Author Topic: 79 CBX project  (Read 11841 times)
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
79 CBX project
« on: June 05, 2018, 05:39:08 AM »
Well the 74 CB550 is running great thanks to all the help I received here.  Guess it's time to start on it's big brother.  Both were parked back in 88 NOT with the intention of leaving them for 29 years.
I'm hoping the CBX will be as easy as the 550.  Some rust in the tank carb rebuild and some brake work.  Fingers crossed.  My evapo-rust was delivered yesterday!
Right now the bike is as dead as a door nail.  Off with the tank for cleaning and a wiring inspection will be next.  Probably purchase Mike Nixon's booklet, "Rebuilding the CBX1000 Carburetor" before starting on the carb rebuilds.
Dennis
Offline innovativems
    • Innovative MotoSports
Re: 79 CBX project
« Reply #1 on: June 05, 2018, 06:47:43 AM »
Gorgeous cbx!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Re: 79 CBX project
« Reply #2 on: June 05, 2018, 08:10:14 AM »
Following  :)
Offline Bankerdanny
  • Endeavor to persevere
Re: 79 CBX project
« Reply #3 on: June 05, 2018, 09:08:07 AM »
Nice. I love the early twin shock CBX's
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
Re: 79 CBX project
« Reply #4 on: June 05, 2018, 11:14:57 AM »
If your CBX was parked in '88, you WILL have to go through the carbs! There is, never has been any CBX that was parked for more than 2 years which did not require carb work. If the carbs were no drained, the small jets and the accelerator circuit are gummed up. If the carbs were drained, most likely the O-rings are dried out and leaking.
Prepare yourself for quite a few hours of work and/or frustration. Engine need to be tilted to get the carbs out and very few get the carbs running right on first try.
If you don't have it already, Mike Nixon, a former Honda service rep put together an invaluable little pamphlet on how to restore CBX carbs.
It is available on ebay of from the author himself.
 https://www.motorcycleproject.com/
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Re: 79 CBX project
« Reply #5 on: June 05, 2018, 11:32:54 AM »
Parts can be a PITA to find and very expensive.....I have a red 79 in pieces and have been collecting all the parts for 5 years. Have 99% of the parts now and even scored a NOS Sport Kit for a very fair price.
Offline DurangoCB
Re: 79 CBX project
« Reply #6 on: June 05, 2018, 11:42:35 AM »
Love those bikes.  Have fun!
1971 CB500 Four- current project http://forums.sohc4.net/index.php/topic,170622.0.html
1978 CX500- next in line
Offline strynboen
Re: 79 CBX project
« Reply #7 on: June 05, 2018, 01:27:39 PM »
thek the generator..and thange the bearings  and brushes...carbs is a bit hell to Work on....get a real good gasket/o ring kit..vho can hold up for fuel...strange some dont do that...
i hate all this v-w.... vords
Offline kpier883
  • is quite the
Re: 79 CBX project
« Reply #8 on: June 05, 2018, 08:31:32 PM »
Randall has a very good kit for CBX carbs.  It and the book you mentioned are what I used.
https://www.randakks.com/honda-cbx-randakk-master-carb-overhaul-kit.html
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Re: 79 CBX project
« Reply #9 on: June 05, 2018, 08:34:20 PM »
Thanks for the comments & info guys.
Mike's carb rebuild book is on the way.....
strynboen, I'm leaning towards using the Randakk carb rebuild kit.....
Dennis
Re: 79 CBX project
« Reply #10 on: June 05, 2018, 08:38:57 PM »
Thanks kpier883!  That's the direction I've been leaning towards.  Looks to be a very complete kit.
Dennis
Offline strynboen
Re: 79 CBX project
« Reply #11 on: June 06, 2018, 06:19:57 AM »
be very carefull vhen lockteit the choke plates schrevs...i got mine glued solid...thorth it vas better then use Lock/cut vashers...
Offline MoMo
  • Ride like you're invisible
Re: 79 CBX project
« Reply #12 on: June 06, 2018, 07:03:18 AM »
subscription sent in.  Never forget the test rides after working on one "back in the day".   Larry
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
Re: 79 CBX project
« Reply #13 on: June 06, 2018, 07:53:40 AM »
You will have to pull the pressed-in slow jets out. They sit under rubber plugs. You can tap them and use a small M3 or M4 screw to pull them out. Very difficult to get completely clean without pulling them. Also, the emulsion tubes have a tendency to stick. You may have to heat the jet tower they sit in and/or soak the carbs in hot soapy water for a while.
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline Bob3050
Re: 79 CBX project
« Reply #14 on: June 06, 2018, 09:00:26 AM »
Find a turbo kit for it and you can leave those six carbs in the garage.
Bob
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
Re: 79 CBX project
« Reply #15 on: June 06, 2018, 12:53:35 PM »
Bob
 :o :o you could also replace the motor with a 104 cu-in V-Twin.... ::)
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: 79 CBX project
« Reply #16 on: June 07, 2018, 07:03:16 AM »
Following
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: 79 CBX project
« Reply #17 on: June 11, 2018, 02:21:13 PM »
    Good looking CBX, be looking in to see how it goes with yours. I had a 1980 CBX, for about 6 years. Then, situation changed & I needed to come up with some cash and with me getting older, I thought it was best to let it go. Boy, I have been regretting it ever since.
Member # 1969
Re: 79 CBX project
« Reply #18 on: June 13, 2018, 02:17:58 AM »
Got Mike's carb rebuild book in the mail and was going to start this weekend, but I got side-tracked with this little beauty.
2011 CBR250R with less than 6000 miles.  Needs just a tiny bit of tlc, but got a great price and it's a blast to ride.  Plus I can ride it to my night job.... won't take the '74 CB550 for fear that something would happen to it in the parking lot.
Dennis
Offline bill440cars
Re: 79 CBX project
« Reply #19 on: June 15, 2018, 08:45:07 AM »
Dennis
       Slick looking ride there. Should be fun.
Member # 1969
Offline jag767
Re: 79 CBX project
« Reply #20 on: August 08, 2018, 05:23:24 AM »
Fyi if you need any parts, a friend of mine has 3 cbx's, and a parts room for them. Probably enough to build 2 more, at least 1 complete one.
Re: 79 CBX project
« Reply #21 on: August 21, 2018, 02:36:58 PM »
Nice looking CBX.  I think Nils has restored a few, too.
Online PeWe
Re: 79 CBX project
« Reply #22 on: August 22, 2018, 10:01:48 PM »
I saw a red 79 CBX earlier this week. I like the stock look. I have forgotten how nice the engine sounds. Really quick throttle response.
A NOS looking -79 will be fine in my garage.
Re: 79 CBX project
« Reply #23 on: December 21, 2023, 05:59:26 AM »
Well it's taken me 5 years, but I brought the CBX home this past weekend!  With a bit of luck hoping to have it road worthy by spring.....
Online newday777
Re: 79 CBX project
« Reply #24 on: December 21, 2023, 07:00:20 AM »
Cool. Did you get anything done to it in the past 5 years it's not been home?
Stu
My current rides
Prior bikes....
