Author Topic: The $6 Charging System Output Improvement Mod  (Read 23330 times)
Re: The $6 Charging System Output Improvement Mod
« Reply #25 on: July 03, 2020, 10:18:56 AM »
'A L' :American Locomotive.,
Do you know of a better way to attach the Schottky rectifier to the heat sink besides the clip ? Can it be surrounded by a small bracket or something? I doubt there's any area of it that I could drill through..
The reg/rect units traditionally like a solid connection to the heat sink so the transfer of heat is complete.
« Last Edit: July 03, 2020, 10:22:52 AM by grcamna2 »
« Reply #26 on: July 03, 2020, 10:37:26 AM »
Would it attach with a thin coating of an epoxy with a gentle clamp to assure it's down on the heat sink?
Gap filling super glue?
How much heat is expected?
Offline FJ40toy
« Reply #27 on: July 03, 2020, 10:41:43 AM »
Can try thermally conductive adhesive for the heatsink. It works well, but not sure how it would hold up to vibrations from the bike. From my experience it is used on electronic equipment that is stationary such as networking equipment.
Sent from my moto z3 using Tapatalk
1978 CB750F, 1973 XL250 Motosport, 1982 FT500 Ascot(engine rebuild), 2000 VTR1000F Superhawk, 1974 CB550 (waiting for rebuild)
« Reply #28 on: July 03, 2020, 12:54:25 PM »
  I have never had a CB750 that ever had a charging problem
Neither have I. ;D
nor have i...not even with 550s
Nor have I... not with my CB500 and I run a 55/60 Watts H4, 3Ω coils and a transistor ignition (which draws just a little extra). After every ride I return with a better charged battery than I left with. But I find your experiment very, very interesting. Forgive me my ignorance, but seen the high charging rates, I take it the regulator was bypassed?
« Reply #29 on: July 03, 2020, 01:34:03 PM »
Good improvement!  More efficient charging of the stock stuff for a few $ more.
Riding longer time at lower rpm will not charge much, especially not with headlight on, frequent use of blinkers and brake light.
I see how it works after I mounted a LED voltage meter between gauges last year
My K2 need ground cabling improvement to rectifier and front inside headlight direct from battery ( - ), voltage drops.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #30 on: July 03, 2020, 02:16:47 PM »
CPU thermal paste should be fine
« Reply #31 on: July 03, 2020, 02:30:52 PM »
Thermal paste,is that adhesive ? I've used it for the heat sink on a computer CPU
Offline FJ40toy
« Reply #32 on: July 03, 2020, 02:39:42 PM »
I don't think you want thermal paste for CPUs. Those have a clamp mechanism to hold the fan on. You want a thermally conductive epoxy or tape.
This will adhere the component to the heatsink.
« Last Edit: July 03, 2020, 02:42:59 PM by FJ40toy »
Offline American Locomotive
    • sohc4
« Reply #33 on: July 03, 2020, 02:42:25 PM »
Yes, I am using thermal compound between the rectifier and the heatsink. You can use thermal epoxy, a thermal pad or anything else thermally conductive.
The clip could also be replaced with any kind of mounting mechanism you want. You can use screws and a clamp, epoxy, or anything really. I was going to do a clamp but didn't have any small screws handy. Thermal paste and pads will require a retention mechanism, epoxy will not.
Regulator is not bypassed. It's set to 14.2v, and I have a brand new healthy battery that will accept a lot of charge if I purposely run it down some.
Like I said, this mod won't make a difference for many people, but for those running extras like heated hand grips and have some issues maintaining charge - this is a cheap way to squeeze a bit more out.
Plus, 20w less wasted electricity is 0.027 HP more at the crank - which means a faster bike :)
« Last Edit: July 03, 2020, 05:34:02 PM by American Locomotive »
  • Gusto mo titi ko?
    • project
« Reply #34 on: July 03, 2020, 02:57:46 PM »
Id recommend tinning your conductors before soldering them in place.
« Reply #35 on: July 03, 2020, 03:37:58 PM »
Thermal epoxy to glue the unit to the heat sink,that sounds like the best solution to me.Does thermal epoxy allow heat(I'm just learning here..)to transfer directly through it to the heat sink,no loss of transmission ?
« Reply #36 on: July 03, 2020, 03:53:21 PM »
How may this work with a solid state voltage regulator?
Offline FJ40toy
« Reply #37 on: July 03, 2020, 04:05:16 PM »
Yes. It serves two purposes, one to affix the heatsink to the chip or device, and second to conduct heat to the heat sink from the device or chip.
It works well.
Offline dazemc
« Reply #38 on: July 03, 2020, 05:32:53 PM »
I am very excited to try synchronous rectification using MOSFETs. I had never heard of such a rectifier before but it does look like something I am familiar with. A Dickson MOSFET charge pump, which makes me wonder if you could produce an AC to DC charge pump. This would give you the benefit of removing the regulator at about a 90-95% efficiency. I still don't quite understand how the original rectifier works but I found this diagram. So it looks like it's using two transistors, two diodes, 3 resistors and one zener diode. Attached is a write up that was with the diagram. So to me it appears to ground out the field coil to achieve a set voltage. Could the field coil just be relayed to constantly be on? If not, there has got to be a way to control the field coil switching using MOSFETs as well. http://cloud.tapatalk.com/s/5effce336f411/VoltRegExciteField%20%281%29.doc
Sent from my SM-N950U1 using Tapatalk
1971 CB500
Offline dazemc
« Reply #39 on: July 03, 2020, 05:35:13 PM »
Also, if Honda rectifiers are similar...... Do they have 9 diodes too? Would explain the horrendous voltage drop.
« Last Edit: July 03, 2020, 05:39:30 PM by dazemc »
1971 CB500
    • sohc4
« Reply #40 on: July 03, 2020, 05:43:26 PM »
Analog Devices makes the synchronous rectification chip - they call it the "ideal diode bridge controller". It analyzes the incoming AC signal and properly sequences and drives the MOSFETs (and it has built in charge pumps). It works from DC to over 600 Hz AC. I might spin up a board for fun.
So the stock regulator is just a set of contacts that get opened by a magnetic coil. When the desired voltage is achieved, the contacts open up and the field coil is turned off. Of course this cycle occurs very rapidly near the regulated voltage setting. The biggest issue with the stock regulator is that there's a big power resistor on it that's burning at least 5 watts of power, if not more.
If you have a separate regulator and rectifier you can do it. If you have one of the combination regulator-rectifiers, it will not work. Well it won't work without going back to a separate regulator.
They should only have 6 diodes internally.
« Reply #41 on: July 04, 2020, 12:49:36 AM »
The standard Honda regulator has 3 position
1 full battery voltage to field
2 zero voltage to field
3 reduced voltage to field
The risistor is only in circuit in condition 3
« Reply #42 on: July 04, 2020, 05:46:52 AM »
My rectifier was heavily corroded under the ground connection, brushed it and added an extra ground wire to battery -.
This  FUS45-0045B rectifier used here is the 20A version?
Is that enough for eventual spikes?
The old rectifier can still sit, just swap connector if it will give up, old Honda back in.
A connector housing needed.
Stock look like this. Fixed surfaces and additional ground wire. There is an isolating washer at top, I'm sure it will quick go bad if lost.
    • sohc4
« Reply #43 on: July 04, 2020, 06:01:51 AM »
The FUS45-0045B is rated at 20A per diode (this means one AC phase can feed up to 20A), but in normal operation with all 3 phases going, it's rated for up to 45A continuous. It has a 150A surge current capability.
For the connector, I cut the plug off the original, but left enough wire so that I could reattach it later if needed. I understand some may not be willing to cut up an original factory part though. There are tons of new aftermarket rectifiers for sale for these bikes with the correct plug, so someone has to be making it. It's just a matter of identifying the type of plug.
« Last Edit: July 04, 2020, 06:11:48 AM by American Locomotive »
Offline rotortiller
« Reply #44 on: July 04, 2020, 06:55:33 AM »
My stock CB750 system is pictured. As you can see it is powering the complete electrical system at under 1800rpm. The coming-in rpm of my alternator is even lower. (the rpm at which the alternator powers everything and power flows into the battery instead of out). If you have an modern efficient AGM battery coming in rpm will be lower over old school wet cell battery. The stock CB 750 , it uses a full wave 3 phase 6 diode rectifier. Maybe the subject mod can improve my situation, however  it's fine in my situation. Options are also available for LEDs freeing up additional head room and adding lighting lifespan. Six bucks is a pretty cheap way to add performance or replace a toasted component.
« Last Edit: July 07, 2020, 11:53:59 AM by rotortiller »
    • sohc4
« Reply #45 on: July 04, 2020, 07:10:44 AM »
Yup, like I said many times: If you have a stock bike with a stock electrical system, this mod will not do particularly much for you. It provides extra current in low RPM situations and about 20w total extra charging system power. Not earth shattering by any means, but it's a nice bump for less cost than a meal at Burger King. I suppose if you have a failed/toasted stock rectifier, there would be no reason to NOT do this mod, unless you need your bike to be original as possible.
As far as rectifier terminology goes: Any full-wave rectifier is a "bridge" rectifier. In the case of these bikes, the exact term would be a "Polyphase diode bridge rectifier"
« Last Edit: July 04, 2020, 07:13:18 AM by American Locomotive »
« Reply #46 on: July 04, 2020, 07:19:02 AM »
OK charging with headlight ON?
H4 55/60W
That"s the weakness this cheap mod hopefully can fix.
This is the law here and safety to be seen.
« Last Edit: July 04, 2020, 07:20:33 AM by PeWe »
    • sohc4
« Reply #47 on: July 04, 2020, 08:00:51 AM »
H4 55/60W
My bike with the stock regulator will have a slight battery discharge at idle and high-beam on. With the schottky, it's a slight battery charge at idle. But of course, that it just with my particular bike, my battery and my electronics.
« Reply #48 on: July 04, 2020, 08:54:36 AM »
My question was about the earlier photo with 14.35V.
I found a seller in UK with low shipping to me. Order done!
https://www.ebay.co.uk/itm/192960004000
Next is to find heat transfer paste, cooling plate to attach it on.
I'll fixate it with an alu plate with 2 holes for screws tightened into the alu plate it sit on as cooler.
I saw heat transfer glue, not cheap.
Connector housing  for additional mount and swap connector plan B  :D
Offline Alan F.
« Reply #49 on: July 04, 2020, 10:36:11 AM »
For heat transfer compound ask around to friends that build computers or dabble in electronics, someone will be able to spare some.
