Author Topic: Bill Hirsch Tank Liner Failure  (Read 1574 times)
Offline Gorms
  • Barkeep! Give me a beer and a
« on: May 14, 2010, 07:12:04 PM »
I was filling up the bike with gas tonight and as I peered inside the tank...disaster.  A large section of the liner had peeled away from the tank.  I couldn't tell if the liner had torn or ruptured or if it remained intact and seperated from the wall.  I rushed home, removed the tank and drained the gas.  Now it appears that the entire side of the tank liner has seperated.  I don't know what to do.  I researched the hell out of which liner to use and took every precaution to apply it correctly to the virgin fiberglass tank.  What do I do?  Forget about it?  Try and pull it out and just use as is?  Tear it out and reline it with the same stuff?  POR-15?
...bummed :-\
Re: Bill Hirsch Tank Liner Failure
« Reply #1 on: May 14, 2010, 07:44:42 PM »
Sounds like you are into stuff that I am not,Fiber tanks and all but when a "film" failure happens like inside your tank I would say it all has to come out somehow.metal is kinda easy,hit it with some strip. But the seal is broken.   RED-KOTE ? Gotta love the color
Offline KB02
« Reply #2 on: May 15, 2010, 05:02:09 AM »
yeah, that's what I would say, too. Strip it all out and coat with redcote (granted, you say you did your homework on which liner to use, and I am assuming you chose not to use redcote for a reason?).
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #3 on: May 15, 2010, 07:54:32 PM »
That's too bad, it is the one Benjie recommends for his tanks.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline Gorms
« Reply #4 on: May 16, 2010, 01:21:24 PM »
Benjie recommends POR-15 but the company told me that it will not stick to fiberglass and I would likely encounter problems.  The Bill Hirsch stuff was the only stuff I am aware of that is designed and recommended for fiberglass tanks.
So if I were to strip it, what would be the best way to avoid damage to the fiberglass as well?
Offline Old Scrambler
« Reply #5 on: May 16, 2010, 04:40:36 PM »
I don't know what material you applied........I do know that Red Kote works for 2 or more years and then should have a re-application of a single coat just to make sure the tank remains sealed.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: May 16, 2010, 04:45:46 PM »
I was told the exact opposite when I called and asked to be transferred to the shop and asked about the fiberglass tank on my Tracy body.  I used POR-15 and it is holding up fine so far?
