Author Topic: CB 750 K1 GT New Pics with a new look  (Read 157194 times)
Offline tweakin
  • tear down
Re: Tweakin's Turd..(K1)
« Reply #300 on: February 13, 2014, 08:22:57 PM »
Man, I ask for advice and I get a half for and half against...  A ton of help you guys are, ha ha.  The plan is to get some tank trim and try it out, only then will I know.  If I do go with the trim it will be the KO style without the black lines.
All I can say is that maybe Tige will be merciful and take three days to complete this beauty or he's going to blow us away in BOTM!  Take your time, buddy!!  ;)
If not this month, then next ;)...Larry
You guys are funny.  Actually both my other SOHC builds (915 and 78F restomod) were nominated for BOTM and I declined.  Not because I am an A$$, but because I really just build for myself to enjoy and share updates on this wonderful forum, not really into the entire voting thing.  Maybe the turd will be different, but not sure.
The GT version (Golden Turd) is looking very nice... When do you expect to roll it out into daylight. I wouldn't say sunlight given the PacNW winters that are typical, but I have been in Seattle in January before and seen the sun...
David
David, I never really put a deadline on my builds but the GT "Golden Turd" will be ready for some sun in the coming months.  And yes we do get some sun up here and you need to enjoy the orange orb when it decides to make an appearance.
« Last Edit: February 13, 2014, 08:27:38 PM by tweakin »
Offline cheftuskey121
  • Super Newbie
« Reply #301 on: February 13, 2014, 08:34:09 PM »
Personally Tige I'm for the tank trim with no line. I feel like it completes the look and makes the tank look bigger. It also gives the eye a line to look at in contrast to the beautiful color on the tank. Helps draw the eye to the tank because it has a definitive bottom. My 2 cents. Looks beautiful all around man.
« Reply #302 on: February 13, 2014, 10:18:01 PM »
I think it has a clean look without the trim but I'd like to compare since I'm a F'r guy.....never paid attention to K trim I guess. Is that something you can do without actually attaching it/scratching the paint???? Just don't detract from that gorgeous tank.
About time you quit teasin us and finally put the gold on!!
Offline tweakin
  • tear down
« Reply #303 on: February 14, 2014, 06:40:21 AM »
I ordered some trim to try out, we will see. I will install it loosely to get an idea of the look then decide.
Hope to get most the electrical completed this weekend.  Other than that my wax board list of "to do's" is shrinking.
Offline David B
« Reply #304 on: February 14, 2014, 02:31:30 PM »
+1 for the trim.  Chef said it very well.
By the way, what kind of wheel chock do you have on your lift?  It looks like the Harbor Freight or Northern Tool ones.  How do you like it?
DB
« Reply #305 on: February 14, 2014, 03:03:03 PM »
There's nothing like a "definitive bottom" Chef.... 8) ;)
« Reply #306 on: February 14, 2014, 03:07:00 PM »
Infinity edge?!
« Reply #307 on: February 14, 2014, 03:15:12 PM »
Infinity edge?!
Nice ass.... 8)
  • Super Newbie
« Reply #308 on: February 14, 2014, 05:42:33 PM »
Retro is on to me. I love a definitive bottom. Makes me weak in the knees.
Offline tweakin
  • tear down
« Reply #309 on: February 15, 2014, 09:23:00 PM »
Yes the wheel chock is the cheap Harbor Freight one and it works great for the lift.
Offline tweakin
  • tear down
« Reply #310 on: February 17, 2014, 04:45:37 PM »
Most of my wiring has been completed  ::) and getting closer and closer to initial fire up.  If I didn't already state this, I HATE WIRING.
I am having a major brain fart on what the two extra wires from the (+) on the battery connect to, and the green female off the wire harness.  (pic attached)
« Reply #311 on: February 17, 2014, 05:27:52 PM »
Extremely tidy wiring!
  • Super Newbie
« Reply #312 on: February 17, 2014, 09:44:14 PM »
Tige that green should be extra. if you use a modern flasher relay you can plug it into that. I use that ground to connect to my pamco unit near the coils though. works great for that. other wise it just hangs out.
Offline brandEn
« Reply #313 on: February 17, 2014, 10:49:09 PM »
That green ground wire is extra and is used on 3 prong flasher. I believe the red wire from the battery/solenoid is the main power wire for the harness....
Offline tweakin
  • tear down
« Reply #314 on: February 18, 2014, 06:04:30 AM »
Thanks fellas, thats what I thought, should have the wiring wrapped up today.
Offline edwardmorris
  • Youngish
« Reply #315 on: February 18, 2014, 12:35:22 PM »
Is that a new harness or did you redo the connectors? Looks very nice!
Offline brandEn
« Reply #316 on: February 18, 2014, 01:42:18 PM »
I was just looking at the K1 wiring diagram and it shows only one 15A fuse for the whole harness. What harness did you end up using? I see you have more than one fuse there.
Offline Davez134
« Reply #317 on: February 18, 2014, 05:34:27 PM »
Could be just extra fuses in a case? I have similar on my K2. Could be wrong, as I'm viewing on my phone...
BTW every time I see this bike I want to buy another just so I can have that color. Awesome!
« Last Edit: February 18, 2014, 05:36:12 PM by Davez134 »
Offline tweakin
  • tear down
« Reply #318 on: February 18, 2014, 06:40:59 PM »
Thanks Ed, its a new harness from cb750supply.com
B, the harness is for a K3.  I do usually put extra fuses in the blank section of my fuse box though.
  • Super Newbie
« Reply #319 on: February 18, 2014, 06:48:47 PM »
is that one you had lying around or what? just curious why you didn't go with a K1 harness?
Offline tweakin
  • tear down
« Reply #320 on: February 18, 2014, 06:55:55 PM »
I went with the K3 harness because the bike is a blend of K3 and K1 running parts with modern controls.  I also like the idea of having extra fuses in the harness rather than the one 15 amp of the KO?K1 harness.
Offline tweakin
  • tear down
« Reply #321 on: February 25, 2014, 05:45:44 PM »
Work and my daughters select soccer schedule has been limiting my shop time.  the bike is ready to fire just need a few good hours to tidy up a few bits before I do so.
On another note, my Cafepress.com package showed up today...
http://www.cafepress.com/sohc4
« Reply #322 on: February 25, 2014, 06:49:28 PM »
Looks good, but something is missing in the glass!
Offline tweakin
  • tear down
« Reply #323 on: February 26, 2014, 07:31:58 AM »
Don't worry Steve-O, it will get plenty of use.  ;)
Offline tweakin
  • tear down
Re: Tweakin's Turd..(K1) FINISHED (Video)
« Reply #324 on: February 27, 2014, 05:07:19 PM »
Initial fire up this afternoon and all went great.  Fired right up, idled well and had excellent throttle response.   Only a few minor tweaks and the turd is flushed!
initial start up video...
1971 cb750 K1 JDM
« Last Edit: February 27, 2014, 05:09:36 PM by tweakin »
