Author Topic: Andys CB810 K2 -updated 14 Oct 2024 - missing link!  (Read 136921 times)
So I opened up the K2 carbs tonight and found a few issues...evidence of brass-aluminum corrosion, and carb #3 had a bent float - probably explain why it was the cold cylinder at start up - surprised it wasn’t overflowing at idle. See pics below...
#2
The broken pilot jet
Explains the #3 plug...that I checked previously
Offline jaytee-nz
I might be seeing things, but the pilot jet on the right hand carb looks bent to me ?
Never noticed that...Ill take a closer look and let you know!
That pilot jet does look bent. Were you playing soccer with those carbs Andy??
Never touched them!
I may need your help though in extracting the broken one  :-X :-\
I have a spare set of carbs that I am hoping to install tonight and test ride tomorrow morning so will update here with progress.
« Last Edit: July 24, 2020, 06:35:33 AM by andy750 »
If the bent looking jet really is bent, the broken jet might have been bent too. Can be why it broke.
Remove the other jets very slow. No quick twist.
Edit: Buy Keihin jets.
« Last Edit: July 24, 2020, 08:53:04 AM by PeWe »
Ok so...the pilot jet was not bent...optical illusion I think - see pics
All four carbs
Pilot jet on the right looks straight to me
Close up
Arrow points to jet in question
Switched the carbs and success!!! - no leaks on start up and test ride showed what I have been missing these last few months - snappy throttle, growl of the HM300s, fast acceleration - got it up to speed on the highway and was not disappointed. Smiling again!! Can’t wait for the next ride :)
Thanks for all the comments they really motivated me.
Post-highway ride
Offline Alan F.
Good news Andy!
Quickly done too!
Offline knowsnothing
Re: Andys CB810 K2 road racer- updated 07.24.20 on the road again!
« Reply #286 on: July 28, 2020, 01:26:23 PM »
 Nice work young Andrew
1978 CB750k Blue - for sale
« Reply #287 on: July 28, 2020, 06:19:49 PM »
Thank you Treeve! I was over in your neck of the woods on Saturday morning at 8am....did the Blue Hills-Wollaston Beach loop from mine and back to test ride the K2. Passed with flying colours! Next time Ill shoot you a text before I head over. I was back home by 8:30 before the heat hit.
How is your bike coming along? Running yet? Need any parts?  8)
« Reply #288 on: July 29, 2020, 11:45:57 AM »
Let me know next time for sure.
The bike is finally running.  I still need to finish the tank and seat, but I have a stock tank and seat on it for now so I can get a few miles on it while i finish.
 Right now i am working on tuning.  It has a hanging idle issue I think is likely due to a lean condition, so I am working on that.  Still need to open it up on a highway, but its nice and peppy so far. I am just pumped it didn't grenade on first start up since i did do most of the work    ;D  .
« Reply #289 on: July 29, 2020, 07:57:55 PM »
Are the felts on the throttle shafts lubed? That can cause a slow return to idle.
« Reply #290 on: July 31, 2020, 07:12:57 AM »
Looks good Andy!
« Reply #291 on: July 31, 2020, 06:41:12 PM »
Looks good Andy!
Thank you! Big relief getting it back on the road. Now thinking about tires - what do you like? I always buy BT45 but feel like a change for this bike
Offline Alan F.
« Reply #292 on: July 31, 2020, 07:11:21 PM »
BT-46 is available, I haven't heard any ride reports though.
« Reply #293 on: July 31, 2020, 09:46:30 PM »
Someone recently mentioned putting a new BT-46 on the rear of their CB. Do not recall whom. Would a Google search find reference to BT-46?
Online Kevin D
  • SE Michigan
« Reply #294 on: August 01, 2020, 03:10:31 AM »
https://grippingstories.com/articles/2019/battlax-bt46-the-new-reference-bias-touring-tyre
BT46: wet road performance improved about 10% by modification/enhancement of sipe design.
At least, that’s the Bridgestone pitch.
UM application, tube or tubeless.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #295 on: August 01, 2020, 07:05:14 AM »
Rear with longer life would be fine. Over 4000 miles with some inspired accelerations.
« Reply #296 on: August 01, 2020, 08:09:13 AM »
 Happy to say the broken pilot jet has been extracted and Andy should have the carbs back very soon.
« Reply #297 on: August 01, 2020, 09:47:44 AM »
Golden boy to live that close to a superb support, huge knowledge and fantastic craftsmanship!
Good friend too!
« Reply #298 on: August 01, 2020, 01:56:00 PM »
Good friend too!
Very well said Per and couldn’t agree more. I first met Mike about 15 years ago through the forum and it has been an honour to know him.
« Reply #299 on: August 01, 2020, 01:56:46 PM »
Thank you Mike!!!!   ;D
