Author Topic: What did you do to your bike today ?  (Read 3644271 times)
Offline fire113
« Reply #17550 on: May 13, 2014, 02:04:14 PM »
...what a bad day  :-[
...was going to do the gas tank decor and found out that the gas tank is looking "cloudy" in sunlight, was not visible in the painting room.
Did the gas tank again but the paint was bad/too old or what ever and I got some ugly flakes in the candy gold layer  ???
Have to do it again one more time  :P just ordered the paint.
Have to kill some tequila right now to get rid of the pain in my head.
Offline Jerilee
« Reply #17551 on: May 13, 2014, 05:03:05 PM »
Got my 'new' seat in the mail today!
I pulled the Suzuki taillight out of it and surveyed the land, a bit of damage to the plastic of the cowl where it was cut for that light, I'm wondering if it will show, if not I'm going to keep it and clean it up, otherwise I'll have to get another cowl.
The seat pan has some rust bust seems solid overall and the foam seems OK under new vinyl, I'll recover it in a more correct cover after I clean the pan and send it to the powder coater's with the rest of the black parts.
http://www.ebay.com/itm/160702898688?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 These look pretty nice but they're stitched, not heat pressed, and don't have the Honda painted on the back.
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline ryanj
« Reply #17552 on: May 14, 2014, 03:18:01 PM »
Cleaned the rust out of my fuel tank.  I used Betco Stix bowl (as in toilet) cleaner which really does stick.  According to the MSDS, it's minimum 20% phosphoric acid and it seems like it did a pretty good job.  I poured in two bottles (946ml each) and shook it all around, let it sit for 15 minutes, and repeated a couple times over about an hour.  I thoroughly rinsed it all out, let it dry, and coated it with a thin coat of light oil.
Before
The sauce
After cleaning, rinse, and oiling
Now that the inside is de-rusted, I can go ahead and begin de-yellowing the outside.
1976 CB550F
Offline fire113
« Reply #17553 on: May 16, 2014, 12:43:32 PM »
...did the spokes cleaning thing
Offline nccb
  • 1974 CB750 Four
« Reply #17554 on: May 16, 2014, 01:16:46 PM »
you got a before?  I've tried everything and can't seem to get them from not looking like #$%*
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #17555 on: May 16, 2014, 05:06:49 PM »
worked on the 1/2 plate aluminum for the hydro clutch conversion for baby.  getting there slow an steady.  got caught in hail storm this afternoon on her as well.  60 mph in traffic when it hit out of nowhere.  surprised still got windshield and helmet visor left.  scary as hell for about 3 minutes.
MATT
Offline thrutheframe
« Reply #17556 on: May 16, 2014, 06:17:54 PM »
Stuffed me some bucket...
My customer bought a bunch of Dime City stuff but didn't bother to see if it all fit together.  Those chrome buckets they sell are NOT meant for a full harness.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline jerry h
« Reply #17557 on: May 16, 2014, 10:28:52 PM »
Put some new rubber on the rear...........    I think I need to turn more, looks like I went straight too much ;D
« Reply #17558 on: May 17, 2014, 12:14:48 AM »
go riding with Oldscrambler in the Kettle Moraine...that will keep your tires wearing evenly
Offline 750K
« Reply #17559 on: May 17, 2014, 02:00:28 AM »
Did some spring cleaning of my garage, rearranged things and got my wife's and my dirt bikes fired up. Cleaned the plug, float bowl & fresh gas on both bikes. Fired on the second kick, got stopped by the cops while ripping up and down the street on my xr haha. Not street legal, no helmet and loud. Must have horseshoes up my ass, walked away without a ticket lol.
77 Cb750, 78 Kz1000
Offline fire113
« Reply #17560 on: May 17, 2014, 02:58:23 AM »
...half before I have, only one side was cleaned.
I used Nevr-Dull and after it I used Luster-pad's to get them like polished.
Offline nccb
  • 1974 CB750 Four
« Reply #17561 on: May 17, 2014, 05:38:56 AM »
thanks fire, I'll have to check that product out.
Wobbly
« Reply #17562 on: May 17, 2014, 02:08:39 PM »
Took the K8 seat off and put the proper N.O.S. K7 seat on. Then, I went for a little ride to a place where people speak funny.  :D
« Last Edit: May 17, 2014, 02:15:00 PM by Wobbly »
Offline Jerilee
« Reply #17563 on: May 17, 2014, 04:47:26 PM »
Power washed the grease and road grime off the swing arm while we had the hose out for the car washing. I'll strip it shortly in prep for new bushings and powder coat.
Jeri~
77/78 cool 2 member
Offline Bankerdanny
  • Endeavor to persevere
« Reply #17564 on: May 17, 2014, 08:18:32 PM »
Stopped by my buddy's hardware store and picked up the tank petcock bung I ordered off eBay last week. Now I just need to get the tank from my sister's so I can have the part welded on to replace the stock one the PO cut off for no good reason.
Offline Tempast
« Reply #17565 on: May 17, 2014, 09:35:52 PM »
My Hagons came in the mail :) Installed them and they are gorgeous. They're the 310mm style but for being shorter I don't compress them nearly as much as my original shocks. I'm quite a bit higher off the ground now :O Maybe they'll settle.
« Reply #17566 on: May 18, 2014, 03:27:03 AM »
Are you going to take it back to bare metal Georg? Regardless, you'll need to spray the silver base coat again, if you just spray more gold on it, it'll get darker, but the sparkly silver won't shine thru in sunlight.
I bet you already knew that, but I thought I'd just throw it in if anyone else is thinking about doing a candy paint job. Cheers, Terry. ;D
Offline blackbird939
    • Zundapps.com
« Reply #17567 on: May 18, 2014, 04:58:12 AM »
Assembled the clutch and lower oil pan, oil screen tube thing. Hadn't touched this bike since 2005.  :)
Offline Bailgang
  • Scott
  • Indiana
« Reply #17568 on: May 18, 2014, 05:13:04 AM »
Since I got my 750 running a few weeks ago the neutral light never went out even though it worked fine before I tore the engine down. No pinched wire so the problem was coming from the neutral switch itself so I tried another and still the same problem. The problem turned out to be an oversized o-ring I used, it sealed just fine but even though the switch seemed to be seated to the block it actually wasn't because of the o-ring so I installed the correct o-ring and neutral light works as it should. I'm getting the bike ready for a trip in July so I wired up a cigarette lighter under the seat so my GPS can have something to plug into.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline WhyNot2
  • I'm finally an
« Reply #17569 on: May 18, 2014, 06:25:14 AM »
Bet it's fun riding that thing on them autobahns over there. Bike looks good, and weather too. Ahhh France, miss it and Germany too.
I only had cars when I was over there, would like to have had a bike.
But, oh well, would have lost household poundage if I had one. Lots of hassle to ship back and forth.
Offline fire113
« Reply #17570 on: May 18, 2014, 10:15:15 AM »
...nope! I am not going back to bare metal, paint arrived on Saturday and I hope that I can finish the K0 next week  :-\
Was going to renew all my gauge covers but the sandblaster guy did a mistake--> all housings unusable / bent. The guy paid me for the housings and I ordered new housings, just finished all gauges but I broke one face plate, don't ask me how   ;D
Have a good one...Georg
Wobbly
« Reply #17571 on: May 18, 2014, 11:20:24 AM »
The Honda is my Baby. It didn't ship with the household goods. I had a crate made and put it in an airplane in San Diego from where it was flown to Frankfurt at my own expense. It cost more than I paid for the bike new.  :)
I don't care much about France. But France is only half an hour away from LRMC where I am stationed at--for the past eight years. Whenever I get the opportunity, I am in Italy, Austria or Switzerland, riding in the Alps--summer or winter. For the Autobahn, I prefer my other bike:
« Reply #17572 on: May 18, 2014, 01:19:46 PM »
Got The Patina Bike running on four cylinders for the first time in who knows how long?!
Offline goldarrow
  • one day, i'll be an
« Reply #17573 on: May 18, 2014, 01:20:52 PM »
I like the brownie.  Good job Stev-o.
CB550 K0
« Reply #17574 on: May 18, 2014, 01:22:56 PM »
Thanks, but it ain't done yet. Still need front brakes...working on that.
