Author Topic: will these propulsion systems work in space?  (Read 8918 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« on: December 29, 2009, 04:03:15 PM »
a electrically driven squirrel cage fan.
and a vacuum cleaner motor.
« Last Edit: December 29, 2009, 04:36:44 PM by Industrial Cafe »
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: will these propultion systems work in space?
« Reply #1 on: December 29, 2009, 04:08:38 PM »
If they have fluid to push.
In a vacuum like space, nyet.
Offline Soos
« Reply #2 on: December 29, 2009, 04:11:27 PM »
Depends on how many politicians you can force through a BIG version of those motors.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
MötleyRöx
« Reply #3 on: December 29, 2009, 04:19:39 PM »
They will work, but they will not do work.   :)
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: December 29, 2009, 04:31:42 PM »
I wonder why the vacuum of space can't be "pushed"
the blades spin but they wont be creating ANY wind?
  • Like a well oiled
    • Undead Asphalt
« Reply #5 on: December 29, 2009, 04:32:47 PM »
is it because you can't compress the volume going into the intake?
Offline Soos
« Reply #6 on: December 29, 2009, 04:33:13 PM »
I like that answer!
-=≡ Soos ≡=-
Offline Soos
« Reply #7 on: December 29, 2009, 04:34:46 PM »
no "air" in space(in concentrated enough volumes) to compress and propel you....
l8r
-=≡ Soos ≡=-
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #8 on: December 29, 2009, 04:37:19 PM »
It might work if you added a Bussard Ram Jet Magnetic Field to the intake and add an igniter in the chamber.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
  • Like a well oiled
    • Undead Asphalt
Re: will these propulsion systems work in space?
« Reply #9 on: December 29, 2009, 04:37:30 PM »
so what if you put a whale in a space suit? could he swim in space?
  • Like a well oiled
    • Undead Asphalt
« Reply #10 on: December 29, 2009, 04:38:07 PM »
I was thinking along the lines of a solar powered way to move you around in space. even if its slow.
Offline Peterbylt
« Reply #11 on: December 29, 2009, 05:26:52 PM »
Did someone say whales in space?
[youtube=425,350]<object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
MötleyRöx
« Reply #12 on: December 29, 2009, 05:36:21 PM »
I like that answer!
I like IC's question threads... but, I always wonder if it because he has a quest for knowledge or if he's just very clever.
Either way, all of these types of threads have been terribly entertaining.   :)
Offline mystic_1
  • 1970 CB750K
« Reply #13 on: December 29, 2009, 05:40:22 PM »
I like that answer!
+1
Nicely done, MötleyRöx! :)
mystic_1
- John Augustus Shedd
  • Like a well oiled
    • Undead Asphalt
« Reply #14 on: December 29, 2009, 05:44:06 PM »
I like that answer!
;D ;D
« Last Edit: December 29, 2009, 06:09:50 PM by Industrial Cafe »
Markcb750
« Reply #15 on: December 29, 2009, 06:04:00 PM »
Because space is not 100% empty they would produce an itsy bitsy teenie weenie amount of thrust.
I'm talking small, really small, smaller then could be effectively measured.
Here in the vicinity of the Earth the thrust from sunlight and the solar wind would be greater.
Unless you can get the Bussard collector running, but then warp drive is close so why not just use the blowers to cool your field generators.
Offline Gordon
  • 750K1, 550K2
« Reply #16 on: December 29, 2009, 08:15:22 PM »
Mark touched on this, but at least for now, using a solar sail is the only way to use sunlight to power a space vehicle, and last I heard it would take a sail about the size of Texas to propel a small capsule at a decent speed.
That would be pretty kick-ass though! ;D
  • Like a well oiled
    • Undead Asphalt
« Reply #17 on: December 29, 2009, 08:36:01 PM »
so if I mounted a small squirrel cage fan in a vacuum chamber with a feather in front of the outlet nothing would happen?
« Reply #18 on: December 29, 2009, 08:45:09 PM »
So we have found ways to produce and store sufficient amounts of anti-matter to make warp drive possible?
« Reply #19 on: December 29, 2009, 08:49:28 PM »
What if you were able to hang your butt out in space, would a fart propel you?...... ;D
"sits back and eats popcorn.... ;)"
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #20 on: December 29, 2009, 10:47:17 PM »
nope.
No.
Offline BlindJoe
« Reply #21 on: December 29, 2009, 10:50:32 PM »
if you farted in an empty bathtub would you still see bubbles?
« Reply #22 on: December 30, 2009, 12:39:17 AM »
If you were a fonzanoon you would.
Offline Gordon
  • 750K1, 550K2
« Reply #23 on: December 30, 2009, 12:45:27 AM »
If you fart in an empty elevator was it wasted?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #24 on: December 30, 2009, 01:01:27 AM »
Wouldn't the motors rev up past their "purpose built" specs and burn out very quickly with no resistance on them?
