The internet is known for it's lies, but I found this on a Suzuki GS forum:
Yoshimura Isle Of Man cam specs:
Int .354" 264° @ .040"
Exh .337" 263° @ .040"
Int open 27°btc/close 57°abc
Exh open 56° bbc/27°atc
.004" running clearance (.006" race)
Must use Yoshimura valve springs
Durat In o/c Run-
Valve ion Lobe Ex o/c ning
Cam Lift @.04" center btc/abc clrnc
inches degr degr Description and Application bbc/atc inches
Isle Of Man Race .354 264 27/57 .004
.337 56/27 .004
For racing applications, add .002" clearance
From a CB forum post:
Isle of man cam specs
In opens 27BTDC
closes 57ABDC
lift 9.00mm
Ex opens 56BBDC
closes 27ATDC
lift 8.55mm
yoshi part# YH600-122-00
Valve clearance street-0.10mm race-0.15mm
ign timing +5 advance
http://www.thegsresources.com/_forum/showthread.php?239452-Yoshimura-GS750-1000-2V-Cam-specs-catalogI don't see lobe separation angle, but duration is there.
Hope this helps
