Author Topic: CB 550/650 Daily  (Read 48649 times)
Offline Camrector
Re: CB 550/650 Daily
« Reply #50 on: May 18, 2017, 06:51:20 AM »
It's a 76k frame. Haven't mocked anything up yet so we will see how the fitment goes. No center stand will be used, and the kick stand can always be moved. Once this head arrives we will make quick work of this thing!
Offline Camrector
« Reply #51 on: June 06, 2017, 04:21:28 PM »
Head is here!!! Modified valve cover and degree wheel in transit from Dave. Wrapping this motor up this weekend!
« Reply #52 on: June 06, 2017, 07:59:36 PM »
Cam,
Are you sticking with the Lesters for this build OR are you going to incorporate the disc rear hub from Devin/Cognitomoto OR a disc Lester?
Offline Tews19
  • I am no
« Reply #53 on: June 06, 2017, 08:16:47 PM »
Subscribed!
1970 Honda CB750 survivor.
Offline Camrector
« Reply #54 on: June 06, 2017, 08:44:57 PM »
Lester's for this build Don.
I'm using these wheels on my "592" build
Just had Nils help me Powdercoat them gold
 Not sure what I'm doing with the Cognito Disc hub. Probably sell it
« Reply #55 on: June 06, 2017, 11:51:08 PM »
Those are pretty snowflakes. The Lesters you have slated for this build are nice too.
A bit of a shame to not use the Cognito rear hub. Maybe re-lace your lady's rear wheel?
Offline DaveBarbier
« Reply #56 on: June 07, 2017, 04:41:06 AM »
Nice dude! Hope you dial this in nicely! After loctiting and torquing the cam gear and my final button up of the rock cover I rechecked my degree and I had a 1/16th of a degree difference in intake and exhaust lobe centers 104.75° vs 104.8125°. With my degree wheel use a long breaker bar to spin the motor. It'll get you a very smooth action and you can be very accurate.
Offline Camrector
« Reply #57 on: June 07, 2017, 07:05:39 AM »
Don that's a great idea! Didn't even think about that!! Thank you.
Great news Dave thank you for the tips!! This is  info I have for the cam from the Yoshi catalog
TT Special YH600-122-00    int opens 27°BTDC  int closes 57°ABDC  lift 9.00mm
                                      exh opens 56°BBDC  exh closes 27°ATDC  lift 8.55mm
Offline DaveBarbier
« Reply #58 on: June 07, 2017, 10:46:43 AM »
That's it? No duration or lobe separation? How about valve lash? I'd ask Bwaller or another one of the high performance guys if this is enough info to degree with. I've only degreed twice, so I'm still wet behind the ears.
Offline Camrector
« Reply #59 on: June 07, 2017, 01:07:21 PM »
Yup that's it man. Cant find anything else on the Yoshi cam.
Im going to use megacycles numbers for the 126-20 to fill in any gaps I have.
« Last Edit: June 07, 2017, 01:14:53 PM by Camrector »
Offline CBGhia
« Reply #60 on: June 07, 2017, 01:18:57 PM »
What ignition are you going to run?
« Reply #61 on: June 07, 2017, 01:25:15 PM »
Let me know if you are going to run CDI boxes and need new units.  I have 2 CDI boxes from Rick's Electronics.
Offline Camrector
« Reply #62 on: June 07, 2017, 01:27:50 PM »
I have the C5 ignition all ready to go.
Offline DaveBarbier
« Reply #63 on: June 07, 2017, 01:38:59 PM »
The internet is known for it's lies, but I found this on a Suzuki GS forum:
Yoshimura Isle Of Man cam specs:
Int .354" 264° @ .040"
Exh .337" 263° @ .040"
Int open 27°btc/close 57°abc
Exh open 56° bbc/27°atc
.004" running clearance (.006" race)
Must use Yoshimura valve springs
Durat In o/c Run-
Valve ion Lobe Ex o/c ning
Cam Lift @.04" center btc/abc clrnc
inches degr degr Description and Application bbc/atc inches
Isle Of Man Race .354 264 27/57 .004
.337 56/27 .004
For racing applications, add .002" clearance
From a CB forum post:
Isle of man cam specs
In opens 27BTDC
closes 57ABDC
lift 9.00mm
Ex opens 56BBDC
closes 27ATDC
lift 8.55mm
yoshi part# YH600-122-00
Valve clearance street-0.10mm race-0.15mm
ign timing +5 advance
http://www.thegsresources.com/_forum/showthread.php?239452-Yoshimura-GS750-1000-2V-Cam-specs-catalog
I don't see lobe separation angle, but duration is there.
Hope this helps
Offline Camrector
« Reply #64 on: June 07, 2017, 01:55:37 PM »
Wow thanks again Dave!
Btw cover and degree arrived safe and sound.
This is the biggest degree wheel I've ever seen lol. It's Huge!!!
« Reply #65 on: June 07, 2017, 02:10:24 PM »
I ended up going with the C5 ignition, as well. I wasn't sure if you were sticking with the CDI's but figured I'd offer them up if you wanted new ones.  Good choice!
Offline Camrector
« Reply #66 on: June 07, 2017, 02:35:11 PM »
Thanks Don.
Offline DaveBarbier
« Reply #67 on: June 07, 2017, 05:47:31 PM »
Glad it got there safe and sound. Oh, and don't go nuts cranking down the rocker shaft pins. With the removal of metal it'll be weaker. Just snug them up :)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #68 on: June 08, 2017, 04:53:30 AM »
This build gives me wood.
I have a motorcycle problem.
Offline Camrector
« Reply #69 on: June 08, 2017, 05:09:29 AM »
Nils for the last time, in not calling this bike Viagara!
Offline NobleHops
« Reply #70 on: June 08, 2017, 05:54:25 AM »
Dude, c'mon. You know "The moment is right". :-)
Offline DaveBarbier
« Reply #71 on: June 08, 2017, 06:37:37 AM »
If you're riding for more than 4 hours, consult your doctor.
Offline NobleHops
« Reply #72 on: June 08, 2017, 06:57:17 AM »
Do not drink alcohol in excess when riding this motorcycle :-)
Offline Lostboy Steve
« Reply #73 on: June 08, 2017, 06:59:07 AM »
I love those. Absolute love.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #74 on: June 08, 2017, 07:21:48 AM »
Its rather frightening how many "members" seem all too familiar with the conditions surrounding ED  :o Even the young Hipsters in CT  ;D ;D ;D :-X
That ED will go away real quick with the introduction of new tail. Just saying. ;)
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
