Author Topic: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine  (Read 137525 times)
Offline river
Re: The Hot Mess - 1975 CB550F1 Frame/1981 CB650 Engine
« Reply #625 on: June 15, 2019, 05:19:44 PM »
Bout time! Good to see you were actually getting some work done while I was sweating buckets in AZ the last week. I know you have a lot of stuff going on but this is one that I would really like to see done.
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
Offline Sigmund
« Reply #626 on: June 15, 2019, 06:39:39 PM »
You can get an offset sprocket kit for the front and rear sprockets. Cognitomoto has them.
Is that what you're using?
I have the front from Cognito, and a 78' CB750 rear hub that's 10mm wider. I prob won't use them with a 3.5 rim and 130 or 140 tyre. (Tire)
CB450t, CB650, CB750 dohc, CB900 dohc.
Music, Motorbikes, Technology and Creativity.
http://forums.sohc4.net/index.php/topic,177987.0.html
Offline river
« Reply #627 on: July 09, 2020, 08:47:08 PM »
Cough. There's a healthy amount of dust up in here. What's up Daddy Don?
ml
Squirrel 2.0
Squirrel 3.0
« Reply #628 on: July 09, 2020, 11:37:02 PM »
Sorry guys. I’ve been snoozing on this one. Been busy having an affair with my MV Augusta Brutale 800RR Dragster.
Also been piecing together a learner track bike for my buddy’s son.
And lusting after a Ducati 748 track bike.
I will get back to the Hot Mess. I promise.
Offline Blackfin5
« Reply #629 on: July 10, 2020, 02:03:32 PM »
How can you not have a love affair with a sexy Italian, Don.  I hope she isn't the  jealous type.  Very nice...
« Reply #630 on: July 10, 2020, 02:57:26 PM »
Did you take the 748 out ? Does she have sweet moves ?!!  :)
« Reply #631 on: July 10, 2020, 03:22:59 PM »
The 748 needs some TLC.  It presently has a strange glitch under hard load between 5K and 6K RPMs where the power cuts out and then snaps back on.  I was giving it a test ride and it did this powering out of a turn, causing the rear to break free and start coming around.  This needs to be addressed likely by tuning or it could cause a brutal high-side.  The bike pulls surprisingly well for a 748cc bike though and its extremely well-planted.  It does not have a slipper clutch, TC or ABS -- very analog and grunty.  I was hoping to take it out at Big Willow (Willow Springs Raceway tomorrow) but not with this current issue.
« Reply #632 on: September 21, 2021, 11:46:29 AM »
Don,do you still own the 'Hot Mess' ?
« Reply #633 on: September 21, 2021, 12:16:21 PM »
Yes, I do. She's been on the back burner for a long time. I decided to complicate things by converting the chassis to a mono-shock set up.
Offline Godffery
  • Godffery's Garage
« Reply #634 on: September 21, 2021, 04:05:17 PM »
Got Pix...?
« Reply #635 on: September 21, 2021, 06:40:03 PM »
Got Pix...?
Yes, in a way.
Here's the chassis in its present state: de-tabbed, with a CMR boxed chromoly swingarm.
image_zpsbghlukp2 by Donald Leonhardt, on Flickr
image_zpsc1lyzdlr by Donald Leonhardt, on Flickr
The bike will have a 2013 GSX-R600 Front End with a Cognitomoto triple:
image_zpsjpiysiex by Donald Leonhardt, on Flickr
The mono-shock and new frame geometry will be adapted from my friend Bryan aka Blacbikes' 550 mono-shock build - with the suspension jointly developed with Matt Wiley at Racetech
Untitled by Donald Leonhardt, on Flickr
« Last Edit: September 21, 2021, 08:01:49 PM by SOHC4 Cafe Racer Fan »
« Reply #636 on: September 21, 2021, 07:35:27 PM »
That's going to turn-out nice Don,I look forward to the build.  8)
« Reply #637 on: September 21, 2021, 08:16:19 PM »
Thanks!
Offline Godffery
  • Godffery's Garage
« Reply #639 on: September 22, 2021, 05:36:29 PM »
The Hot Mess would be welcome to live in my garage on loan anytime...
Hahaha
Offline DaveBarbier
« Reply #640 on: September 28, 2021, 11:47:58 PM »
Don, looking great! Finally back on the hot mess, I’m excited!
