Author Topic: Lets see a photo of your SHOP!  (Read 222866 times)
Re: Lets see a photo of your SHOP!
« Reply #1700 on: August 20, 2023, 08:19:42 PM »
I remember the old house well, I always felt like I was either going to fall down, or fall up. Magnificent view of the surrounding area but not person friendly. ;D
Online BenelliSEI
  • 1969 cb750
« Reply #1701 on: August 21, 2023, 07:07:36 AM »
The garage in the middle of a post Rocket 3 tidy up. That's the K7 under the Super Tenere tank. The Vmax is outside getting some fresh air
Clever use of a skateboard!
i used to have a Vmax engine strapped to it until one day i rolled it out of the carport into the driveway ( both of which were on a reasonable to severe slope - this slope also caused Terry's BMW chookasaurus to roll of its stand and whack the side of the clown car ), i wedged it up against the garden bed, turned round and heard the ominous noises associated with a motorcycle engine strapped to a skateboard trundling off down the hill, i started running while at the same time thinking "what the fcuk am i going to do even if i can catch it ?"  it rolled about 20 feet down the hill then fell over, momentum caused it to roll over a couple of times before coming to a halt just before it would have dropped off the small cliff on the other side of the driveway. if it had gone down there it would still be there.
i no longer live in that hell hole of a house
Sounds like good material for that vintage Benny Hill show  :D
too much swearing
I’ll try and only use it on a “flat floor”!
Offline Kelly E
  • Geriatric Hooligan
« Reply #1702 on: August 22, 2023, 02:50:14 PM »
Today we have 5 bikes undergoing some sort of repair not counting the KL 250 resurrection. 2 with batteries getting charged. 1 waiting for a starter solenoid. 1 waiting for a jet change and 1 waiting for a decision about repairs. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Online BenelliSEI
  • 1969 cb750
« Reply #1703 on: August 22, 2023, 05:45:10 PM »
Kelly….. busy shop!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1704 on: August 22, 2023, 05:59:53 PM »
Moved a table out of the main shop into the shed. That made room to move the air compressor and the Tig welder to a spot allowing more working room towards the front of the lift. Of course I didn't do any of that today. I slept a lot and took a 100 mile ride.
Sent from my LE2127 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Kelly E
« Reply #1705 on: August 22, 2023, 07:26:21 PM »
I didn't get to ride because I had to haul my daughter around. Her van had a flat tire but I did get a bunch of firewood stacked. It was high broken clouds and 74° so stacking wood isn't brutal out even though I'm in the shade. Still a bit left to stack and there's more off screen to the left. 8)
1983 Honda CB 1100F
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1706 on: August 22, 2023, 08:32:05 PM »
Now that is a quality days work!!!
Offline grcamna2
« Reply #1707 on: August 22, 2023, 09:39:32 PM »
Kelly,the one waiting(we spoke on the phone  :))for a decision(81' black w/ orange stripe GS1100EX)0n repairs; do you think it will need all new seals and gaskets plus further inspection from having it's cases filled with gasoline for a certain duration ?
75' CB400F/'bunch o' parts'
« Reply #1708 on: August 22, 2023, 10:34:48 PM »
Kelly, that’s a nice days work with the neatly stacked firewood. You must go through a lot of wood in a winter there… Best to get it in and stacked so it can dry some more this fall before you start making the stack smaller.
David
Offline Kelly E
« Reply #1709 on: August 23, 2023, 08:32:54 AM »
David
All the wood is bone dry. It's been sitting there since the middle of June baking in the sun.
That's 6 cords of Douglas Fir, Walt the Wood Guy drops off that much every year already cut and split. I spent over 20 years cutting and splitting that much wood every summer. I had my fun so now I buy it and just have to stack it.
1983 Honda CB 1100F
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1710 on: August 24, 2023, 02:44:08 PM »
Bouncing back and forth guiding the oldest and his best friend on some choring, then playing with the 3 younger ones amongst a slew of side quests from the ole lady....
Getting real close just the workbench left to clean and organize
Of course I've already planned to add something...... A small sandblasting cabinet. Not saying I might not build it myself just not a 100 sure yet. Might just buy a cheaper one from jegs.
Offline Kelly E
« Reply #1711 on: August 25, 2023, 05:05:41 PM »
If you buy the blast cabinet from JEGS lay down a bead of silicone sealant along every joint and circle every screw hole during assembly. Ours is just about dust free outside, only leaks from a rear lower corner but it's so small I don't worry about it.
1983 Honda CB 1100F
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1712 on: August 25, 2023, 06:00:33 PM »
Thanks for the advice!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1713 on: August 26, 2023, 06:30:46 PM »
Got my buddy's Softail on the lift today.
Offline Kaze
« Reply #1714 on: September 18, 2023, 02:25:03 PM »
I tore down the old shed and built myself a 10x12 Dad-Den, with heating and it's own power box... But then my son got older. No room in the house for giant kids, so that out-building is the "college man's room" now. I now have...a 2x3 space I carved out inside the garden shed.
Walk in. Turn to the left, turn to the right. Back out, because there's no point in turning. Bring a fist full of tools to the other side of the house where the carport is. Go to where the bike is sitting on GRAVEL so that I can lose every &*^*# gray nut and bolt that comes off my Honda. Walk back to the shed cursing because "of course" a socket won't fit. Grab 17 & 19mm box end wrenches... go back to bike...squat... why the @*&Y*#$ do I have an SAE feeler gauge? Why do I even OWN an SAE feeler gauge?! Walk back to shed at an angry clip to get proper metric feeler gauge. Get distracted by the rust on the metric feeler gauge. Start polishing rusty tools.
« Last Edit: September 18, 2023, 02:37:00 PM by Kaze »
One man's rubbish is another man's project.
« Reply #1715 on: September 18, 2023, 03:37:59 PM »
Sounds like you could cross-post to the power off thread with no issue. Could be worse, your tool box could be in a basement. Magnetic tool tray or bowl is a good idea for working on bikes or vehicles...
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1716 on: September 18, 2023, 03:43:21 PM »
I'm in an 11 by 12 lean to shop I built from used materials. Also with a gravel floor I thought man work is throwing out these black rubber anti-fatigue mats those would be great to cover my flooring in. It's nicer on the feet but now when I drop a nut or bolt it hits the rubber and bounces into Oblivion I used to be able to drag a magnet and find stuff in the gravel LOL
Offline Kelly E
« Reply #1717 on: September 18, 2023, 04:29:08 PM »
Gurp's our top expert on working in small spaces. 8)
1983 Honda CB 1100F
Offline Kaze
« Reply #1718 on: September 18, 2023, 07:34:24 PM »
HAHAHA! Guess what? I put those mats down too. You're right, they are no help.
This week I lost the little round piece that goes into the rear brake arm. I didn't notice that it had fallen either so it was lost. I had 2 kids and me going over the gravel with magnets... No dice. It's likely in Oblivion with your parts.
Thank goodness I found a backup part in a box. Gravel is evil.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1719 on: September 18, 2023, 08:59:34 PM »
I wish. Sometimes I roll stuff outside just to have so damned room. Hoping to close on this house soon and not be so cramped.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1720 on: September 18, 2023, 09:02:50 PM »
It really seemed like a good idea till I did it...... It did solve a few issues for me but made finding things worse. And yeah that part..... No sounds when stuff falls now.... Absolutely terrible
As you can see though I stay cramped in there.
Offline Kelly E
« Reply #1721 on: September 19, 2023, 08:29:25 AM »
Be careful, I moved from a 864sqft shop to 1400sqft and the new shop was stuffed full. It took a year to build the utility room, replace the 200amp service, install the benches and get organized. I had no idea that I had accumulated that much stuff in 10 years. Now once or twice a year Barnacle Bill and I do a purge and haul a couple of truck loads to the dump. 8)
1983 Honda CB 1100F
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1722 on: September 19, 2023, 08:49:55 AM »
I'm on my 5th reorganization.
I started back into the 7x12 that my shop is built on to.
I'm actually on the way home with bike parts as we speak. Haha. Stopped for a lunch with my oldest son.
I know I have enough now to fill a 20x20.
I need to purge now but my heart can't stand to throw out good parts.
Offline Kaze
« Reply #1723 on: September 19, 2023, 12:07:06 PM »
...but if you throw away bike parts your future self will curse you?
In my defense of throwing away those "broken" CB750 engines...how was I to know that I would know more than I thought I knew?
Offline grcamna2
« Reply #1724 on: September 20, 2023, 04:44:45 PM »
Lol  ;D  exactly !
