Author Topic: I've been K0'd!  (Read 200538 times)
I think those triples are prone to breaking whether the proper washers are there or not.  If you see one and the washer is actually pinched, it is likely broken...so I don't see how the presence of the washer's, correct or not, make any difference.
 I'm for sure using the inch lb, torque wrench going back on. If there was a CNC'd unicorn with heavy duty fork clamps for 2-3 hundred I'd probably buy one for this bike.
 I never had the sandcast's  tree off or I'd retorque it too. I'll let that sleeping dog lie.
  It's really remarkable how little I've done to it besides cleaning the carbs and oil/ filters/ plugs, rear spokes, tires I still have the front but not mounted. I've painted the 1 nos, 1 used Honda sidecovers. The stock airbox isn't on it but it's here. One turn signal socket and bulb was rusty.
 I'm going to paint some Frankenbike sidecovers with a yellow/silver base under the candy ruby red to try to match the tank's paint fade.
« Last Edit: March 15, 2018, 09:10:24 PM by Don R »
The Unicorn triple was a bad design, not enough meat around the fork tubes, the gap was too wide, and the material it was cast from was too brittle. If Harley Davidson built one like that, they'd be reviled, but us Honda lovers seem to be able to forgive any of Honda's sins.
Interestingly enough, the Unicorn triple on my K2 bitsa has the D washer on one side, but there's not enough room for one on the other side, but it hasn't been repaired, could it have stretched? I've got a busted one here and the metal is very "crystalline" in appearance, but I've got both bits still, so once I've mastered my 8 year old TIG that I've never previously been able to master, I'll do a perfect weld and re-use it.
Before these triples were worth any money I had a few but sold them for not much or gave them away, but I've still got one here that someone's lopped the horn off? Maybe it would be safer to chop the horn off the broken one, and conduct a horn transplant? A "Horn-ectomy"? Or maybe a "Triple Bypass"?............;D
Offline jaytee-nz
Terry, my unicorn tree was broken at the clamp too. I gave it to a welder at work with 25 years TIG experience and when he gave it back to me repaired, he told me it was the worst sh%t he had ever welded and he didn't want to ever see it again ! I think your description of the metal sounds accurate.
The crystalline break is a type of fracture and it has been too long since materials class.  A stretching break if I recall correctly gives that structure in the break, whereas shear will give a different look to the metal.
You might be better off as providing a 3D scan of a good triple to be able to import into CAD-CAM software to develop a CNC cut triple tree.  It would require a bunch of cutting operations and a very fine ball mill to refine the surface after it was taken to a smooth surface with a larger ball mill with its limits reached.  Then it would be put in a vibratory polisher to spend a week (joking) polishing and further smoothing that finish. After coming out of the polisher you rekey it to the CNC and I think I would bore a small center hole for the triple's for tubes and then after polished you reindex and then bore the triple tree for tube holes and any slots for the washers.
Kingsport Public library offers free 3D printing training and has a 3D scanner that is no charge to use to be able to scan an object and then replicate it by 3d printing after editing the scan file and prepping that fire for the printer so it knows where to print or to provide the support tubes and or fill for an object or make it hollow.  I intend to scan and print something for a friend but I have to make it first.  It is for an RC airplane for a friend in England. A pair of scale Lewis guns in 1/11th scale for one of the WWI airplanes.  Having to make the tubular gun mount for the gun in the gunner's position. Second gun goes on top of wing on a rail for reloading it retracts back and down to where the pilot can change the bullet cartridge canister holding the ammo.
The gunner sat on a basket like affair...he was not belted into place and a few gunners were ejected in combat apparently.  No, not an ejection seat.  ;)
Don, yellow and silver? Or silver base with then yellow? Or, vice versa?
Thanks
David
Thanks David, the same suggestion was made on a CB750 FB forum, but the resident machinist said while he could do it, it'd cost a fortune to machine one from a solid billet of aluminum. My Gold K2 with the FZR1000 forks had a CNC machined set of triples, and I liked them so much I asked the guy who'd made them to make me another set, but baulked at the $1000 quote he gave me. Probably better to just buy a Yamiya repro. ;D
 Triple bypass, that a good one. I'm quite sure I overtighten them but it seems once the gap is closed what's the harm. (now I know) lol. Thanks for the lively discussion. I've considered welding a third onto two thirds but as long as I have one to use there's no sense getting too carried away.
Another idea would be to find a sand casting foundry, or make your own with enough capacity to melt enough alloy at once...
You can melt down aluminum you buy from small cutoffs at metal shop of known alloy.  If you need to add other metals to make the alloy have better strength, then that is added to mix it up.  Lots of YouTube  stuff on it along with websites.  Sand Casting your own using the right kind of sand bought at your local investment casting or metal shop that does casting work.
You can build your own foundry from concrete/cement with Alumina powder added to make it a high heat version.  Add denatured alcohol to help it flow better and a big vibrating sander or borrow the....er, nevermind on that one...attached to your form can help reduce the bubbles...
A good leather apron and welding gloves and protection is important when dealing with metal casting, along with clothes to help protect against splatters...no bare skin, and face shield too.  Pair of thick cotton or good winter gloves beneath the welding gloves can help with insulating from heat but your tongs for gripping and handling your crucible, also possible to make your own....just have to ensure your tools won't deform and you can practice your moves using milk or water in the crucible to perfect your technique.
It is not going to be something you are going to do as a career or do to sell.  You will need to buy some mold making wax to apply to your pattern part to acct for shrinkage.  It comes in sheets and is very pliable and easy to use and it comes in various thicknesses.  It is the bomb on mold making.  No easy way to add the needed area to the original in a uniform way like the mold making wax.
« Last Edit: April 26, 2018, 02:49:39 PM by RAF122S »
I think the trick is to machine them out of bilet the height of the bar mount,  rough it out, anneal the part where the horn mounts, then bend it up. Then finish machine.
 Might be time saving to tilt it to machine the horn part.
« Last Edit: March 16, 2018, 01:56:41 PM by 754 »
 We have a foundry here that may be willing to pour some parts but aren't interested in making molds or dies. If I get one welded up to add some meat in the problem area I may check it out. No promises.
 I just noticed I have soda in my ears. Off to the showers! Someday I'll build a booth until then I'll use the grey sky blasting booth. The soda keeps the grass out of the expansion joints
Offline DickL
  • Really really old
I have a 1970 750KO triple tree that is not broken and has not been welded. Its chromed, the chrome is peeling and you can have it for the price of US ,shipping.
Dickl
SOUTHWick, Mass.
1970 CB750
1999 Honda Valkyrie
 I'd be proud to own that. I have a few parts waiting for a batch to go to the chrome stripper. There's a minimum so it doesn't pay to take less than 6-7 parts.
 If you'd like to, let me know shipping to 61401 and I'll send funds however works for you. thanks.
Offline DickL
  • Really really old
Ok. If i they have one of the USPS boxes that it will fit in, it should be modest. If i need something for my KO i know you'll be fair.
DICKL
1970 CB750
1999 Honda Valkyrie
Yamiya sell NEW improved tripples without need of the spacer! With and without an additional hole in the horny part. What is the hole for?
http://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_144_72&products_id=716
With hole
http://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_144_72&products_id=3242
It cost some to restore gauges. I have a complete K2 set shipping my way right now, hopefully no beginning of cracks. It need some new parts, bottom covers, faces, glasses, seals, fasteners ... Yamiya has it all.
The old gauge setup is a vital part of the specific bikes design.
Important to be aware of how the gauge is designed to be illuminated. I have a K6 restored tacho that has very bright white light while my stock speedo has a nice green light. I noticed that the inside of top steel covers has to be painted green which must be the answer.
The older gauges might have been painted inside too...
Just drain the wallet!! An old CB750 is like a prostitute, need money all the time and difficult to resist! ;)
« Last Edit: March 17, 2018, 02:09:23 AM by PeWe »
  Well there it is, no need to go wild making things when you can buy one already improved. With the hole is for the Japanese domestic speed warning light.
« Last Edit: March 17, 2018, 05:53:25 AM by Don R »
  I can't make myself tighten up the pinch bolts. They are snug and the washer still floats.  I may need to remove the top triple before I go further and make sure there's no corrosion in the holes.
Don, I think the washers are supposed to float...that's why I don't think they really do anything.
Offline MauiK3
  • A K3 is saved
  • Old guy
The D washers tightened up on my K3. They do not move. Maybe check thickness, could be too thin. Yamiya stuff is good, if pricey. But hey, I'm not complaining.
1973 CB 750 K3
10/72 build Z1 Kawasaki
 My D washers always tightened up before too. Then I found one broken and broke the next one L0L! I bought a bike with a broken one and also got a bike that had no D washers, it was fine so who knows?
Mic your fork tube, if it's been Rechromed  it may be bigger enought that it cant close up...or will break first.
 It's a new set Frank, I'm not sure I remember the source. Z1 maybe?
  Checking the OD is a good idea. I bought this new set for another bike and decided my keeper needs the new parts so I did a three bike fork tube swap. K0, early K2, and drag bike.
Thanks to another member here with sharp eyes, I scored a K0 triple in Texas with handlebar clamps and all the bolts for 135 bucks shipped yesterday, so I won't have to worry about welding up my spare triple for the next build. ;D
  Good deal Terry.
  I got the gauges on and everything's almost all wired back up with dielectric grease and clean contacts. Why is it those perfect turn signals you've been saving in a nice dry box in a plastic tote grow pits and gouges before you get around to using them? I guess I was hoping they were perfect, close but not so much. As it turns out the two right side signals and one left all have the orange tag on the wire.
  Headlight tomorrow after I vote for the Primary candidate representing least of my fears. Then I'm setting the old gas tank on and checking the float valves again before putting the painted airbox on. through filters of course.
 My Yamiya order came today from Joseph F Marks. I really need to figure out the photo problem I have. curse the photobucket.
« Last Edit: March 19, 2018, 10:04:46 PM by Don R »
