Author Topic: K7 engine in a K2 Frame?  (Read 1031 times)
Offline rocs
« on: November 20, 2016, 08:45:23 AM »
Hey guys,
So i had an issue with the k2 engine and had a k7 laying around. I thought this would be a simple swap but starting to run into issues with the sprocket etc. Anyone successfully complete this swap? Anything i can take off of the K2 to make this easier?
1975 CB550k's
Offline Swoop
Re: K7 engine in a K2 Frame?
« Reply #1 on: November 20, 2016, 11:31:42 AM »
You will need a K7/K8 sprocket carrier for the rear wheel.
Offline jamesw
« Reply #2 on: November 20, 2016, 03:44:51 PM »
Also the chain is different.
K2 uses 530....k7 uses 630.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: November 20, 2016, 03:49:58 PM »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: November 20, 2016, 06:05:29 PM »
or a 10mm offset rear sprocket from Cyclex will save you having to mess around with the axle spacers too
