN number. I ended up with an L frame and an E donor.
 We cut the upper tank mounts off and I have a plan to get the tank rubber mounted through those lower holes, where it needs to be for an E tank.
 I have a frame loop with a slight kick up that I will have welded on once the tank mounts are sorted. I will run a bobbed rear fender and a small tail light.
 Zip Dawg approves.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #259 on: November 15, 2018, 09:17:17 AM »
 This bike is my inspiration for the spare parts bike. I will be able to run the stock carbs, exhaust and even the plenum, so that should really simplify tuning.
 I'd say I have about 90% of the parts needed to finish this one.
'71 CB500 K0
'81 Yamaha XS650
« Reply #260 on: November 15, 2018, 11:53:45 AM »
A friend of mine has a GS550.  It seems to pull harder than a CB550.  Better brakes, too.
« Reply #261 on: November 15, 2018, 12:19:05 PM »
DOHC/4valve v SOHC/2valve. All else equal, the DOHC should win everytime.
Offline slikwilli420
  • Master of Disaster
« Reply #262 on: November 15, 2018, 01:20:01 PM »
The GS550 was a 2-valver, but did have a 6-speed trans, which is a nice add-on for a middleweight bike like that. It was the next evolution of tech vs the single stick CB550, so should still win every time.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #263 on: March 17, 2019, 12:55:37 PM »
Scott, how's the bikes coming along?
Offline Scott S
« Reply #264 on: March 18, 2019, 06:38:40 PM »
 Slow.
 Work, life, rain, winter, more rain.
 The SR500 is being a real #$%* about giving me spark.
 The Brat style GS550 got some welding done. I'll post pics soon.
 I hope to clean up the GS550 engine and reseal it soon. Try to get it back in the frame and maybe move it along.
 I have two SOHC4's in the lineup and would rather be working on them.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #265 on: March 27, 2019, 03:20:13 PM »
 Well, this Winter was brutal for me, in SOOO many ways. Work life, personal life, it rained 9 million inches, I got distracted with home improvements, etc, etc, etc. And all of the projects sat. And sat. And I lost interest and motivation.
 The SR500 is back in my garage and STILL doesn't have spark. The shop kept it for 6 months and I'm no closer than when I dropped it off. At least he didn't charge me anything.
 When I got it home, I noticed that the pulse coil was re-wound incorrectly.
 Here's what it's supposed to look like:
 That gap is critical. I had an in depth talk with Rick's and I sent it back for the THIRD rewind. If it's not right this time, I'm asking for a refund of some sorts and sending it to England for Rex's to take a shot at it.
 I did manage to get the purple CT70/140 running much better. A smaller carb helped with easier starting and it's still just as fast as it was before.
 Yesterday, I swapped out the throttle and clutch cable on the silver Glutton bike. I also worked on the rear brake rod for the 400F controls.
 So, those are two or three small victories.
« Last Edit: March 27, 2019, 03:31:48 PM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #266 on: March 27, 2019, 03:22:47 PM »
 While everything sat and I got distracted, I really lost interest in the GS550 projects. Pretty much nothing has happened on the Katana swap bike. On the Brat Style GS550, I did manage to get the tank sorted, seat hoop welded on and swapped out the front master cylinder to cure a dragging front brake.
 Anybody want a couple of Suzuki projects? I'll hook you up!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #267 on: March 27, 2019, 03:30:39 PM »
 Even as I started on the Suzuki's (and the SR500), I knew I had an other Sweep The Floor CB500/550 in the pipeline.
 I thought I'd knock out the Suzuki's and then get on the CB since the CB was LITERALLY a basket case; the carcass of the Glutton for Punishment bike.
 But all along, I was really wishing I was building the SOHC4.
 Then... CalJ came along and brought me yet another project. I'm not sure if he loves me or hates me.
 So, now I have STF and STF4 bikes in the works!
 I did a huge inventory of the parts I got from Cal and the parts in my stash. I picked up a few missing pieces and started building these two in my head.
 The bike I got from Cal used to belong to forum member Springer.
  http://forums.sohc4.net/index.php/topic,143800.0.html
  It was the victim of Cal's roof collapse a few years back and was a little worse for wear. But it's a heck of a good start and has plenty of nice parts, too!
 Today, I worked on the oxidation and chipping paint, from all the weather exposure.
 Before (and while I was wire brushing the end caps):ore (and while I was wire brushing the end caps):
 After some wire brushing, buffing, polishing and a little paint touch up. Not show quality, but bringing it back to life!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #268 on: March 27, 2019, 03:33:13 PM »
 While I was in there I got a couple of nice surprises....
 Dyna ignition
 And upgraded valve cover
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #269 on: March 27, 2019, 03:37:29 PM »
 Found a use Delkevic exhaust on eBay. Made the seller and offer and combined it with a 20% off sale in the app. Got a basically new Delkevic for about $85 off the list price.
 I also busted apart these hubs I had. The rear was from the Glutton bike and sat in a leaky shed since the '80's before I got it. It took two days of soaking, heat, cursing, bloody knuckles and lots of beating to get the retainer ring out. The ring is now kinda ugly but should be reusable.
 Cleaned these up and I plan on painting the inner fins and having a set of hoops that have been in my stash for years powder coated. New spokes and bearings are on the way.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #270 on: March 27, 2019, 03:41:51 PM »
 The powder coated wheels will go on the Springer bike. I have a nice set of chrome wire wheels that are from another parts haul from about two years ago that will go on the other bike.
 The Springer bike will be a tracker of sorts.
 While the other bike....well....I have some ideas spinning around in my head. It will be built using this tank with an awesome, original, old skool '70's paint job on it.
 I picked this up during the eBay sale day, too. I just couldn't pass up the '70's goodness, minor chips, patina and all!
'71 CB500 K0
'81 Yamaha XS650
Offline Kelly E
  • Geriatric Hooligan
« Reply #271 on: March 27, 2019, 04:25:06 PM »
What year's have the upgraded valve cover?
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Scott S
« Reply #272 on: March 27, 2019, 04:32:43 PM »
 I believe '77 and '78 had them.
'71 CB500 K0
'81 Yamaha XS650
« Reply #273 on: March 27, 2019, 10:28:16 PM »
That is correct, the 77-78 had the pinned rocker shafts eliminating the eccentric wear problem of the early 550s.
Offline Kelly E
« Reply #274 on: March 28, 2019, 08:52:50 AM »
Thanks, I will look for one. Mine is definitely an early 550K. It is number 449 with 18k miles.
1983 Honda CB 1100F
