Author Topic: WTF!!?? HELP!!  (Read 15343 times)
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
Re: WTF!!?? HELP!!
« Reply #75 on: October 14, 2011, 06:03:55 PM »
this is insane with that oil filter housing bolt....it just doesn't make any sense how its stuck like that.
how can I do this with out  destroying sh!t??
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: WTF!!?? HELP!!
« Reply #76 on: October 14, 2011, 06:29:13 PM »
Maybe some heat is the answer? but not too much ;)
Offline WarwickE36
Re: WTF!!?? HELP!!
« Reply #77 on: October 14, 2011, 06:32:30 PM »
Worst case scenario it breaks... not a huge deal.  Replace it and move on.  Once it breaks the tension should be removed and you should be able to get it out with vice grips or a pipe wrench.  I know it sucks, but waiting for a new bolt isn't the end of the world.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Greggo
  • Somebody's
Re: WTF!!?? HELP!!
« Reply #78 on: October 14, 2011, 06:36:44 PM »
+1 'wick
Offline crazypj
  • I'm brill, me
Re: WTF!!?? HELP!!
« Reply #79 on: October 14, 2011, 06:49:50 PM »
Get a 'six point' 12mm socket, 12 point will round the head off (cheap impact sockets work great)
Tap head of bolt first to re-form it a bit then beat the socket on.
Use a breaker bar as already described and keep beating on the 'head' of the bolt while applying pressure.
 It's very rare this will fail, you keep enough pressure on breaker bar to 'turn' bolt.
 If you apply too much pressure it tends to tilt and round off bolt head
 You won't break case if you beat it too hard but you could possibly crack filter housing (I've heard of it happening but never seen it)
Offline d9canada
Re: WTF!!?? HELP!!
« Reply #80 on: October 14, 2011, 08:08:58 PM »
Good, if it didn't get too hot and good you had some oil, I really don't want doom for you.  As for the impact, if others are talking about hammering on the thing as you use a breaker bar, what's the diff?  Either probably has equal chance of working and unless you go ballistic you probably won't crack the housing.  I like the idea that maybe the rotor and stator have come to grips, there's gotta be some reason why it stuck.  But then, if it was running, sounded like gas starvation, jeez if the stator was grabbing the rotor, you ought to hear it.  Oh well easy to check.  Good luck!
Brian
CB350F to CB900C
GL500
GL1000
CBX
02 Sportster 883
64 Suzuki M15D Sovereign 50cc
Re: WTF!!?? HELP!!
« Reply #81 on: October 14, 2011, 08:24:48 PM »
 Cut the square hole part of the socket off and WELD it to the bolt..
Offline brycegp
WTF!!?? HELP!!
« Reply #82 on: October 14, 2011, 09:53:47 PM »
tell me this thing isn't reverse threaded!!
Re: WTF!!?? HELP!!
« Reply #83 on: October 14, 2011, 10:13:10 PM »
normal thread,,you are trying the correct direction,if the bolt does come out but the hex is damaged you can buzz it down so a larger nut goes over it and have it welded on,these arent wheel nuts,once the cup is against the case and the o ring is snugged it only needs a slight pinch up tighter,you can see on this one at about 11 oclock where i had to use a chisel to nudge this one off once upon a time.
Offline d9canada
Re: WTF!!?? HELP!!
« Reply #84 on: October 15, 2011, 09:02:43 AM »
Looking directly at the nut, you want to turn it counter clockwise?  Are you so upset about things that you're going the wrong way?  If you are going counter clockwise and it won't go, you have to use more force.  A breaker bar is bad for one thing, the force is one sided.  Two guys with a T bar is better or some form of impact.  Do you know someone with an electric impact?
Brian
CB350F to CB900C
GL500
GL1000
CBX
02 Sportster 883
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #85 on: October 15, 2011, 12:06:25 PM »
yes turning it counterclockwise.
I live in LA...I'll be lucky if any of my friends have a utility flash light...let alone an impact wrench..OR a welder to weld on a bolt or socket to the nub that is left after all this struggling.
i've already ordered a new bolt...so destroying it isn't a concern.  I'd rather NOT destroy the housing however.  I'm out of ideas...
Thinking of girding off the end of this bolt to get passed the retainer ring so at least the housing can slide off.  then I'll take a pair of vice grips to turn the bolt...??
Offline Greggo
  • Somebody's
Re: WTF!!?? HELP!!
« Reply #86 on: October 15, 2011, 12:12:22 PM »
Yup, that's why I asked if you had a Dremel earlier ;)
Re: WTF!!?? HELP!!
« Reply #87 on: October 15, 2011, 12:14:32 PM »
Be careful though if you don't want to damage the housing.Grinding and such the head off is going to have to be flush with the housing and risky for damage.Seems hard to believe it won't come off,if its been off before recently.If you have a good bite with a socket,maybe solidly wap the end of your ratchet or pipe you may have slid over for more leverage with a rubber mallet and see if that extra jolt may help.
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #88 on: October 15, 2011, 12:34:52 PM »
done that.
Offline FuZZie
Re: WTF!!?? HELP!!
« Reply #89 on: October 15, 2011, 12:46:56 PM »
Only thing I know will work is a air powered impact gun, maybe you have a garage close by you could mooch a favour?
Offline WarwickE36
Re: WTF!!?? HELP!!
« Reply #90 on: October 15, 2011, 01:06:29 PM »
Just put a 1/2" breaker bar on it, if that wont do it, put a pipe on it.  jack handles are perfect for this.  Break the head off don't grind it off (unless yo have exhausted every other option).  If you round the head, go get a kit from NAPA to remove rounded heads, they bit harder the more you force it.
2004 SV650s
Re: WTF!!?? HELP!!
« Reply #91 on: October 15, 2011, 01:09:41 PM »
Take a socket with you to a muffler,tire or oil change shop,beg a little and see if they can just break it loose with their air impact ratchet,snug it back up a little and change out when you get back. Meet nice people on a Honda and make new friends.
Offline brycegp
WTF!!?? HELP!!
« Reply #92 on: October 15, 2011, 06:30:17 PM »
$50 in tools and 1 minute of work...job done.
at least I can change the oil now.  and maybe get to work on the real issue...
Offline Greggo
  • Somebody's
Re: WTF!!?? HELP!!
« Reply #93 on: October 15, 2011, 09:29:48 PM »
Phew!
Offline FuZZie
Re: WTF!!?? HELP!!
« Reply #94 on: October 16, 2011, 06:46:13 AM »
Looks like a nice strong bar, check that oil and filter for bits too. ;)
Offline grasscutter
  • Love the CB650.
Re: WTF!!?? HELP!!
« Reply #95 on: October 16, 2011, 07:06:23 AM »
Just read through entire thread.  This is the 1st time you've ever changed oil in this bike?
Come on!  We're burning daylight!
Offline d9canada
Re: WTF!!?? HELP!!
« Reply #96 on: October 16, 2011, 07:54:25 AM »
I agree, that poor bike probably hasn't seen a new oil filter in years :(.
But I'm glad you got it and now hopefully you'll get the thing finished up.  And you can tell the buyer "oil and filter just changed!"  ;D
Brian
CB350F to CB900C
GL500
GL1000
CBX
02 Sportster 883
Offline brycegp
Re: WTF!!?? HELP!!
« Reply #97 on: October 16, 2011, 08:10:17 AM »
Geez, guys...   I've put 6000 miles on this bike in 3 years and change the oil (AND FILTER) every 1500.  In fact...this marks the 6th time I've changed the oil on this bike in that time.
Im not baffled cuz I'm an idiot.   I'm baffled cuz there is no reason this thing should be stuck...cuz I put it on last and didn't put it on that tight.
And when I sell a vehicle, I would always give it to them with fresh oil...and address anything else that needs immediate attention.  I would never let someone take possession of this bike without fixing anything I felt needed immediate attention.  The guy only came to see the bike...he wasn't going to ride it home.
EDIT: There are no metal shavings in the oil.  And (just so you know) the filter was not decayed in anyway.  Not that I expected it to be...
« Last Edit: October 16, 2011, 09:13:55 AM by brycegp »
Offline crazypj
  • I'm brill, me
Re: WTF!!?? HELP!!
« Reply #98 on: October 16, 2011, 09:08:55 AM »
Put some anti-seize under bolt head .
 It's possible to get some corrosion between head and the 'O' ring.
 It's not much area but can make life difficult
Offline brycegp
WTF!!?? HELP!!
« Reply #99 on: October 16, 2011, 10:39:17 AM »
thx!  I'll do that...
anyone have a link to a good "how to" for valve adjustment and timing on this bike.  I searched and there is no concise step by step explanation in the FAQ.
