Author Topic: CB500T Cafe ...."twisted love"  (Read 17210 times)
Offline the technological J
  • deliciouso!
Re: CB500T Cafe ...."twisted love"
« Reply #50 on: January 06, 2012, 08:17:44 AM »
top of the page ma!
what are  you thinking for the tail lights and that area? fab some fresh shapes outta some old tail light lenses maybe?  it might look kinda sweet with a rack on the back if you match it to the fender.... you how women like to carry things... like purses
94 ST1100..Gone
72 750 K2 Stay tuned!
« Reply #51 on: January 06, 2012, 08:58:29 AM »
  :P Pshh..i ain't puttin no farkin rack on a cafe !!!!
the rear signals are gonna be as tiny as i can find them , the tail light will be on the fender, and the plate will be side mounted ..
  ...and no front signals
Offline four_shot
    • For the Cherokee lover in you.
« Reply #52 on: January 06, 2012, 09:13:27 PM »
Are you gonna vent the front drum like the others?
Will it hold up to the 500's weight while braking?
I wouldn't think the weight would be much different, but there's probably a big difference in performance compared to a disc.
Oh, I agree, the guages do stand a little too tall.
in memory of Dave "Gonzo" Steele
« Reply #53 on: January 06, 2012, 09:30:17 PM »
gonna vent this one too ,
 it's more for looks than performance , the disc would be better of coarse performance wise
« Reply #54 on: January 08, 2012, 07:17:10 AM »
i like looking at the polished stuff right next to unpolished stuff (outter hub vs inner hub) ..for a nice before and after .. that hub was so god damn crusty i didn't polish as deep as i could have, i was getting really sick of wet sanding it
so originally this pattern had a lot more symmetry to it , but a few holes got outta line (from the drill bit walking) .. and that threw off the whole pattern ... so i just "swiss cheesed" it  .... haven't decided if i'm gonna replace it and try again , or just rock it like that .... it doesn't look bad, just not the plan, ya know
« Reply #55 on: January 08, 2012, 07:23:16 AM »
i just remembered, i can do a real before and after  ;D ;D
Offline luke000
« Reply #56 on: January 08, 2012, 07:40:55 AM »
Man this is a bada$$ build.  I like the twisted square stock. So much I am copying your kickstand and making a taillight bracket for my build right now (I hope ya don't mind) and some more parts latter :D
Anything free is worth saving up for.
1974 Honda CB550
1982 Yamaha Virago 750
'74 CB550 Cafe Build
« Reply #57 on: January 08, 2012, 07:46:02 AM »
i don't mind man , if i did , i wouldn't be posting it here  ;)
« Reply #58 on: January 08, 2012, 11:02:24 AM »
so i ended up having to scrap the old mount and start over ... well worth it i think
i've got something special in mind for the headlight mounting , but it should sit right about there when done
and finally , my stupid question for the day ... how the hell am i suppose to get that break cable off
.... i mean i'm not retarded ... what the #$%* is the trick i CANT figure it out , and i'm about to just cut it off
Offline Cheffish
« Reply #59 on: January 08, 2012, 12:10:49 PM »
I have no idea about that brake cable, but I wouldn't cut it. I bet it's really pricey. It looks like it has to come outta that slit in the brake panel. Did you loosen it all the way at the lever. And also the two nuts by the brake panel? Or it should slide in/out where the spring is on the bottom. Or maybe just cut it off ???
Offline lucky
« Reply #60 on: January 08, 2012, 12:13:21 PM »
I hope you got full penetration on those handlebar welds.
I like your work that you are doing.
Offline lucky
« Reply #61 on: January 08, 2012, 12:15:17 PM »
Be careful about grinding or sanding structural welds. The raised profile area of a weld has a lot to do with its strength.
Offline Really?
« Reply #62 on: January 08, 2012, 01:47:18 PM »
Step back and look at it again.  :)
Drop the wheel off of the forks.  Once you have both of the brake arms off, me thinkin' you can create enough slack in the cable to get the cable out.  Somehow that cable has to slide through that slit.
Hopefully I am seeing what you are talking about.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
  • deliciouso!
« Reply #63 on: January 08, 2012, 04:19:29 PM »
I was thinking something almost hidden behind the tail light but strong enough to hold a small bag...... I'll see if I can draw up what I mean
94 ST1100..Gone
« Reply #64 on: January 08, 2012, 06:37:54 PM »
don't worry brother it's all good , this ain't my first rodeo , i just took a tiny bit off of the crown, and will fill the rest with putty
and the handlebars are structural grade tubing , 1/4" thick , i could get 50% penetration and they would still be strong enough to jack up my pick up truck... let alone withstand the forces of being handlebars , thanx tho
        ....and no they are just tacked together , haven't done the finish welds yet  ;)
« Last Edit: January 08, 2012, 06:44:31 PM by Spikeybike »
  • deliciouso!
« Reply #65 on: January 08, 2012, 09:34:30 PM »
heres what i randomly thought might work  the white is the fender and the black is the "rack"
 i was just thinking right before stumbling across this thread we work in metal so much why not shape some plastic to be custom also
94 ST1100..Gone
« Reply #66 on: January 10, 2012, 03:30:00 PM »
just couple little goodies today
mmmmmmmm. naked forks
« Last Edit: January 10, 2012, 03:32:25 PM by Spikeybike »
Offline dergs713
« Reply #67 on: January 10, 2012, 03:37:20 PM »
Damn dude thats gnarly, wish ya lived on my block, I could use another set of hands that had talent like that.
Matt
Offline Really?
« Reply #68 on: January 10, 2012, 03:47:54 PM »
Matt
Frack that, he needs to move to DFW!
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #69 on: January 10, 2012, 05:02:15 PM »
WOW spikey...or twisty...Great details.
Offline Really?
« Reply #70 on: January 10, 2012, 05:15:03 PM »
Matt
And bring Joe with you!
  • deliciouso!
« Reply #71 on: January 10, 2012, 10:57:39 PM »
Dude how much to make me some fork ears like that?
94 ST1100..Gone
Offline four_shot
« Reply #72 on: January 11, 2012, 10:16:58 PM »
All that twisted stock must mean your slow @work. ;D
You should get it all chromed.
Offline Charliedontsurf
« Reply #73 on: January 11, 2012, 10:35:08 PM »
Thats awesome work! Definately keeping an eye on this one
Sent from my DROID X2 using Tapatalk
« Reply #74 on: January 13, 2012, 09:08:14 AM »
if your serious , 100 bucks (i know it sounds ridiculous but there's a lot of work in it)
not really slow at work , i do most of it on break ...and i'm very sneaky  ;D  i've been workin on it for about two weeks, here and there bringin it back and forth from work to home , .... i think my next big tool purchase is gonna be a torch , then i can do it all at home .
i would love to get it all chromed , but that would probly break the bank
« Last Edit: January 13, 2012, 10:06:53 AM by Spikeybike »
