Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 1193827 times)
Re: Phaedrus:CB750 RestoMod - Misc Updates, Ohio Prep, W/ New Pics: 9/25/16
« Reply #4050 on: October 11, 2016, 02:20:58 AM »
Ron,  Sorry I am behind on the threads I follow... Just saw your updates... I hope your surgery has gone well.  Looking forward to hearing you are doing a lot better and on the mend!
David
« Reply #4051 on: October 16, 2016, 01:43:11 PM »
Thanks every one for the well wishes. I had a triple bypass, and am home now recuperating. Walking about a half hour per day. Not totally able to do my transfers, but its encouraging.  The wife is a saint.
Offline Tintop
« Reply #4052 on: October 16, 2016, 04:13:19 PM »
Great to hear your home and on the mend Ron.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #4053 on: October 16, 2016, 05:55:40 PM »
Woohoooooooo, Ron is back. Glad it's worked out great. You're gonna be a new man  ;D
Offline CBJoe
« Reply #4054 on: October 16, 2016, 08:27:11 PM »
Great to hear an update and that you are doing well! Take care   ;D
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #4055 on: October 23, 2016, 01:10:55 PM »
Ron,  I hope the damage wasn't too bad and your ejection rate is where it should be...  Glad you are back home and feeling better!
David
« Reply #4056 on: October 23, 2016, 02:37:43 PM »
David
Two Drs. both said the heart muscle itself looked good still.  Still on "sternal restrictions" for 4 more weeks. Be careful about picking up, moving, pushing etc.
The 2 stents I had just didn't do the job. I want to get a copy of the repots to see why they switched from stents to the by-pass route. Implication the blockages were advancing quickly.
Thx for thinking of me.
Up to a mile per day, no chest pain. Still a lot of swelling in the legs. Things are looking good.
Got out in the shop finally. Had to swap out the trailer hitch. I had a 4.5" drop. But the trailer rode high in the front. Don't know how much difference it makes, but I didn't like it. I found a drop hitch with a 6" drop. Took a while as most drop hitches reduced their capacity from 350# to 200# TW and 3500# trailer weight to 2000# with that much drop. I found one that had an extra gusset welded in to maintain the capacity at 350 and 3500.
Felt good to get out.  :D
Offline Tintop
Good news that everything is going well for you Ron. 8)
77 CB550 Cafe build
+1
Ron,  glad to hear you are improving...hope you are able to rebuild strength and endurance before winter weather sets in.  Do you have a gym membership or are you going to have long term PT for the recovery period.  You are very blessed to have managed to not have any heart muscle damage.
Frien in Tuscon had a massive heart attack they refer to as widow makers because very few survive such an event.  John has managed to rebuild and strengthen but it was a long road and he has significant heat damage.  He was out for a run and had the heart attack and trash collector found him and was able to get him help in time.  He had no id on him and that was a challenge at first.
John is a retired career Army helicopter pilot and was in very good health....just the ticking time bomb went off day and he had been checked out by cardiologist about 3 months prior with no symptoms or precurssors to a heart issue.
Offline CBJoe
Hey Ron!  How's it doing?  Kicked the heaters on in the shop yet :)
Thought we'd have 70degree weather till Christmas till this week rolled around.
'65 CB77
'66 CM91 (C90'ish)
Hi Ron,how are you ?  :)
Thanks Joe and grcamna:
I'm doing fine. Still healing from the bypasses, Takes about an hour  a day of walking and exercising.
The real negative symptoms are still the drop foot from the neuropathy and the bradykinesia (slowed movements) from the Parkinson's. Neither of these are life threatening (other than as a result of a fall or pneumonia), while the heart stuff is. But the heart causes me less trouble on a day by day. I'm back to work 8 hrs day, and the Docs say that's the best thing anyway, staying active.
I miss the "rock steady boxing" classes for the Parkinson's. My sternum needs 12 weeks of babying before returning to harder exercise and punching.
Joe, are you available, with notice, to help us pull Phaedrus's engine, and then replace it? Bruce and I are not up to it ourselves. I'll need to line up another helper as well. Once its out, and on the bench, we'll flip it over, take the lower case off and re goop the sealing surfaces esp around the mainbearing saddles. I'm getting leaks out of the main bearing heavy duty studs I installed and I've been told it because I didn't goop them properly.
We've been doing little things each week to keep the momentum moving forward. My surgery really threw a wrench in the 2016 schedule. We want to be ready for 2017 Ohio Mile.  :D
Keep at it Ron.  :)
Another option is to use some Hondabond ETC below the nuts/around the washers in the opening of the crank studs in the lower case.
IF you do yank the engine PUT A CAM IN IT!!  ;)  You should be getting more out of that engine than what you have so far.
Keep at it Ron.  :)
Yeah, I did that with the goop from the outside, and put copper washers on too, That fixed most of it, but there's still a drop or two every outing and I don't want that for my legacy. And there's one I can't get to because of the frame tubes.
No cam this time. Maybe later, I've got a frame kit.
I am looking at some better pipes though.
Offline CBJoe
Hey Ron,
Absolutely I'm available with a little bit of notice.  Been travelling for work a bit and heading to Atlanta Sunday for a few days but after that I'm free.  Just let me know when you're thinking.  I can easily round up a second set of hands if you need...just let me know.
Glad to hear you're getting back at it.
Cheers, Joe
« Last Edit: November 25, 2016, 06:15:40 PM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
Hey Ron,
Cheers, Joe
Thanks Joe:
It will be purely at your convenience, and possibly (probably) later than sooner. My garage is heated though.
We unloaded the bike today to start making the preps. Ideally, we'll get it out some morning, do the re-gooping, and get it back in later that day. To avoid making it a multi day affair. But its not always in my control. If we find something other than run of the mill, it may be out one day, and back in later on.
I always liked this 90° profile shot:
Pulled the tank and frame rail kit:
After having sat alone on the trailer for 6+ weeks, the trailer rail was covered with oil below the engine. Dang! I mean, after a good hard run at the drags, there was no oil leak obvious for a few weeks.  Then as stated, after neglect for many weeks, there is oil dripping from the left frame rail, the main bearing stud tips, a film all over the front of the engine (which must have happened when last run and just not noticed till now.  A close examination shows oil pan is dry, the two large oil passage plugs have oil dripping from them, the oil filter cover has oil dripping from it.
The top end seems dry, though the front of the base gasket may be wet, running down the face, or the case seem is leaking and blowing up to the gasket... jeesh.
Anyway, I'm going in and regoop everything.
Offline Old Scrambler
Re: Phaedrus:CB750 RestoMod - ByPass update: Short Shop Update: New Pics: 11/27/16
« Reply #4068 on: December 04, 2016, 02:42:28 PM »
Ron...........Its great to hear you are on the road to being a 'new man' :) :) :)
I've been traveling quite a bit so not always keeping up with all the different news on this board. My brother had a 3-bypass episode almost to the same date as yours. I just returned from a visit with him in Atlanta and make the same wish to you............Please attend all of the PT sessions ;) Each one is likely to add a year to your newly-extended life on this earth.
Regarding the bike..........Oil on the bottom got there from above............and they all get fogged in the front from high-rpm runs. It tends to show a few weeks after sitting. I think we sometimes forget how often we 'washed' our prized bikes back in the day.
Keep the progress reports coming........and tell us how cute your PT guru is :) :) :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #4069 on: December 07, 2016, 10:23:04 AM »
Thanks for that, Dennis:
Committed to my PT. I've spent more time on that these least several years than motorcycles. My PT gals are cute, that helps.
Oil from above is maybe the place where the studs are (I changes to main bearing studs from the stock bolts) inside the engine. At the seam split level, then wicking its way to the bottom of the stud, then blowing over the bottom of the engine. We'll see.
« Reply #4070 on: December 08, 2016, 08:39:17 AM »
I bought some 4-2 exhausts from CycleX. Version #5s on this page.  http://www.cyclexchange.net/Honda%20SOHC%20High%20Performance%20Exhaust%20Page.htm
Ken was candid about them, not to expect any power increase. I'm OK with that, what I'm wanting now is something more practical than the Marshall I have on it now.
#1. Oil change without having the oil puke all over the header. Since I have to change the oil every event, the mess was really getting old.
#2. Having the muffler(s) tuck in to the bike more. The Marshall points outwards in a ridiculous way.
#3. Easy removal of the mufflers for cleaning the rear wheel.
While I have the engine out I can remove the spigot style exhaust mount and prep for the later style clamshells with drawdown clamps. I'll have to buy some of those late model clamps, maybe eBay.
Offline Restoration Fan
  • My wife will never call me
« Reply #4071 on: December 08, 2016, 09:25:40 AM »
Wow.  I take some time off from reading threads a lot happens!
Glad to hear you're improving, Ron and back now to working on the bike.  I hope you also had the foresight to tell the doctors to put in a turbo switch while they had you opened up?   :)
« Reply #4072 on: December 11, 2016, 05:16:25 PM »
Yeah, a lots happened in the last few years. I didn't like the way the turbo hooked up to the exhaust  ;), so we opted for some nitrous  :D.
« Reply #4073 on: December 11, 2016, 05:31:43 PM »
Last week, we sorted out the pieces left over from my chainguard fabrication exercise. May have a buyer. Really trying to reduce the volume of stuff in my shop/garage.
This week, we got the CycleX exhaust. Removed the old one, good riddance, and dry fitted up the new one. It appears to be well made, and fitting my criteria. ie: way clears the oil filter, drainpan, for keeping track of the engine via oil pump screen, and after some twerking, the mufflers ought to come off and on quickly for aid in cleaning the wheel. Only thing missing is an obvious way to stop the centerstand. But that should be doable.
The spigots were actually loose in the head.  :o   Since they aren't used with the new pipe, took them all the way off.
Next is to procure some late model finned clamps from eBay. Then store everything away and continue prep for engine removal.  :D
« Last Edit: December 11, 2016, 05:48:40 PM by MCRider »
Re: Phaedrus:CB750 RestoMod -Shop Update: New Pics: 12/11/16
« Reply #4074 on: December 30, 2016, 09:29:50 AM »
Rats! Ohio Mile is no more. It was one unused runway of a little used regional airport. Amazon or something like that has purchased the property for a distribution center.
Rick has moved to Arizona, pre-retirement I think. His son Preston is still here and will assume duties of pilot at the drag strip.
Working on prep for pulling the engine and attempting to goop up some oil leaks.
Received some exhaust flanges from CycleX for the new pipe I bought from them. Hope to mock it up for a pic, and determining how it will mount and how we will stop the centerstand.
« Last Edit: December 30, 2016, 09:35:02 AM by MCRider »
