Author Topic: So are you sure you wanna buy a Mac ,huh?  (Read 7421 times)
« on: January 16, 2009, 10:28:08 PM »
expect the hot lava after one season
i took alot of little short trips  (sneak in a ride here and there ya know)
i just found this just now,   i think i have some navel jelly, but have never had good results with it,  aside from media blasting it out,  what can i do
Re: So are you sure you wanna buy a Mac ,huh?
« Reply #1 on: January 16, 2009, 10:31:18 PM »
in the past i was always against a drain hole, because ,it was my thinking that a hole drilled in the pipes would be breading ground for rust.     i see now that not having one can be just as bad.
Offline mark
« Reply #2 on: January 16, 2009, 10:33:38 PM »
.........  what can i do
get some o' them stainless ones from Benjie.
F you mark...... F you.
Offline mark
« Reply #3 on: January 16, 2009, 10:35:29 PM »
braze up the holes when they happen.
« Reply #4 on: January 16, 2009, 10:42:53 PM »
but i really like the 4 to 1  look and sound ,     wish i could find a kerger, i gave up looking long ago
maybe i'll try The Works,  i've been wanting to see that trick in action for years since i read about it here
then if that doesnt work
 i'm thinking i will go , ...blast it - coat it - wrap it - f@ck it
Offline bender01
« Reply #5 on: January 16, 2009, 10:47:08 PM »
Wow. Im  Going to pull my baffle on my 350f soon! To take a look. Ive been thinking of losing it anyway. (Might as well sound like im going fast since fast isnt an option) Ive been modifying/removing it bit by bit anyway.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Online Terry in Australia
« Reply #6 on: January 16, 2009, 11:01:43 PM »
Drill a drain hole or two Spiker, then run some two stroke fuel through yer engine occasionally, and it'll never rust out. Cheers, Terry. ;D
« Reply #7 on: January 17, 2009, 12:41:31 AM »
Why won't the two stroke oil gunk up the back of the intake valve?
KingCustomCycles.com
« Reply #8 on: January 17, 2009, 02:26:13 AM »
Your short trips are what is killing you.  Heat will eliminate that sort of condensation build-up.  If you think that is bad, imagine what kind of water has accumulated in your oil.  Oil has to reach the boiling point at least once a month, somewhere in the engine, to boil off the accumulated fuel and water.  Moral of the story? ride hard, ride long, and ride often.
« Reply #9 on: January 17, 2009, 09:32:52 AM »
 i took plenty of long rides too , more so even.   real moral here: pipes need a drain hole .
and there was nothing in the oil :P
Offline goon 1492
  • Sucka Repellant
« Reply #10 on: January 17, 2009, 10:01:11 AM »
There is a way to use electrolysis, using the same method that is used for removing rust from inside the gas tank. If I can find the link off of powerblocktv's site I will post a link.
« Reply #11 on: January 17, 2009, 10:43:41 AM »
Long trips won't undo the damage done by the short trips. Condensation occurs then rust.
Still you're correct, needs a weep hole.
Terry's idea of running some oil through the gas is clever.
Still needs a weep hole.
Or you could park it at a steep angle.  ;)
Offline johnyvilla
« Reply #12 on: January 17, 2009, 11:50:52 AM »
Spikey: That's really weird. I live in your neck of the woods, and my Mac system has no rust after two seasons.
Offline sparty
  • I just play one on TV
  • My engine is 100% stock... wink.
    • Gallery
« Reply #13 on: January 17, 2009, 12:18:56 PM »
johny, you might be running a richer bike and hence have coated your pipes with some carbon, which will deter rusting.  The insides of my Kerker have a nice thin layer of carbon because I was sure to run rich for just that purpose.  A leaner mixture with new pipes = rust in my experience.
1972 CB750 K2 Cafe' Style
GO AWAY SNOW AND COLD!  Can you see the Hot Rod wants to run...
“That's thirty minutes away. I'll be there in ten.”
« Reply #14 on: January 17, 2009, 12:36:37 PM »
i'll have to keep that in mind ..    less fuel= more air .  more air = oxidation
and i already have to rejet all over again because of the ported head.  so whateva
Offline scondon
  • Mmmm......tasty bugs
« Reply #15 on: January 17, 2009, 01:02:50 PM »
    Hypothesize, experiment, observe, and revise. All for the sake of a bigger,better mousetrap. That's where the real fun is, right Spikey. Of course the riding part is pretty fun too ;)  :)
billybobobrain
« Reply #16 on: January 17, 2009, 01:42:48 PM »
The more efficiant the burn the more moisture in the exhaust, I think I would do the "hole" thing and clean the pipe.
« Reply #17 on: January 17, 2009, 02:48:28 PM »
hit the nail on the head with that one Scondon
the Works is in fact "the business" , that stuff works fast  :o :o
now i'm coat the inside with something, not sure what yet ,
« Reply #18 on: January 17, 2009, 03:18:55 PM »
No mate, why would an occasional tankful of gas with a little two stroke oil mixed through it cause any problems? It's an old remedy for rusty pipes (and to help prevent gas tanks rusting too) that goes back to the days when our bikes were new, and the OEM pipes would often rust out in one season.
The two stroke oil mist just coats the interior of the pipe, and creates a waterproof barrier. I've never heard of this "cure" causing any problems with valves, and I suspect you'd need a heck of a lot of oil to gunk up the valves. Dirty engine oil in old worn cylinders would be a more common cause, I'd imagine.
I've also heard of guys using a cup of diesel fuel in a tank of gas to loosen up sticky valves in cars, (I put some in my oil once, which worked well in my old Ford V8 to loosen up a sticky lifter when I tried it many years ago) and even transmission fluid in the fuel, as an "upper cylinder lubricant".
I've got stainless steel pipes on my BMW K1100LT, beautifully made as you'd expect with 1.6mm wall thickness header pipes, but the problem with SS is that it's brittle, and so far I've had to weld broken header pipes up twice in three years. (not a real problem, considering the bike has now done 100,000 miles without any other repairs of note)
If you're gonna use them, make sure that the pipe is well "clamped" at either end of the pipe, I suspect that my rubber mounted, (but heavy) OEM muffler assembly occasionally "flexing" on rough Aussie roads is exacerbating the situation, and if it wasn't such a nice quiet touring device, I'd install a smaller, lighter muffler. Cheers, Terry. ;D
« Last Edit: January 23, 2009, 06:38:02 PM by Terry in Australia »
Offline scondon
« Reply #19 on: January 17, 2009, 04:08:49 PM »
   I've been using copious amounts of VHT 2000degree paint to coat the inside of my headers. I don't know about the rust preventing qualities of this paint but the smoke and the smell of the very first start-up are not to be missed.
Offline goon 1492
  • Sucka Repellant
« Reply #20 on: January 19, 2009, 04:34:12 AM »
what about using some of that cylinder fog and spray up the pipes?
Offline JLeather
« Reply #21 on: January 19, 2009, 04:46:13 AM »
I find that strange Terry.  I've run SS exhaust on my car for years, header included, with no problems.  I don't even think mine is that thick on the walls.  Must be from flexing or something.
« Reply #22 on: January 23, 2009, 06:46:24 PM »
Yeah, I think you're right mate, I meant to post a question on the BMW site I occasionally look at to see if the problem was common with my model bike, but I haven't yet. I'm assuming that the cracking is caused by the weight of the muffler assembly (big heavy thing) not well enough clamped to the frame.
It cracked the first time around 3 years ago (just before I bought it) and although the repairer did a beautiful job of welding, then polishing the repair, it cracked through the repair, and cracked through the header pipe beside it.
When I welded it this time, I also welded all the header pipes together, (the headers run parallel about 5-6mm apart at the point where they broke) so it probably won't be an issue now, although I'm tempted to add another bracket off the muffler to the frame.
I've always wanted a SS exhaust on my car, then I can build my hydrogen booster, and not worry about the pipe rusting out. Cheers, Terry. ;D
« Reply #23 on: January 23, 2009, 11:26:06 PM »
thats exactly what i did , lots of it ,    hoooly sh1t that stuff is noxious.  i mean seriously ,  filled the house ,from the garage.   if the start up smell tops that , plus smoke . ... that should be fun  ;D
coated the outside as well , and was already planning on wrapping it ,  and went back and forth on weather to use black or grey , ....at first ,black was the obvious choice.  but everyone always does black (or tan) . then i saw the grey and thought i'll go with that , ...then changed my mind again and ordered black, and the guy sent grey instead, i figured it was a sign from the bike gods that i should go with my first choice  ;D  ;D ;D
this should have been a pic of it on the bike but , i totally forgot to get the mounting hardware,..... my new head has the exhaust studs removed so i can use puurty shiny ones instead  (to bad i forgot to get um  ;D )
« Last Edit: January 23, 2009, 11:30:27 PM by spikeybike »
Offline ev0lve
« Reply #24 on: January 23, 2009, 11:58:09 PM »
Hey, would you mind giving a quick rundown of how you wrapped your headers? I picked up a used Kerker and if I can't shine the chrome up on it and get rid of the rust I'm thinking I'll wrap em. Top to bottom? Collector to top? How do you transition from 2 to 1 etc? Any tips at all cause those look pretty damn good.
Thanks
