Author Topic: Phaedrus: CB750 RestoMod - Update: 09/23/21 w/ new video  (Read 1227574 times)
Re: Phaedrus: CB750 RestoMod - Update: Stills, Video! 12/20/18
« Reply #4400 on: December 19, 2018, 12:34:15 PM »
Misc stills to get us caught up:
Prepped to degree the cam:
21st Century set up to degree cam:
Joe's mighty "been all around the world"  Guzzi:
Noticee how the #1 slide is at idle whilst #2 (and 3 and 4) are rising.
« Reply #4401 on: December 19, 2018, 03:47:12 PM »
I love that Guzzi! ;D
Offline CBJoe
« Reply #4402 on: December 19, 2018, 05:24:11 PM »
Its a great bike...pain in the ass to service though and F$@! guzzi for making the Service Software so proprietary
Holy Crap Ron!  Look at all that green grass and leaves on the trees  ;D  Feels like it was just yesterday
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #4403 on: December 28, 2018, 08:54:42 AM »
Follow up: We checked the point gap and the static timing. They were spot on from the last time I checked them. One may ask why still points, not electronic? I'm sold on HondaMan's transistor booster. Installs easily, works wonderfully. Engine starts without delay, so cool.
On to the miserable turn signals. They flash when they want to. The puny screw that holds the socket in suspense inside of the housing, is too small to really do its job. And when it is tight, the bulb fits so loosely in the socket that it still intermittent flash due to poor ground.  I think I'll op for some OEM quality, but with a semi-bullet look, like from a Suzuki of that era.
« Reply #4404 on: December 28, 2018, 01:02:38 PM »
+3 for points! :)
Points is one of the nice old details that makes these bikes to be something special. It has became a challenge for me to get it to work  fine. I have found the issues to fix and how to set it up.
Hondachopper has two descriptions about what to do and how.  http://www.hondachopper.com/garage/garage.html
http://www.hondachopper.com/garage/carb_info/timing/timing1.html
Improvements: https://www.motorcycleproject.com/text/sohcign.html
A SOHC thread about setting the gap equally for a smooth running idle and avoid carb synch when ignition make engine to run uneven.
http://forums.sohc4.net/index.php?topic=147444.0
Check real TDC, T vs case mark which is more important for ignition than cam that can differ a few degrees, ignition not. Very visible on low throttle lift, taking off.
I have verified 2 cranks and 2 advancers. Advancer set at the max counterclockwise position of its play make it correct.
EDIT: This work fine for cam timing, not ignition. Let it sit max clockwise and retard the ignition a little due to the play of advancer. 2-3 mm later is my experience. I stamped alternative case marking 3mm later when timing the cam using a piston stop before the rockers were mounted.
« Last Edit: August 05, 2019, 03:05:32 AM by PeWe »
Offline CBJoe
« Reply #4405 on: December 28, 2018, 07:16:18 PM »
Hey PeWe....we did indeed get true TDC with proper stop tool that Ron had in his magic tool collection.  I'd also like to say thanks again for your previous documentation on cam timing numbers as it helped us understand the mechanics and results better.
Ron...whatever you do keep those signals low profile  8)
Fingers crossed we'll have an indian summer in January so that engine can get broken in  ;D
Here an inspiration pic from the Glenn Curtis museum to get thinking about the CB77 ;) I know it’s a scrambler...but close enough
« Last Edit: December 28, 2018, 07:19:31 PM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
« Reply #4406 on: January 01, 2019, 09:23:16 AM »
1. Cleaned up the shop, scrubbed the floors with oil dri, etc.
2. Fired it up and listened to those pipes. They are reminiscent of the old Chris-Craft mahogany boat gurgle. Not another 4-1, though the 4-1 may yield more power, I'm into what I like.
3. Compression check yielded 180 psi straight across. The new C7 cam has more overlap than what we were running and less chance to build up pressure. Still I think 180 is good for an engine with 5 minutes on it.
Bot some more substantial turn sigs. The ones I had were just too puny. The ground screws would shake out, they wouldn't stay tight to the makeshift mounts. The new ones are more robust without being K2+ size.
Happy New Year!
Re: Phaedrus: CB750 RestoMod - Update: 1/1/19
« Reply #4407 on: January 11, 2019, 10:21:48 AM »
Last Sunday's recap:
Attendance: Ron, Bruce, CBJoe.
Tasks:
Install new turn signals. The mini bullets were a challenge to keep functioning. Vibrations would cause them to lose their ground. So I got some Fat Bullets:
Install mirrors:
Give it a once-over: no pics
Ready to ride...
Success! About 8 mile break in ride! Yay!
Re: Phaedrus: CB750 RestoMod - Update: 1/10/19 w/new pics.
« Reply #4408 on: January 11, 2019, 11:54:18 AM »
Excellent!  ;D
No smoke? How's it feel so far?
« Reply #4409 on: January 11, 2019, 12:03:09 PM »
Bike look good. I hope it will run perfectly! A Happier and Newer Year has begun! :)
Offline Tintop
« Reply #4410 on: January 11, 2019, 01:06:27 PM »
+1!
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline CBJoe
« Reply #4411 on: January 11, 2019, 03:26:51 PM »
Excellent!  ;D
Smoke?  What smoke  ;D
« Last Edit: January 12, 2019, 04:27:26 AM by CBJoe »
'65 CB77
'66 CM91 (C90'ish)
« Reply #4412 on: January 12, 2019, 06:56:10 AM »
Don't smoke and drive!  A successful ride is worth a smokey evening afterwards ;)
« Reply #4413 on: January 12, 2019, 10:09:20 AM »
Thanks to Joe for taking it on its spin.
Thanks for eveyone's comments.
Now, to get down to tacks. NO smoke, and apparently no top end leaks. It has a driip coming off the ignition wire underneath, should be fixable. The rear brake is really acting up. It was red hot when Joe got back from his ride. But, it didn't inhibit its ability to roll when we pushed it around. Odd. I've got some ideas, but have to delve into them.
One turn signal isn't working. The new signals had about 18' each of extra lead. Cramming all that wire in the bucket with the relays, I think caused something to come unplugged, no prob.  I'll trim off the excess leads and try again.
« Reply #4414 on: January 12, 2019, 12:46:36 PM »
Frankenfrankenstuff:
Do you reemeber? those are your sidecovers, with gold metalflake in the emblems. Nice work.
« Reply #4415 on: January 12, 2019, 04:46:25 PM »
Ron, Bruce, and CBJoe;
Congrats on the success!
Best on wrapping up the details of the little issues that remain.
David
« Reply #4416 on: January 14, 2019, 10:54:11 AM »
Limited update:
Weather related sniffles stifled us getting together, I didn't want to be exposed to potential cold bugs and called it off. But, when I went out to the shop to turn off the heaters, the space was so warmed up, I hated to waste it. So, I pulled the headlight ring and lens exposing the hated bird's nest of wire. As I thought 1 of the ground wires had come unplugged as we wrestled it in, causing its light to not work.
I trimmed 10 inches off the lead of each of the front signals. Replaced the undersized bullet connectors which weren't official Honda size and fit loosely. Plugging them in made a positive fit, the lens went back in the bucket with about 1/2 of the grunting and groaning normally required.
Then, I took a look at the beautiful titanium flange nuts I received and installed the 8mm drilled ones on the bottoms of the fork legs. Held off on wiring them secure until later. Had to get back in the house.and get a jump start on next weeks work load.
The purple ones are flanged with Nyloc but aren't drilled. They are for sprocket nuts. I talked to the vender and they said its common for sprocket nuts to not be drilled, in favor of Nyloc. So demonstrated on their website.
The gold ones look #$%*in on the forks, but don't show well in the picture.
« Last Edit: January 14, 2019, 12:48:55 PM by MCRider »
« Reply #4417 on: January 15, 2019, 07:53:07 AM »
Fancy parts  ;)
« Reply #4418 on: January 18, 2019, 05:41:54 PM »
Man, that bike doesn't even need a headlight at night!
« Reply #4419 on: January 19, 2019, 01:42:09 AM »
That is a clean headlight bucket!
Press the spaghetti inwards away from the center for the bulb, push the reflector into its position, find the screw holes. Test and sniff for burning wires. Forget it and ride  8). I had to reallocate the 3 relays to the outside when using LED H4. 1 relay for Lo, 1 for Hi and no 3 for switching off parking when LO is used.
Using aftermarket bullet plugs need more space too.
« Reply #4420 on: January 20, 2019, 01:38:24 PM »
The bucket is a chrome replacement for a Kawasaki, I bot from a little place in Indy called Cycle Recycle. Its a little different than a CB750, but not much. It hasn't seen much road time or otherwise exposed to the elements.
That's how I usually stuff it, its amazing it all fits. I've still got  the relays inside.
My aftermarket bullets are exactly OEM size. Got them from that electrical place everyone goes on about.
Offline CBJoe
« Reply #4421 on: January 20, 2019, 06:07:46 PM »
So true  8)
'65 CB77
'66 CM91 (C90'ish)
« Reply #4422 on: February 17, 2019, 06:04:43 PM »
Hard to believe its been almost a month since last update. But we've been staying busy. Last time, Joe had a test drive. After about 8 miles, he pulled in and the rear hub was smoking hot. But odd, it didn't really seem to affect the rolling resistance. Anyway, New bearings are on the menu, and some diagnosis. It was so long ago I can't remember if I(we) installed these or had someone else do it. AND, we put 180 miles on it with no heating issues. Damn I hate these mystery problems. Anyway, enjoy the pics. I'm going to bed. (Bought a 9 pc bearing puller/slide hammer outfit)
patented (not) axle holder
« Last Edit: February 17, 2019, 06:19:16 PM by MCRider »
Offline CBJoe
Re: Phaedrus: CB750 RestoMod - Update: 02/17/19 w/new pics.
« Reply #4423 on: February 17, 2019, 08:55:48 PM »
phew!  my shoulder just hurts looking at those bearings again  >:(
Those suckers were fused in there like crazy...that puller worked the biz though  ;)
Joe
'65 CB77
'66 CM91 (C90'ish)
« Reply #4424 on: April 19, 2019, 12:39:55 PM »
Well; I'm gong to start with an update as of today and work my way back.  We've had several shop days, with little details to accomplish. But today I flexed my otherwise atrophied muscles and got the 2 wheels loaded into the car.  Then drove them up to Ducati (what a nice shop) for a new set of Avon Road Riders. The guys remembered who I was (the guy with the purple CB750) Somebody from the shop or parts dept came out every 20 min or so to give me an update, like (or better than) they do at the hospital.
Now I don't have to feel self conscious sending Joe out on  a high speed run and fearing that the 10 year old tires would fly apart!
More soon.   ;D
