Author Topic: What did you do to your bike today ?  (Read 3532438 times)
newday777 and 6 Guests are viewing this topic.
Offline socalenduro
« Reply #1950 on: April 25, 2010, 08:46:36 AM »
looks good, like an old bicycle goose neck stem
Offline Brown Bomber
« Reply #1951 on: April 25, 2010, 10:03:38 AM »
Thanks,
     I tried using rubber bits from some bar end weights, but had to adapt to the notch on the base to keep it from spinning. I had forgotten about the bicycle goose neck, I guess that design has been floating around in my memory for forty years, and found it's way out at 11:30 last night. ;D
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
Offline hondaface75
« Reply #1952 on: April 25, 2010, 10:26:33 AM »
Road to the beach for the first time in 2 years. about 5 hours of riding in 70degree weather. Thing ran absolutely amazing and I even hit the 'ton' for the first time! Lol, its been 3 years since I picked up the 750, but give me a break, these things arent exactly in the safest shape when we buy them.  :D Ill have to try her out again soon!
Offline Frankenkit
  • Industrial Strength
« Reply #1953 on: April 25, 2010, 10:28:27 AM »
rode to work... didn't get to get out yesterday, but such is life.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline kpier883
  • is quite the
« Reply #1954 on: April 25, 2010, 11:39:34 AM »
Worked on the side covers for the CBX.  Both had the rearward post broken.  I still had one of the posts, but not the other.  For the post that I still have, I super glued it back and then reinforced around it using some plastic weld epoxy from NAPA and mixed in some radiator repair compound, the metallic kind, to see if that would lend extra strength.  The other one, I used a bolt that I ground the head on so that it would fit better.  Will use a modified nut as the piece that goes through the grommet.
« Last Edit: April 25, 2010, 11:47:10 AM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline kpier883
  • is quite the
« Reply #1955 on: April 25, 2010, 11:41:14 AM »
Still need to JB Weld or something around the nut to make it slide in and out of the grommet smoothly.  The nut has been ground and sanded and will work as is, but could be better.  Almost final results:
« Last Edit: April 25, 2010, 11:43:52 AM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline Stixxy
  • I Lernd Lawtz at Scool.
« Reply #1956 on: April 25, 2010, 12:14:10 PM »
Finally got the rear wheel back on the 550 complete with new spokes, sprocket, tube and rim band.
Used http://forums.sohc4.net/index.php?topic=368.msg205745#msg205745 as a guide for the spokes. An excellent how-to write up.
'09 CBF1000
I don't have a short temper, I'm just very sensitive to bull#$%*.
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #1957 on: April 25, 2010, 12:41:48 PM »
Today, I took my '71 CB500 on it's maiden voyage after installing the complete induction system from a '78 CB550K. It's completely transformed the bike. We did a 250 mile breakfast run this morning - Fuel mileage 2 up cruising at 70 mph went from an average of 42 mpg with the original carbs to an honest 50 mpg. Cold starting is instant and warm up is smooth. The bike idles like it had only a single carburetor. Power, especially the ability to accelerate and pass without downshifting, is noticeably improved. SWMBO mentioned it to me before I even had a chance to ask her what she thought. Noise from the intake is about 1/3 of what it was with the original airbox and filter. And best of all, I got all this without seriously altering the bike's appearance. It wasn't a cheap mod, but it sure was worth the expense and effort, IMHO.
Stu
« Last Edit: April 25, 2010, 12:47:20 PM by chickenman_26 »
MCN DTF
Offline cookindaddy
  • I sure love this bike!
« Reply #1958 on: April 25, 2010, 01:34:38 PM »
Very nice.
Where is that spot?
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Zaipai
    • My Home page
« Reply #1959 on: April 25, 2010, 01:56:10 PM »
Stu
So it was just the carbs from a 787 CB550K?
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline spitcrazy
  • 1973 CB500 FOUR - German Model.... Funky Tailight!
« Reply #1960 on: April 25, 2010, 02:25:43 PM »
Thanks to all the knowledge on this forum I finally fired her up today. I read the tuning advice from all you all and put the key in and..... nearly killed the battery! Duh so psyched forgot the choke. Three kicks later, she fired, smoother than when I put her away (after the bike shop said they tuned her last year) no more valve noise, smooth running.
2ND mistake, so involved with her Saturday, didn't make it to DMV for registration, so a couple quick spins around the block is all I could do!! Calling for rain tomorrow.... bummer.
Thanks again all ya all...............here she is.
« Reply #1961 on: April 25, 2010, 03:36:57 PM »
Stu
.: Scott :.
No. Like I said, it was the complete induction system. To make this swap work, you need the carbs, plus the '77 or '78 manifolds and rubber connectors, plus the '77 or '78 rubbers that connect the airbox to the carbs. Those parts are all different lengths than the '76 and earlier models, and there are some diameter differences, too. And of course, you have to use the later style throttle cables, plus get a choke cable. I lucked out and got all the hard parts at a salvage yard for $60, then had to overhaul everything. Had to buy three new cables, 4 carb kits, 4 fuel needles.
Stu
« Last Edit: April 25, 2010, 03:48:43 PM by chickenman_26 »
MCN DTF
« Reply #1962 on: April 25, 2010, 04:36:20 PM »
Which beach?
Offline Zaipai
    • My Home page
« Reply #1963 on: April 25, 2010, 05:24:57 PM »
Stu
.: Scott :.
Stu
Thanks Stu, I will have to read up on that some..
Spitcrazy, glad you got her running!! Don't forget to hit the DMV soon so you can enjoy it!!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Zaipai
    • My Home page
« Reply #1964 on: April 25, 2010, 05:28:56 PM »
Well took a few steps forward and a few back but over all progress. At least its a rolling project now! Made some brackets for the rear turn signals, started cleaning up the front brakes for paint.. Also painted the handle bar end caps to match the frame. Also more I just don't remember at this time..lol
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« Reply #1965 on: April 25, 2010, 05:40:09 PM »
bled the front brakes and rode that #$%*... it was nice to put 20 miles on her...
Offline xfactor
« Reply #1966 on: April 25, 2010, 05:50:19 PM »
starred at my bike in the rain, then starred at the rain, then got sad and opened a beer because i cant ride today.
Offline 73nancy
« Reply #1967 on: April 25, 2010, 05:53:42 PM »
installed my front forks on my k1 cafe project working on getting it totally back togeather..
k1 cb750 cafe racer (aka Helter Skelter)
k6 cb750 stock daily rider project
k3 cb750 race bike 911 big bore, alum rods, 13:1, race cam other goodies
Offline myhondas
  • Not really such a
« Reply #1968 on: April 25, 2010, 05:54:02 PM »
Help me...I'm melting.....melting..... ;D....oohhhh did you get wet????
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline xfactor
« Reply #1969 on: April 25, 2010, 06:01:20 PM »
hahaha Yes because I dont have any rain gear. I ride in my non water proof mechanics jacket, but I would ride, if my brakes were 100%.
Offline myhondas
  • Not really such a
« Reply #1970 on: April 25, 2010, 06:48:46 PM »
Just yanking your chain ;D  I avoid bad weather these days too.  one thing to get caught in it, another to purposely go out in it.....we just had severe thunderstorms go through here. and I have a semi rain gear outfit.
SOHC# 5105 11228
Offline Frankenkit
« Reply #1971 on: April 25, 2010, 07:58:03 PM »
checked the plugs after a few hundred miles to see if I'm rich/lean/whatever, and they're in the 'Good/Best' range on Dan's MC page... sort of a 'soft white/gray' with a little white on the electrode but not much.
Cleaned the saddlebags, helped MickeyX with her Harley and we went for a nice little ride out near Bald Peak and Newburg.  ahhhhhh..... needed that. :)
front left turn signal went out. :P  time to decide on whether I want to go LED or just get regular bulbs...
1973 CL350- Lola?
Stuff for sale
Offline MickeyX
« Reply #1972 on: April 25, 2010, 08:27:57 PM »
Fixed my Sportster brake switch that lights up my tail light when I go on the front brake. (someone bent the hell out of my brake handle while I was parked at work last fall and it broke my switch inside) New-to-me brake handle was $10. I replaced that last fall when it happened. I fixed it with some tape built up on the spot the handle hits on the switch but it finally gave up the ghost completely a few weeks ago. I finally decided to put the switch in since I had the time today. The new switch (sat on the shelf in the garage for 8 months until really needed) was $70. :-\ Of course, now the back brake light switch stopped working too.  ::) I cleaned off the plug tips and prongs but nothing. It never ends. It's at least easier to replace. No soldering and heat shrinking, just pull it out and plug another one in and re-bleed the brakes. (pressure switch I think)
Replaced my right side hand grip and throttle sleeve with a new-to-me one for $1 from the HD pull off place. It was ripped up from the PO so I finally got around to putting the other one on after 1 1/2 years of ownership. I figured since I had the whole thing apart... ya know.  :P The HD guys just look at me when I don't want to slap a bunch of chrome on my bike or I'm okay with a used part. Well dear, you just sit there in the parking lot looking shiny and talking about riding. I'll actually go ride mine, thankyouverymuch.
I swear, it looks like a HD swap meet in that parking lot every weekend. They just sit there, eat, drink and then ride home. Unless it rains of course. Then it's full of cars. As Kit and I ride past for breakfast and a nice wash-it-while-you-ride-it kind of day.  ;D
« Last Edit: April 25, 2010, 08:29:59 PM by MickeyX »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #1973 on: April 25, 2010, 08:31:58 PM »
Counter sunk the holes in both of the newly drilled brake rotors, cleaned and even got a couple coats of paint in the centers ;D
« Reply #1974 on: April 25, 2010, 08:45:52 PM »
Lets see a pic, What did you use to drill them, and how did it go?
