Author Topic: THAT MOMENT, when...  (Read 17085 times)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« on: May 27, 2015, 08:11:51 PM »
New thread, could be fun, share your follies here. I'll go first, and in truth I could fill this thread singlehandedly.
That moment, when you're just about to start reassembling the carbs you have been slaving over cleaning, when you're sorting through the newly plated parts and see...
The rusty choke shaft you neglected to send with the rest of it, sitting innocently on the tray with the non-ferrous parts.
It was a good reason to get the mini plating setup dusted off, and it will be handy when I need onesies plated anyway.
Who's next?
I have a motorcycle problem.
Online seanbarney41
Re: THAT MOMENT, when...
« Reply #1 on: May 27, 2015, 08:13:53 PM »
pretty much everytime I try to use a computer
« Reply #2 on: May 28, 2015, 03:54:20 AM »
That moment when you weld a bracket on a muffler and realize  you have the seam up:
« Reply #3 on: May 28, 2015, 03:55:06 AM »
That moment when you cut the chain too short and have to be creative:
I can do brain farts with the best of you  ;D
Offline Bailgang
  • Scott
  • Indiana
« Reply #4 on: May 28, 2015, 05:28:30 AM »
Them moment you solder 2 wires together then realize you forgot to put any heat shrink tubing on beforehand.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline demon78
  • After work to the "Wets"
« Reply #5 on: May 28, 2015, 06:10:56 AM »
Always with the wires.
Bill the demon.
« Reply #6 on: May 28, 2015, 07:30:14 AM »
Took my old rusty 4:4 exhausts off my K8 and put on a 4:1 Kerker
Rode one day out to tlbranth's place to hand off GZ....he saw my center stand was riding on my chain   :o
*facepalm*
« Last Edit: May 28, 2015, 07:32:03 AM by flybox1 »
Offline iamandrewx
    • Facebook
« Reply #7 on: May 28, 2015, 02:06:06 PM »
*as a first time motorcycle owner, rider, "builder"*
That moment you realize that the "cheap" project your got is going to cost well over the original bike you wanted... haha
Oscar, the '78 Build
'78 Honda CB550K | '07 Honda Civic Si
ken65
« Reply #8 on: May 28, 2015, 05:38:48 PM »
Leaving finger prints on should be dry now  paint.
« Reply #9 on: May 28, 2015, 07:14:02 PM »
The moment you order a replacement part that you know you had, and then find it.
« Reply #10 on: May 28, 2015, 07:40:45 PM »
Oh God! Yes, that sucks!!
« Reply #11 on: May 28, 2015, 09:55:05 PM »
You buy the Eastwood high dollar inside the header paint, spray the inside the first one of your new 4/4 set. Then you turn it to look in the end. The moment you realize you just poured silver paint all over your shoes and the floor. And pants. And cell phone case. And bike stand.
 Boy does it spray out of that hose!
« Reply #12 on: May 29, 2015, 04:10:39 AM »
  That moment you pull out into traffic and when the bike starts to die realize you forgot to turn the petcock on    :P
« Reply #13 on: May 29, 2015, 04:27:17 AM »
 ;D  are you following me or something?  ;D
Offline 74cb750
« Reply #14 on: May 29, 2015, 04:43:35 AM »
The moment you realize your helmet is going back and forth, not because of the buffeting wind...
but because it is a new signal from the passanger indicating speed has gotten uncomfortable for her.  8)
Laugh at least once a day.
Life  $ucks, then you die.
Offline MikeZ
« Reply #15 on: May 29, 2015, 04:59:06 AM »
The signal I receive for this "issue" is a punch to my ribs.
Offline madScientist
« Reply #16 on: May 29, 2015, 05:35:43 AM »
When you're trying to kick start your bike for 10 minutes and THEN you notice the kill switch is set to 'OFF'.
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline 74cb750
« Reply #17 on: May 29, 2015, 06:16:30 AM »
Oh man! I did not think anyone would actually admit to that.
« Reply #18 on: May 29, 2015, 07:24:13 AM »
...that moment when you realize you'll have to move the total contents of your garage into the driveway just to find the valve spring retainer that just launched.
(yes, and it was found ::)  )
Offline demon78
« Reply #19 on: May 29, 2015, 08:37:11 AM »
This is going back, the moment when some thing goes past your body and head at close to the sound barrier and you remember yes it is a Triumph spring hub followed by the moment of relief when you find you don't have any new holes followed by the oh #$%* moment when where are all those springs crosses your feeble mind.
Only once never ever ever again.
Bill the demon.
Offline NobleHops
« Reply #20 on: May 29, 2015, 08:38:19 AM »
That moment, when you hear that change of pitch as you drive the lower steering head bearing onto the stem, glance over and see the spacer on the bench, which you shortly learn must be installed beneath that bearing.
Offline demon78
« Reply #21 on: May 29, 2015, 08:49:28 AM »
Another one going back when after the modification is just about done to the 18 cyl radial engine when you realize that yes you've got all the cylinder hold down nuts but you are missing one, one of the PAL nuts (all same as lock nuts) and some one said I thought I heard something go tinkle. Yes of course they need the A/C  P.D.Q. (russian trawler, chinese sub, something mysterious in the water, ufo, etc)
Bill the demon.
« Reply #22 on: May 29, 2015, 09:10:49 AM »
I spent more than a few minutes trying to start my bike only to find out that someone did the "courtesy" of setting the kill switch to off (probably just to eff with me).  :o
« Reply #23 on: May 29, 2015, 10:40:48 AM »
Or rebuilding an engine, start it up and have oil coming out from between the cylinders and head...and THEN you noticed the lone oil seal sitting on the bench.
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #24 on: May 29, 2015, 03:41:57 PM »
That moment, knowing that eyes are upon you, when you coolly throw your leg over the saddle McQueen style, tip a wink to your admirers as you nonchalantly press the starter and give a blip on the throttle as it roars into life, snick it into first, release the clutch while still playing to the assembled crowd, and falling sideways with the bike between your legs, realising you forgot to remove your disc lock. :-[
Not one of my best moments ;D
Build threads:
1977 CB750 F2
1958 Norton Model 99
