Author Topic: What did you do to your bike today ?  (Read 3711593 times)
0 Members and 14 Guests are viewing this topic.
Offline Trav-i
  • Has finally become an
« Reply #8150 on: November 05, 2011, 06:25:24 PM »
Pulled the ignition switch out for a quick repair.  The key had gotten almost impossible to turn, now all is well just gotta put it back in.
Forum member #9962
1992 GL1500 Interstate
Offline Dimitri13
  • 1974 CB550K
« Reply #8151 on: November 05, 2011, 06:44:24 PM »
aired up batteries, charged chains, adjusted off to work, monday.
Is it bad that I read it like this?
Offline caluser2000
« Reply #8152 on: November 05, 2011, 10:34:25 PM »
Out in the shed going over the wiring on the 550 this arvo. Should have gotten some insulation tape, eletrolitic(sp) grease and contact cleaner last week. Seems the old reg is charging a bit better due to cleaning contacts but something fishy going on with the rh indicator and light switch in the rh switch block. Out of the hell I tried a DOHC CB750 reg/rect but instant battery drain. On looking closer at the it looks like it had fried sometime in its past so I'll cut the wires for reuse and biff the rest. Luckily no damage to the loom this time.
Couldn't figure out why she wouldn't fire. Fuel and plenty of spark. Finally the penny dropped. Took a while though. I'd connected the points wires around the wrong way last week. So back to square one.  I'm really enjoying the tinkering and I'm sure Ronda is enjoying the fondling I'm giving her too. No in any hurry to get her out on the road though. Good things take time.
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline fire113
« Reply #8153 on: November 06, 2011, 04:49:47 AM »
...checked my carbsync @ the K1, one kick and the engine is running very good  ;D
Offline heel_touge
« Reply #8154 on: November 06, 2011, 05:36:37 AM »
Was rolling no front caliper for a bit. Found my solution on a parts bike I picked up.
Offline Cqyqte
« Reply #8155 on: November 06, 2011, 05:57:37 AM »
Made a final determination, the OEM rims have got to go... too much damage due to rust and pitting!
The build just got more expensive  >:(
Offline Picasoo
« Reply #8156 on: November 06, 2011, 09:05:30 AM »
Finished front caliper and put on new tires...
...and waitin' a piston rings from USA!!
'75 cb750F super sport
Offline CycleRanger
  • No comment about being an
« Reply #8157 on: November 06, 2011, 04:16:14 PM »
Looks good Picasoo!
I found a stand to hold my XL250S frame while I installed the tapered bearing races.  :)
I keep a variety of different sized PVC fittings for installing bearings, seals etc.
Handy and cheap!
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #8158 on: November 06, 2011, 05:57:13 PM »
Finally got around to getting my pipes cleaned ;)
Offline Grnrngr
« Reply #8159 on: November 06, 2011, 07:14:17 PM »
Sure improves the flavor don't it?   ;D
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline Dimitri13
  • 1974 CB550K
« Reply #8160 on: November 06, 2011, 09:10:06 PM »
Got the ignition timing DEAD on. It was sooooo out of whack I'm surprised it even ran.
Still need to unscrew my carbs.
Offline Freaky1
« Reply #8161 on: November 07, 2011, 11:25:59 AM »
Last weekend I got the oil passages on the lifters elongated to improve oil flow to the lifter bearings. I also added oil holes to the cam towers like is described in Hondaman's book. I got the pistons back on and put the cylinders in place, only to find out that I missed 4 small gaskets under the cylinders. In my defense, they were not included in my "complete" gasket kit though. Better to figure that stuff out now I guess, so the cylinders will be coming back off as soon as the new gaskets come in. Made the rear fender mold a bit stronger so my giant hands won't break it when I go to make the actual fiberglass fender. Mounted the handle bar controls and the headlight and I think it's all coming together nicely. Yes it was a good weekend of work!
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline thrutheframe
« Reply #8162 on: November 07, 2011, 01:03:13 PM »
  Rode it around a bit with no rotor in the alternator.  Runs great on a fresh battery.  I brought my air mix screws all in 1/2 turn, the throttle is way more linear now :)  I put on some poorly painted black side covers just to see what they look like black.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
« Reply #8163 on: November 07, 2011, 01:10:10 PM »
Loaded Goldie into the back of a truck and waved goodbye, she's off to a new owner in Sydney who fell in love with her and will look after her. As much as I miss her I like the extra room I've got in my garage, and the extra bucks in my bank account so I can rebuild my K1 hotrod engine and continue with the K6 resto. Goodbye Goldie! ;D
Offline scunny
  • don't call me expert
« Reply #8164 on: November 07, 2011, 01:22:34 PM »
Terry, I hope the new owner treats her well. she would look good in anyones garage.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #8165 on: November 07, 2011, 01:30:36 PM »
Ha ha, thanks mate, I'm sure he will, I was lucky that it was p155ing with rain as we loaded it onto the truck, that way the driver didn't notice the tears rolling down my cheeks as I looked at it for the last time..........  :'(
Offline CycleRanger
« Reply #8166 on: November 07, 2011, 01:34:37 PM »
Farewell sweet beauty!   :(
The new owner better treat her right or we'll come down there and kick his butt! >:(
« Reply #8167 on: November 07, 2011, 01:38:11 PM »
Ha ha, thanks mate, I've got his address just in case he doesn't, so I can send the International SOHC4 lynch mob his way! ;D
« Last Edit: November 07, 2011, 01:53:13 PM by Terry in Australia »
Offline Tree
  • CB750K5
« Reply #8168 on: November 07, 2011, 03:55:30 PM »
Replaced my old stock shocks with some new ones from Ikon. :D.   They measure the same length when the bike in on the center stand (13 inches), but the bike feels like it is higher now; they must not compress as much.  Much firmer ride and not as  bouncy.
Offline coma13
  • Lex Talionis
« Reply #8169 on: November 07, 2011, 04:39:27 PM »
rode it to work! hallelujah!
They wail and weep,
The march of the sheep,
As they go to that cross on the wall.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #8170 on: November 07, 2011, 07:06:08 PM »
sheesh, everything came in at once!  new bearings for the hub and carrier, new sprocket.  laced my first wheel tonight, a powder-coated 16in drop center.  will true it up tommorow.  later in the week i'll go argue with the powder-coat guy about the lousy job his guys did on my DID aluminum front rim, while he was hunting in wyoming.  grrrrr............
searching for a dr350se
« Reply #8171 on: November 07, 2011, 07:16:04 PM »
At last, someone actually replacing the craptapulous OEM shocks with a DECENT set of shocks. Not Redwings, not YSS, not Old Bike Barn specials, but REAL shocks that actually work! Well done mate, I don't know you personally, but I know that you are an intelligent man. Enjoy those excellent Aussie shocks! (no bias here, I like Hagons too, but Ikons, with their adjustable damping, are better.............) Cheers, Terry. ;D
Offline CBNJ74
  • Sweep the leg!
« Reply #8172 on: November 08, 2011, 08:34:49 AM »
Replaced the speedo drive, speedo cable and tach cable. The needles seem to be sitting nice and steady now at speed.
1973 Honda CB750K
1983 Honda VF750 Interceptor
2005 Triumph Thruxton
2012 Ducati Monster 1100evo
« Reply #8173 on: November 08, 2011, 08:41:25 AM »
I thought YSS was supposed to be a decent shock? comments?
http://www.yssusa.com/series-g.html
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #8174 on: November 08, 2011, 09:35:44 AM »
everyday I see this thread come up in my "replies" and everyday I think "your mother". Dont know why.
So, now that it is out of my system I will fade out and not post it again.or think it.
YOUR MOTHER!!!
My bike (S90) is in Limbo because a D-bag hasnt shipped me my airfilter yet.
 http://www.apexcycle.com/s90.htm is the D bag- buyer beware!!!!! no nothing
