Author Topic: What did you do to your bike today ?  (Read 3670066 times)
0 Members and 10 Guests are viewing this topic.
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #32850 on: February 26, 2024, 07:27:16 AM »
I then also had my friend's girlfriend (she's a power lifter) move my motor out of the garage and up three flights of stairs into my dining room.
Guessing you are not married!  My wife would flip if I brought a motor in the house! [or a female power lifter!!]
Did you get some help to lift it off the floor for her;then she dead-lifted that heavy CB750 motor/trans off the bench and took it from there ?
So we're both good deadlifters - mine is about 360lbs and hers is about 330lbs. The weight isnt the issue, right. It's the weight distribution and the fact there isnt much to grip onto underneath (dont want to apply shear force to the covers). The stupid thing constantly wants to tip forwards. But we humped it up the front steps (three storeys!) and now we're all set.
She is good friends with my girlfriend. They workout together sometimes.
We figured out a solution though. When it's upside down I'll modify two long 2x4s so the mounting bolts can be used to secure the motor to them. Then we'll lift the whole thing like we're footmen transporting a nobleman on a litter carriage and it'll be a lot easier
I like the long 2x4 handles for two individuals;should work well.
How much does a CB750 complete engine weigh ?
Felt like a lot more than 176.5 lbs
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline lash
« Reply #32851 on: February 26, 2024, 09:42:33 AM »
Tell me about it! Feels like 1176.5 when I’m trying to move them.
Offline BenelliSEI
  • 1969 cb750
« Reply #32852 on: February 26, 2024, 12:25:48 PM »
+1 to that! I think the cb750A may even weigh more. What a pig! Had to slide it into the tractor bucket to move it by myself…….
Offline wolf550
« Reply #32853 on: February 26, 2024, 12:46:24 PM »
Ended up selling the frankenstein bike. went to the local cycle gear an hour away in knoxville to get some oil for the brown betty bike. getting it ready to sell also.
After that sells what's the plan motorcycle wise?
after selling the motorcycle I gotta get the rest of the stuff sold off. I have to get the wifes corvette running again before any project for myself to work on.
74' CB550 (Sold)
71' CB500/550 (Sold)
« Reply #32854 on: February 27, 2024, 07:15:53 AM »
I have to get the wifes corvette running...
Corvette? What Corvette!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32855 on: February 27, 2024, 07:57:33 AM »
That's what I'm saying?!?!
Got any pics of it?
Sent from my LE2127 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline BenelliSEI
  • 1969 cb750
« Reply #32856 on: February 29, 2024, 06:15:31 PM »
Finished up a set of carbs for my cb750 K6 project. Set float heights and then did a “Bench Sync”. Been asked what I do, so here it is:
I usually prep a long shank, 1/4 drill bit by making sure the shank is smooth and burr free. I stick it in my drill press backwards and dress the shank with some Emory cloth so it is really smooth and polished.
I start by removing the idle screw/spring and park the spring off to one side. Screw the idle screw in until it touches the operating bridge and add a few turns to the screw. Adjust #2 carb so the slide just barely lifts off the bottom of the carb throat. Lightly lock down the top nut, without moving the base nut/thimble.
Next I crank the idle screw up until I can just slide in the shank end of the 1/4” bit, between the belly of the #2 carb throat and the bottom of the slide. Adjust it so the shank must be flat and centred to just drag in and out. Now using the top adjusters on the other three carbs, set them to the same height….. Lightly lock the top nuts and done. The rubber dust covers on the top adjusters are a pain, but I like the look and they keep the sliding contact faces clean.
Remember to put the spring and washer back in the idle screw! I always check the sync with my old Motion Pro sticks, once the bike is running. I’m often surprised how close this mechanical routine gets it.
Offline WhyNot2
  • I'm finally an
« Reply #32857 on: March 01, 2024, 04:18:31 AM »
Put the 750 on the table removed the swingarm, ordered stainless steel spokes for the front wheel to match the back wheel.
Now, just gotta find someone to lace it up.
Bushings are a bi1ch to remove. Got new brass(bronze) ones to go in. Still beating and banging to get the old ones out.........!!!!!!
Still debating putting the rear fender back on, and install the Lucus style light I have.
Maybe goat head and get a 16" harley wheel for the rear.
So many options
Offline Kelly E
  • Geriatric Hooligan
« Reply #32858 on: March 01, 2024, 07:32:23 AM »
To remove the swingarm bushings I use 3 washers that are just under the ID of the swingarm. Grind the washers flat on opposite edges to form a double D until they will drop through the old bushings. Drop them in and turn them flat so they sit on the bottom bushings. Then use a long drift to drive out the bushing. Then drop 3 unground washers in to drive out the other bushing.
« Last Edit: March 01, 2024, 07:34:32 AM by Kelly E »
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline WhyNot2
  • I'm finally an
« Reply #32859 on: March 02, 2024, 05:47:51 AM »
Thank you. Thats a good way to do it.
I finally got them out using a sawz-all with metal blade.
Cleanup time then reassembly, drop the rear, and prop up the front, replacing the forks with shorter CB550 forks.
Have a new Delkevic  exhaust to install aftere front end diassembly.
Offline fire113
« Reply #32860 on: March 03, 2024, 03:24:42 PM »
...did the first ride this Year.
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #32861 on: March 03, 2024, 04:13:16 PM »
Beautiful bike ! 👍👏
Offline wolf550
« Reply #32862 on: March 03, 2024, 04:38:53 PM »
Got any pics of it?
77' light blue. last running in 2002. hard knock from engine. turned out to be crankcase bearings. going to do an overhaul on it.
74' CB550 (Sold)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32863 on: March 03, 2024, 07:58:48 PM »
Got any pics of it?
We gotta see some pics!!!
« Reply #32864 on: March 04, 2024, 07:27:49 AM »
Got any pics of it?
Prolly looks like this...
When rebuilding, a lot of updates can/should be done to a '77 SBC, they were real dogs [my brother had one]
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32865 on: March 04, 2024, 08:03:45 AM »
Got any pics of it?
That's the greatest thing about those engines is you can do about anything to them. The car is a real beauty!!!
I'm just butting up right now from doing this injector job on my ram 2500. It's something I never did just because I thought it was going to be more of a job than it was. Only took about 45 minutes.
Now ready to go drive it around running better after I finish buttoning it up and clean up.
Offline fire113
« Reply #32866 on: April 01, 2024, 04:49:41 AM »
...did the cleaning thing at the front wheel.
« Reply #32867 on: April 01, 2024, 08:31:16 AM »
New mirrors for Red.  These don't shake.
Offline Magpie
« Reply #32868 on: April 01, 2024, 09:25:08 AM »
The frame is about ready for the motor- a K6.
Offline M 750K6
« Reply #32869 on: April 01, 2024, 03:24:51 PM »
I managed to scratch the bottom frame rail on mine. Right about where your jack is holding the rail. Might be worth some tape just there?
Offline wolf550
« Reply #32870 on: April 01, 2024, 04:22:36 PM »
Got any pics of it?
last running in 2005 I think It wasnt running when I met my wife in 07 but it is just waiting for some love
74' CB550 (Sold)
Offline wolf550
« Reply #32871 on: April 01, 2024, 04:25:08 PM »
Had to take the bike out of storage today and ride home. got alot of nice compliments from the locals when I stopped for gas and cruising. sitting up on top of the hill looking out at the lake
74' CB550 (Sold)
« Reply #32872 on: April 02, 2024, 03:28:57 AM »
Rightly so.
Offline BenelliSEI
  • 1969 cb750
« Reply #32873 on: April 02, 2024, 04:55:58 AM »
Looking good!
Offline drodg33
« Reply #32874 on: April 02, 2024, 06:56:27 AM »
Very nice.
