Here is a basic model of mine.
I'm using GoldWing dampers.
Keith, you "MUST" use something larger than 6 mm at the front and rear unless it is anchored to the primary (re: my gear drive conversion) as under power the load is directed and driving the carrier assembly upwards and it is only the fasteners that are resisting this. Too small and without enough case support it will fail. Now I have brought your attention to this this, if you look closely at mine you will now understand why the bolt is so far forward and is using the channel directly under the crankshaft. You couldn't have a better support if you tried. This mounting is many times higher in capacity than the loads the engine even if blown could ever deliver to the carrier.
Captain
Brent, It has 4) 10mm bolts, one 10mm vertical is in
front of the crankshaft, and three through the sides. Two vertical 8mm bolts in the rear. Could easily do
two verticals in front of the crankshaft if necessary. I am anchored to the primary on the Automatic but there is no room to anchor to the primary on the 5 speed. We're not making 200HP (yet
) like somebody I know! Pretty sure it's not gonna move.
I should add, my torque moment is 93mm versus 57mm on the DOHC.
Just checked, a Class 12.9 10mm bolt has over 9400 lbs. of clamping load.
Keith
