Author Topic: Norwegian cafe.. Oil tank in the swingarm....  (Read 111055 times)
Re: Norwegian cafe.. Oil tank in the swingarm....
« Reply #225 on: November 01, 2010, 03:19:04 AM »
I'm doing a bit of digging for one of those as well. I just started a thread in the SOHC section about removing the oil tank completely...
http://forums.sohc4.net/index.php?topic=79163.msg883817#new
Offline lordmember1969
« Reply #226 on: November 06, 2010, 01:43:46 AM »
Anybody needs new sidecovers?? check this out:):)
http://forums.sohc4.net/index.php?topic=74022.425
Bought a set for my basket case :) ;D
« Last Edit: November 06, 2010, 01:48:16 AM by lordmember1969 »
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline goon 1492
  • Sucka Repellant
Re: Norwegian cafe.. Oil tank in swingarm....
« Reply #227 on: November 06, 2010, 01:19:09 PM »
Is this cool or what:):)??
Made by Frankenstuff:)
Great build! I dig the clear points cover, I am a machinist and heres the one i made for my very slow going build..
« Reply #228 on: November 06, 2010, 03:32:54 PM »
Thank you:) Nice cover:)
« Last Edit: November 20, 2010, 09:59:00 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #229 on: November 11, 2010, 09:42:57 AM »
My Friend welded up the swingarm, did first leaktest and found out it will hold 2 litres of oil :) :) ;D With the extra oilfilter it should be enough :):) So I am pretty pleased :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Syscrush
  • Sold. :(
« Reply #230 on: November 11, 2010, 10:03:48 AM »
Great!
Offline voxonda
« Reply #231 on: November 11, 2010, 02:50:05 PM »
Starts looking good!
Cheers, Rob
« Reply #232 on: November 12, 2010, 10:56:35 AM »
Thank you guys:):) Will post more pictures when I have cleaned it :) With the extra filter it will hold the same volume oil as the stock tank.. But the oil will be located lower.. Do not know if that will affect the oilsystem?? Anybody have experience with lower location of tank?
Thanks :) :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #233 on: November 19, 2010, 09:30:31 PM »
Just read through the whole thread. very cool.
music
« Reply #234 on: November 21, 2010, 01:39:32 AM »
Some pictures of the tank primed, some more sanding and its on its way to the painter :) :)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #235 on: November 21, 2010, 03:33:37 AM »
Thinking of adding a monoshock to my bike,found a website with some very usefull info on motorcycle suspension.. Enjoy :) :)
http://www.carbibles.com/suspension_bible_bikes.html
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #236 on: November 21, 2010, 09:39:46 AM »
Your tank is really nice. I would like to see some more pics of the process if you have them.
and what brakes are you using up front? any other mods you had to do to them?
« Last Edit: November 21, 2010, 09:44:57 AM by Anti-Johnny »
music
« Reply #237 on: November 21, 2010, 09:50:23 AM »
Agreed! That tank is sweet!
« Reply #238 on: November 21, 2010, 03:11:39 PM »
Thank you guys:) The tank started as a cb 500 tank, had a donor 750 tank that i cut out the knee indents from and reversed them end welded it to the 500 tank. Also stretched it a bit using parts from a beetle front bonnet. Had to work a bit on the tunnel to make it wide enough...
Some pictures :) before it is all welded up..
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #239 on: November 21, 2010, 03:20:40 PM »
very nice work. What about the brakes? Seems pretty straight forward.
music
« Reply #240 on: November 21, 2010, 03:26:20 PM »
The front brake is a caliper i bought on eBay for $5,95:)  It came from Kawasaki Z1000 1999, But you can use any superbike caliper if you can make a bracket:) I have not done any modifications to it :):)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline cdoggy81
« Reply #241 on: November 21, 2010, 07:10:31 PM »
subscribed!!!
Offline HedNut
  • Underwater Basket Weaving
« Reply #242 on: November 22, 2010, 06:51:18 AM »
Awesome! Looking good man!
Offline 23tbucket
« Reply #243 on: November 23, 2010, 09:11:32 PM »
Lordmember......Just some inspiration for you when it comes to finishing the Electronic Fuel Injection on your cafe project......
http://s258.photobucket.com/albums/hh280/23tbucket_2007/?action=view&current=001-39.mp4
The microsquirt is completly controlling the fuel injection in this video. The ignition is Power/Arc firing 4 coil-on-plugs in a wasted spark format. This engine has a small 500 cc/ revolution rootes type supercharger. External Densco alternator. I have the same GSXR 600 throttle bodies as you.......but, I had to add an extra 5th. throttle body to the inlet to the supercharger!!!! As you can hear and see the boost from the positive displacement blower pinned the 15 psi gauge at only 4000 rpm, before the engine ran out of gas...lol. The engine was impossible to tune! There was just too much boost and it bent my throttle plates during some high RPM tuning and the engine ran away on me. I removed all the throttle plates and blocked off the shaft openings..so all my GSXR 600 throttle bodies do now is hold the injectors. I built a special intake runner to replace the supercharger inlet filter and put another throttle body on without the injector. I'm just in the process of re-tuning the ECM. I'll post a video on the new Honda CB750 with the "5" throttle bodies later.........
Just a note....A couple of times, I disabled the supercharger boost, and the engine was so sweet to start and ran very, very clean......still snappy throttle responce.....idled as smooth as an old Buick......I almost wished I hadn't put the supercharger on!!!
Are you getting a bit more excited now?????? Ha! ha!
Take care; Clifford
« Reply #244 on: November 24, 2010, 09:05:41 AM »
Take care; Clifford
Thank  you Clifford..
Just what i need is some inspiration:):) Cant seem to get myselves to start the wiring :( All the cables scares me :( :)  But I am almost there.. How was it to program the microsquirt?
Great build you got there :)
Thanks again..
« Last Edit: November 24, 2010, 09:43:51 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline strynboen
« Reply #245 on: November 24, 2010, 11:37:38 AM »
hey norvay..the pics of the generator..i have ..the stator are broken..but it can be fixed
it messing 12#12 cm..its an nippon denso..but used in an racing car,,we are reapering elektric komponents on work
langelands elektro..not shure the elektrnic relæ is working..i will test it if yoy can use it...it are for free..can take it to hønefoss this spring..evt post it there..for the last vay
terry from dovn there have made some nice cover,,his vas for oil filter ,,but it can be thanced to an belt drive for generator..mowed op under caburators..itr vas bolt on hvere the stator vas sitting..replaced for an belt drive,,up to the generator
« Last Edit: November 24, 2010, 11:50:47 AM by strynboen »
i hate all this v-w.... vords
Offline strynboen
« Reply #246 on: November 24, 2010, 12:10:12 PM »
hey terrys idea vas somthing like this,,but better,,generator hvere oli filter are,,and mody for belt drive..insted
« Last Edit: November 24, 2010, 12:19:13 PM by strynboen »
« Reply #247 on: November 24, 2010, 02:03:24 PM »
Thank you:) that sounds like a great idea, its pretty smal so it wort trying out:) I know 23tbucket made some sort of belt drive for a simular generator and compressor so that can be made. PM me and I will pay for shipping :) :)
Thanks again:)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline strynboen
« Reply #248 on: November 25, 2010, 09:02:24 AM »
hey ...i vill test it first..hope to make it working..or have you contakt to an company who can make stators(vikling)
think it have konnektion from an fase to frame..kortsluttet stator vikling..til stel..
« Reply #249 on: November 26, 2010, 02:26:35 AM »
Thanks:) Let me know how it works out?:) Will start working on some kind of beltdrive:)
1977 CB 750 SS Cafe
1971 Mustang Grande
