Author Topic: Marissa's 1972 CB500  (Read 106195 times)
Offline Scott S
Re: Marissa's 1972 CB500
« Reply #75 on: September 22, 2017, 04:22:52 AM »
 In the picture where you say "Gee, now I know why the cable tensioner is busted", I'm not sure I'm following you....
 That looks like the "protector", for lack of a better word, for the drive chain. It looks like someone rode with a really loose chain at some point.
 I'm not sure what tensioner you're referring to.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #76 on: September 24, 2017, 07:22:53 PM »
Yep, the cam chain tensioner is not in its pocket. That will place the tensioner assembly too close to the sprocket, using up all the slack in the chain. Then it cannot be assembled (and good thing!).
« Reply #77 on: September 25, 2017, 03:14:35 AM »
Subscribed. Very interesting build and lots of good info. Good luck Marissa.
Offline rb550four
« Reply #78 on: September 25, 2017, 06:38:07 PM »
 I'd like to be the 4th guy to say that the cam chain tensioner isn't sitting in it's perch, but I'm looking at the primary chain, looks really slack in that picture to me. What do you guys see?   How is it in person Marissa? It would be a shame to go through all this work and miss the opportunity to replace a worn primary chain.
« Reply #79 on: September 25, 2017, 07:33:01 PM »
Untitled by Marissa Simos, on Flickr
Untitled by Marissa Simos, on Flickr presents in my oil pan :)
Yum! Crankcase jelly!
It's good for the skin, though. :)
« Reply #80 on: September 25, 2017, 09:38:18 PM »
Crankcase gravy! Yumm.
Offline Marissa
« Reply #81 on: October 15, 2017, 06:42:15 PM »
A little update!
Yes, I know the tensioner was not in the perch correctly. The main reason I took that picture was because of that damage on the side of the case that looks like at some point the primary chain was hitting that if I had to guess. That's definitely concerning right?
That being said, it did not feel that "slacky" but I'm not sure what amount of tension is supposed to be on it. I think for safe measure I will take the oil pan back off to double check.
I was able to install the cam chain sprocket onto the cam as well after I added an extra set of hands. I believe we first put the chain on the sprocket while the sprocket was resting on the side of the cam, then slowly pried it up onto the cam shaft. We used a lot of picks and small Philips screwdrivers to finesse the chain onto the sprocket (this worked best for us and I'm hoping others who have difficulty initially will find this thread and try it).
We started on the easier side which has the chain guide, not the tensioner. We would pry the chain over onto the sprocket one link at a time, and once we would get it where it needed to be, piece by piece we put a screwdriver at an angle between the sprocket and chain to keep it from trying to sway to the other side. Once we got the next link over the sprocket and parallel, we would put another small screwdriver in the same position as previously, and take the first screwdriver out. So we fed the chain on literally one link at a time, and once we got to the tensioner side, we placed a bigger flat head in laterally on the side of the chain to force it (if you were sitting on the bike, the flat head was placed on the right side of the tensioner, partially on it and also moving the chain at the same time. Once we got it to move the chain as close to the sprocket as it would go, we took a dental pick and moved the chain one link at a time once more. It popped right on once we did that to two links or so.
I have no idea if we made this overly difficult or if people had a much easier time doing this, but regardless we have no issues now with the chain, and it is properly timed. We used blue threadlock as well on the cam bolts as extra insurance that they won't back out. I think I will also use that on the oil pan bolts as well when I'm checking the slack on the primary chain.
Dad lending a hand, he taught me how to work on cars, but he has never worked on a bike before.
Currently, I am waiting on some oil, Honda Moly paste, and cables in the mail. I was told by someone on SOHC4's Facebook page to use the Honda Moly oil on the cam to ensure I don't wear down the seat of the cam. (I'm sure many just use oil liberally, but I want to ensure I'm doing things as best as possible where I can.)
I mocked up the valve cover and a couple of things just to see how it will look. If it runs well and I can get a few runs in this season, I will certainly be doing an extensive cleaning, wax and polish. I clean the bike whenever I'm making progress but there's usually a week or so where I'm waiting on parts/too busy.
Think it looks fairly nice. I purchased the stainless steel bolts from alloyboltz on eBay (Dime City Cycles also sells them) and while most of the components had the perfectly sized bolts, my side cover bolts were quite wrong and I had to switch/piece meal them together because the cb500 kit is supposed to also fit the cb550, and I'm guessing they have slightly different side covers in order to fit the CB550 moreso. Regardless, they are fine if you want a little upgrade.
Found a NOS cylinder stud to replace my broken one as well.
1984 Nissan 300zx - sold
2016 Ford Fiesta ST - daily
1972 Honda CB500 - infinite work in progress
Instagram- marissasimos
Offline Marissa
« Reply #82 on: October 15, 2017, 06:56:50 PM »
Scott, to answer your question on the clutch cable tensioner thing (have no idea what it could be called) The part that engages the end of the clutch cable, which connects to the spring in the bottom of the side cover housing, it houses a steel ball and rotates when the cable is being engaged. If you look closely in the photo, a big chunk of it is missing from impact of the drive chain either busting or getting loose. I'm going to assume it will need replacing once the bike is road worthy.
Offline DaveBarbier
« Reply #83 on: October 16, 2017, 04:35:04 AM »
Looking good Marissa. I use assembly lube which I doubt contains any molybdenum. Some use regular oil, but I believe my 650 manual specifically calls for moly paste on the cam.
As for the picture of the cam, I'm sure it's just of you guys messing with the chain, but the notch is 90° off from where it's supposed to be. Assuming you cylinders 1/4 are at TDC. Just making sure you got that installed correctly. Notch at 3 o'clock, cylinders 1/4 at TDC. You're thorough so I'm sure it's done right.
Lastly, I wouldn't bother using loctite on the oil pan bolts. But if you're replacing those screws with stainless Allen heads, use antiseize.
Offline Marissa
« Reply #84 on: October 23, 2017, 06:56:12 PM »
Found a nice surprise on my spark advance... Anyone got one laying around for a 72 CB500?? Please :(
Also, noted on that last part Dave.
« Reply #85 on: October 23, 2017, 09:38:08 PM »
Turning the crank too quick with a machine, maybe with spark plugs in too.
I never cracked mine on my CB750 when turning around the crank with plugs in with a 23mm wrench.
You need an advancer marked 323. Maybe 300 (CB750) will work too?
https://www.ebay.com/itm/Honda-CB500-Four-CB550-F-K-71-78-Zundversteller-spark-advancer-Fliehkraftregler-/152730270619?hash=item238f6efb9b:g:EksAAOSw4QVZ1b5n&vxp=mtr
NOS
https://www.ebay.com/itm/GENUINE-Honda-NOS-30220-323-154-ADVANCER-SPARK-/232480414995?epid=1411800417&hash=item3620e99d13:g:UfoAAOSw8a1ZsVgw&vxp=mtr
Offline DaveBarbier
« Reply #86 on: October 24, 2017, 04:28:33 AM »
I assume you've been turning the crank over with a wrench on the big nut. A lot of people do this but many people say it's bad practice. I think even Honda says not to do it. Use the kicker or use the nut on the alternator side. Or, take the plugs out to relieve compression.
I'll take a look at what I have but I don't think I've got one. Bummer!
Wonder if those tabs can be welded back on...? Their placement isn't super critical.
« Reply #87 on: October 24, 2017, 11:30:02 AM »
If it is the shaft the points cam is attached to, think about what a wobble will do to your points opening and closing.
Offline zeffcat
« Reply #88 on: October 27, 2017, 06:46:00 AM »
I went ahead and converted the turn signals to minimal LEDs which are really impressive when on.
[/url]
Dang, those really are impressive! Do you have a link for those? Loving the build so far, you're doing great work!
CB750 K8
« Reply #89 on: October 27, 2017, 07:23:53 PM »
You can weld up new ones on it, and shape them with a file - done it.
On another note:
I should maybe send you some of the 500 Jamberry kits I have, left over from a machine I designed a year ago? It custom-picked and shipped their orders, and they left me with about 1000 of their kits(!), like I'm going to do something with them?
Offline DaveBarbier
« Reply #90 on: October 28, 2017, 06:48:01 AM »
On another note:
I don't know Mark, before you send those off maybe doll yourself up and post a selfie to the Babe Thread.
« Reply #91 on: October 28, 2017, 10:40:18 AM »
What with some companies mining the net for your social media and internet/web presence as part of their candidate evaluation...don't know if I would do something like that....
Yeah, I know it was a joke.
You could make care packages to the ladies of the SOHC4 whom would be interested enough to paypal you a gift of the latest usps small flat rate box for a box of these jamberries.
Offline Marissa
« Reply #92 on: October 29, 2017, 04:07:56 PM »
zeffcat,
Thanks for the kind words! You can get them here: https://www.dimecitycycles.com/morimoto-mc-bar-end-led-pindicators-turn-signal-indicator-lights.html
I chose them because I didn't like the placement of the bar end versions, or the price of them. For $45 a pop, they are so bright when they're on, but once you turn them off, it's really minimal and helps hold that streamlined cafe racer style.
I wish my bike was running so I could tell you how they perform on the road.
Offline Marissa
« Reply #93 on: October 29, 2017, 04:20:06 PM »
A big thanks to Calj for the spark advance. I got the bike all dolled up with a Daytona electronic conversion, which was easier to install than expected, but at the same time, I can't get it to start up for me. I'm going to try to diag this over the course of this week to figure out what is going on, it has to be either fuel related or ignition timing.
Dave, I took off the valve cover and verified the cam notch is pointed at 3 o'clock when 1 & 4 are at TDC.
I switched the plug wires just for ha ha's to see if ignition timing was reversed, nothing happened.
I know that the carbs are getting fuel because unfortunately I have to readjust the floats apparently... Carb #1 will leak fuel if it's sitting on the kickstand.
I guess I'll start trying to diag by putting a little bit of starting fluid in, seeing if it will go with that and take it from there. Maybe if that doesn't go anywhere I'll do a compression test to see if something is apparently wrong with my newbie rebuild.
So close yet so far!
Offline Scott S
« Reply #94 on: October 29, 2017, 05:02:02 PM »
 Are you getting spark? Ground a plug on the head and see if it Sparks.
'71 CB500 K0
'81 Yamaha XS650
« Reply #95 on: October 29, 2017, 09:23:05 PM »
On another note:
I did that with my thumb, in my book!
Offline Scott S
« Reply #96 on: October 30, 2017, 03:15:33 AM »
 I almost mentioned the points cam dot, but she said she's running an electronic ignition and most of the ones I know of toss the points cam.
'71 CB500 K0
'81 Yamaha XS650
Offline Marissa
« Reply #97 on: November 15, 2017, 01:15:10 PM »
Little update. Here's what I found.
Got my electric start working well, have really strong spark across the board thanks to Calj.
I went ahead and put starting fluid in all the cylinders... Then my legs almost caught on fire (partially kidding). At this point, I knew something was very wrong and I knew there was only so many user errors that could be going on to cause this, so I said screw it yet again and disassembled it.
This is were it gets quite disappointing.
When I first initially timed the bike months ago, I was making newbie mistakes left and right (mostly just not doubling checking, and taking initial measurements. Live and learn) and I didn't double check to verify the cam didn't walk as I aligned the sprocket to it. I can be oblivious sometimes.
I think I turned it over once or twice to verify I was getting correct movement, or maybe I was turning it back to TDC again. I don't know. But after that I was a bit paranoid and retimed it, yet again not checking to see if it was properly timed. Likely, I think it was off timing and screwed myself over.
The second time around was very smooth and this time I combed over everything with a fine tooth comb. I verified everything was at TDC afterwards and went on my way.
Flash forward back to a couple of days ago when I was trying to start it back up, I did a compression test after the starting fluid scenario and wasn't getting any good readings ( I also only tested 1 & 4). I also wasn't able to get the hose in the spark plug hole as easily and smoothly as I wanted to, so I was worried that would be affecting my readings. We went ahead and verified the gauge was working, but with a different hose (this one fit on our lawn mower, the fitting for the bike didn't match anything). We didn't hear leaks, didn't feel them, so I took the head back off, ordered a valve spring compressor, and found this. My next couple of options are difficult ones to make.
Bent exhaust valve on cylinder 1. Here's where it gets interesting.
I removed all other valves and verified with a T square that no others were damaged or bent. It's kind of strange but the head of the bent valve shows no sign of contact, and neither does the piston.
I numbered all the valves, kept everything organized and reinstalled them in order to do a leak down test. I saw that the machine shop did clean the carbon off, and they did do a valve lapping job.
But virtually every valve is leaking.
(it's very faint lighting but you can see water droplets flowing down from the head)
Now, this unfortunately makes a lot of sense, as the bent valve explains why cylinder 1 had no compression, but I was confused what was wrong with cylinder 4 until now. Cylinder 4 is leaking through both the exhaust and intake valve.
The situation is hairy because, of course I want to take it back to the machine shop, show them what's wrong, and see if they will at least relap the valves and verify they don't leak. But, obviously I can't take it to them with a bent valve and expect them not to blame this on me.
One thing I know for sure, I do not want to pay $600 for something like this all over again. I can either:
  • Buy a $30 lapping tool and lapping compound, hoping that a relap will correct the issue, along with a new valve and guide.
  • Buy a used head online from a previously running CB and take a risk that it's in optimal shape
  • Take this head, bring it to another machine shop, have them cut the seats, match the valves, do a bounce test, and then I reassemble it.
Either way, I'm disappointed in myself, but also feel really jipped and taken advantage of. I put all the valves back as they were, the valve seals stayed in place, they went smoothly into the guides, etc. The error on cylinder 1 is definitely my fault, but I can't help but feel the rest of the issues are at the fault of the machine shop.
If there is anyone out there reading this that has "been there done that" and was in a spot like I am right now, I would love some recommendations as for what to do next. Obviously, I've already spent more money than this bike is technically worth, but I don't want to cut my losses now and sell a non running project for next to nothing. I want to finish it, I just need to be as cost effective as possible where I can.
Right now, I'm doing a simple leak down test on the pistons to make sure there's no blow by and that there's nothing else wrong. Once that's sitting long enough to show if anything is wrong, I'm going to measure TDC on all cylinders to make sure the pistons are level and to rule out any potential bent rods.
« Reply #98 on: November 15, 2017, 01:58:30 PM »
I havent exactly "been there done that" but at this point I would suggest finding a competent machinist and get a proper valve job.
The bent valve could have been from improper installation of the head cover?
I agree with your thought process of not cutting your losses and selling a non-running project bike.  Chalk this one down to "education"...
« Reply #99 on: November 15, 2017, 09:02:14 PM »
While you are looking at extra expense I would suggest you consider giving MRieck a chance at giving the head a good going over and do anything needed.  It really sounds as if they did not do the job correctly.
You can reest assured Mike knows what he is doing.  He could do a mild posting job for not a huge amoint of money and if you do need other work you can trust his word.  He is a forum member and really is highly skilled with producing  great power from these bikes.
HondaMan has some guidance on porting work for mild clean up and simple mod to unlock some power. There is another member who worked with Mark to show that work in a thread.
If you want to do aome easy low hanging fruit without cutting in the ports that require great deal of consistency.  Things like removing any flashing and casting lines in the ports as well as matching the intake ports to the manifolds.
I am sorry that you ran into this.
But seriously, not the time to toss in the towel.  Just hang in there and chalk it up to experience gained having lived through it.  You will never get out of the bike what you put in it usually.        But, the learning experience and satisfaction are very hard to put a price on, since many would agree it is priceless.  By doing things like this yourself you will develop skills that few others you know will have and you will understand your bike much better.  There will be times you will want to curse your bike, but after that is over you likely would not begrudge going through it because of your increased knowledge and knowing how to fix your bike.
When she/he's running and you are riding you will be well advised to have towing option through your bike insurance, AAA or AMA is worthwhile.  Not that the bike will regularly strand you but it could just like a new bike.  Having the coverage will give you piece of mind that the bike can be picked up and delivered back home or to a shop or site that can address the issue. It is cheaper to have the coverage than to have it "towed" one time.
AMA coverage with the longer towing distance coverage is good to have, also you get to keep abreast of motorcycle news affecting most all motorcyclist.
You are an attractive lady. Nice photo, just not of the bent valve.
Good luck sorting things out.
David
