Author Topic: Restoration: 1968 CB77 aka Superhawk : pics as of 12/27/2021  (Read 11002 times)
Re: Restoration: 1968 CB77 aka Superhawk : pics as of 12/27/2021
« Reply #75 on: April 24, 2022, 09:08:18 AM »
test
« Reply #76 on: April 24, 2022, 09:17:42 AM »
Beautiful work on your SuperHawk Ron  8)
« Reply #77 on: April 24, 2022, 09:58:41 AM »
I was trying to stay away from my photobucket account, but it turns out to be the easiest for me to understand.
« Last Edit: April 24, 2022, 10:00:54 AM by MCRider »
« Reply #78 on: April 24, 2022, 11:18:45 AM »
more
This was the first iteration of front fork assy. The external springs were showing like a schoolgirl's slip. That couldn't be right. Resolution later.
This was Joe getting ready to blow a gasket putting the springs back on the rear socks. He got it done.
Here's a shot of the very expensive NOS chain guard I found on eBay.  As I told Joe and Bruce, this project has a budget of $500,000, so that's not a problem.  :) The last shot is a comparo of chainguards with their hog wart fixes.
« Last Edit: April 24, 2022, 11:38:48 AM by MCRider »
« Reply #79 on: April 24, 2022, 12:15:11 PM »
Inside of gas tank before and after sand blasting by the powdercoating.
Rr Fender before sandblasting. (Out of order)
« Reply #80 on: April 25, 2022, 11:31:44 PM »
Sand blasting? You want to kill and remove the rust but not cut the tank's matal anymore than you have to...thinning a tanks metal could be dicey as anything that makes it weaker could put gas all over you if you lay down the bike and the tank opens up when sliding.
I prefer chemical stripping and chelating rust.
« Last Edit: April 27, 2022, 12:48:16 AM by RAFster122s »
« Reply #81 on: April 26, 2022, 08:01:54 AM »
If you sandblast, you might want to line the tank with Caswell epoxy.  Honda used really thin steel for these tanks, and they can be prone to developing pin-hole leaks if you sandblast.
« Reply #82 on: April 26, 2022, 04:44:13 PM »
+1  :)
« Reply #83 on: April 27, 2022, 01:13:39 AM »
the tanks on the ca95 and likely the CB77 are heavier than the tank metal used on the CB550/650/750 and similar bikes. but even then, I think you really should avoid anything to thin it further, even aggressive sanding a tank to remove surface rust I have decided is something I will never do again.
the rolled surface of metal forms a kind of protective layer apparently because that smoother rolled and stamped tank metal once you give it tooth by either muratic (?spelling?) acid, vinegar, or sand blasting the tank or that metal will rust aggressively. the natural humidity in a tank’s air and the heating and cooling of the day and night air causing condensation inside a tank or toolbox can cause massive levels of rusting.
so, I agree that you really should line that tank. ron, being an old motorcyclist I know you are probably aware of this and it is your plan to do so. At least the powdercoating guys you are using is doing really nice work.
i would love to turn my cA95 into moreof a CB95 but that isn’t gonna happen…the CB95 was a cool bike but very low numbers and I have only seen photos of them. my CA95 is a rough project, I think I won’t even do the build of it, despite having acquired a bunch of stuff to do the build. i just don’t have the funds and resources I once had as an engineer and being on social security with my income restricted I no longer have the engineering salary and I didn’t intend to be on social security at my age…but life rarely lets you predict how it is going to turn out…
life can be hard sometimes and brutal at other times…
life never has been an easy road for me.
I really like how this is turning out Ron, you and Joe make a good team…and it keeps Joe out of trouble…him helping see this project along is good…
i think Joe must be a good friend with a big heart as you guys have become MC building buddies…first with Phaedrus and now with the CB77.
Offline CBJoe
« Reply #84 on: January 24, 2023, 04:37:31 PM »
Happy 2023 :) Its been a long time so we wanted to throw out a quick update.  Ticker is getting ready for spring and hopefully will make some noise with warmer weather.  More to come in the future.  Just throwing out there that things are still happening and movin' and shakin'
Motor in position.  Once we know it runs well it will be pulled and cosmetically cleaned up
Added turn signals where there were none before.
Again...short update...more to come
« Last Edit: January 24, 2023, 05:17:20 PM by CBJoe »
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline scunny
  • don't call me expert
« Reply #85 on: January 24, 2023, 05:39:17 PM »
I see the external springs are gone.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline CBJoe
« Reply #86 on: January 24, 2023, 05:42:13 PM »
Yep... mistakes were made.  Been long enough I can't remember what it was but we figured it out.
Another quick note as there was mention of sandblasting and the integrity of the tank.  We actually had the tank and frame chemical dipped at a local striper. It was in phenomenal condition.  After full cleaning it was powder coated white with the frame and other bits
Sent from my Pixel 6 using Tapatalk
« Last Edit: January 24, 2023, 05:56:53 PM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
« Reply #87 on: January 24, 2023, 05:58:21 PM »
Looks absolutely fabulous!
« Reply #88 on: January 24, 2023, 07:39:59 PM »
Hawk is looking good Ron and Joe! I hope you guys are getting some shop therapy hours in as it is good for the soul and mind to hang out and work on bikes and other things…
« Reply #89 on: January 25, 2023, 09:19:47 AM »
I don't remember what we had done wrong with the fork tube/ spring assembly. We must have put the springs in upside down or there was sleeves that was misplaced. But its all better now.
It's amazing how much the inside of these forks look like a CB750KO.
Yeah, this is all therapy now, as I have lost all strength and balance in my legs. I can't even get out of my chair one step without falling down. So we work on it as often as we can. That's CBJoe and Build Bubby Bruce, doing the work and I throw in a little wisdom..  Without them it would likely... not get finished.   :(  But I have a substantial budget for this project so we'll just keep on.  It does really look nice. The white is really white.
« Reply #90 on: January 25, 2023, 11:56:41 AM »
I love that white Super Hawk Ron  8) I imagine the spirit/character Phaedrus featured in the book Zen and The Art of Motorcycle Maintenance would ride that CB77 all day long  ;)
I would love to own a white CB77 and do what you're doing as far as Full Resto  :)
« Last Edit: January 25, 2023, 01:56:47 PM by grcamna2 »
« Reply #91 on: January 25, 2023, 01:14:15 PM »
Very nice project! Looking good.
« Reply #92 on: January 28, 2023, 02:21:38 PM »
Glad you are still at it as much as possible Ron....
Offline CBJoe
« Reply #93 on: February 05, 2024, 06:19:10 AM »
Updating this thread with the unfortunately news of Rons passing.  Please see this link for info.
http://forums.sohc4.net/index.php/topic,194406.0.html
'65 CB77
'66 CM91 (C90'ish)
« Reply #94 on: February 05, 2024, 10:14:21 AM »
CBJoe,he will be missed  :(
