Author Topic: WTF! Ball Bearings all over the damn place!!  (Read 2389 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: October 17, 2009, 02:34:48 PM »
I didn't think that when I removed my lower tree the little bastards were going to bounce all over the damn garage! Nothing was holding them there but 30 year old grease! I think I found them all, can I still use them?
Offline Gorms
  • Barkeep! Give me a beer and a
Re: WTF! Ball Bearings all over the damn place!!
« Reply #1 on: October 17, 2009, 02:37:38 PM »
You can reuse them but considering upgrading to a roller bearing set.  Not very expensive and easy enough to install.
Offline robdrobd
  • Who? Me?
« Reply #2 on: October 17, 2009, 02:39:02 PM »
Are the roller bearings enclosed in some kind of case so they are not just "free ballin" all over the place?
Offline fmctm1sw
« Reply #3 on: October 17, 2009, 02:46:47 PM »
did that too a while back...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #4 on: October 17, 2009, 03:21:11 PM »
 Chasing around looking for your balls. :o...
The price you pay for not reading or owning a manual....
 PSSs.. they are 1/4 inch, if stuck buy caged bicyle bearings and pop em out..
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #5 on: October 17, 2009, 03:48:49 PM »
Yes.
Try a search on the site here from the home page "steering bearings"  ;D ;D ;D ;D ::) ::) ::)
Offline Gorms
« Reply #6 on: October 17, 2009, 03:48:58 PM »
[/quote]
Yes they are encased.  There are 2 pieces: one race, and another race with the rollers in a cage.
« Reply #7 on: October 17, 2009, 03:53:35 PM »
Like an old car or trailer bearing, tapered Timken type...
 Far nicer when you re & re the front end while working on the bike..
« Reply #8 on: October 17, 2009, 04:29:15 PM »
The trick is knowing how many balls there were. Hint, top and bottom are 1 different. Nobody would tell me either.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: October 17, 2009, 05:08:39 PM »
Having disassembled this far it would make no sense to skip replacing the bearings.
mystic_1
- John Augustus Shedd
Offline SohRon
« Reply #10 on: October 17, 2009, 05:15:19 PM »
19 on the bottom, 18 on top
Offline mystic_1
  • 1970 CB750K
« Reply #11 on: October 17, 2009, 05:17:26 PM »
If you re-use them here's a tip:  Use zero-year-old grease to hold them in place while you install the lower tree.
mystic_1
Offline SohRon
« Reply #12 on: October 17, 2009, 05:35:55 PM »
Here's how I did it. Should still work with the frame right-side up:
A big 'ol rubber band works great for keeping things together.
Offline robdrobd
  • Who? Me?
« Reply #13 on: October 17, 2009, 07:21:35 PM »
I followed your rebuild post and had no idea why everybody said the rubber band was a great idea, now I know  :P
Offline the technological J
  • deliciouso!
« Reply #14 on: October 17, 2009, 07:24:06 PM »
go to ur honda dealer and ask for the all balls tapered bearing not to expensive and well worth it... the timken bearings are a load more and  need a little special care to get them to fit but if u have access to to a metal shop they'll be worth it... but its an upgrade ive made on 2 of my bike and am about to order for my other two
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline GammaFlat
« Reply #15 on: October 17, 2009, 09:22:10 PM »
I had the horrible notch in the center position that I thought was a "feature" until I went "tapered".  The bike feels much nicer now.
K6
85 Goldwing
Offline KeithB
« Reply #16 on: October 18, 2009, 04:33:40 AM »
 :D :D :D
sorry, had to laff as I have done the same thing.
Found THAT out the hard way after searching for ages trying to find the 19th one for the top ::)
Nanahan Man
Offline Alan F.
« Reply #17 on: October 18, 2009, 02:52:07 PM »
You'll notice better handling out on the road too.  It's like the difference in handling between 10 psi low on the front tire and correct tire pressure.
-Alan
