Author Topic: What did you do to your bike today ?  (Read 3854143 times)
0 Members and 26 Guests are viewing this topic.
Offline HMBdreamer
  • Having fun on Highway 1
« Reply #27725 on: May 05, 2019, 07:41:49 PM »
Last week I paid the DMV fees and registration on my Cb750k4 that was only 16 years overdue, and today I took my two girls (9 and 12) for their first motorcycle rides! It's a day I'm sure we will all remember fondly for a long time.
It's ok if it leaks a little oil, that just means there is oil in it.
It's when it stops leaking that you should worry.
« Reply #27726 on: May 06, 2019, 03:56:19 AM »
Nice!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #27727 on: May 07, 2019, 08:27:43 AM »
Ordered brake lines for the front. I am not sure if I will get them by this weekend, so I may be off the road for another week.
Offline WhyNot2
  • I'm finally an
« Reply #27728 on: May 08, 2019, 08:39:36 AM »
Split open my little CB100 engine.
Should I use sealant or will just using the gasket be ok?
Offline MoMo
  • Ride like you're invisible
« Reply #27729 on: May 09, 2019, 06:40:24 AM »
Shouldn't need to use sealant with a proper Honda gasket. You might want to start a thread in other bikes
Offline WhyNot2
  • I'm finally an
« Reply #27730 on: May 10, 2019, 04:11:56 AM »
Thanks, will do.
Offline Tews19
  • I am no
« Reply #27731 on: May 11, 2019, 03:09:28 PM »
I finished up this 76 750 yesterday. Nice survivor, mostly original bike with new side covers from Yamiya. I also put on a set of 300s..
Sent from my SM-G955U using Tapatalk
1970 Honda CB750 survivor.
Offline setdog
« Reply #27732 on: May 11, 2019, 06:48:38 PM »
got the motor back into the frame, 73 cb750
stock motor, basically just cleaned the bottom end, new rings,
new gaskets and seals.
feels like once the motor is back in the frame the hardest part is
behind me.
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
« Reply #27733 on: May 12, 2019, 12:22:46 AM »
+3
I used an Athena gasket kit on my CB750 K2. Head gasket went on dry as all the gaskets. It is a later model gasket with 8 wider holes. Cylinder and head earlier with smaller holes so it got 8 o-rings + good 2 for oil going up.
The trick is to re-torque until nuts stops to move/gasket no longer compress. I had to tighten 3 times more after first time.
« Reply #27734 on: May 12, 2019, 04:27:01 AM »
  Lookin' good Nick !
Offline toomanybikes
« Reply #27735 on: May 12, 2019, 04:36:05 AM »
Actually was yesterday, but replaced the tires, chain, and sprockets with parts from this century (see pic) and then took her out for the first real ride. Ran into cyl4 firing problems as mentioned in a separate post.
current stable, always subject to change ...
'22 MG V85TT
'19 Triumph Scrambler XC
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
Offline Tews19
  • I am no
« Reply #27736 on: May 12, 2019, 06:23:40 PM »
  Lookin' good Nick !
Thanks Eric! She is all ready to be ridden! Now it's time to button up the K0 engine and then to restore the 69 750 I picked up not to long ago.
Offline Kelly E
  • Geriatric Hooligan
« Reply #27737 on: May 12, 2019, 06:29:46 PM »
Since I built a ramp for the wife's duck pen today I was able to install tapered roller bearings on the 73' 500, clean and rebuild the fork legs and assemble the front end. Not bad for mothers day. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline spotty
« Reply #27738 on: May 12, 2019, 07:12:05 PM »
took the back wheel out of the vmax y'day to give it a clean and paint....wheel bearing are fcuked, disc is within tolerances
tried to get the bearings out, broke my circlip pliers in the process,that put an end to that and a start to beer consumption
i blame Terry
Offline Bankerdanny
« Reply #27739 on: May 12, 2019, 07:44:10 PM »
Not what I hoped, but still a productive day.
The new brake lines that were on time for delivery by 8pm yesterday at 9am were delayed by noon and haven't shown up yet. So bike still not rideable yet.
Today I fabricated new fasteners to hold on my seat trim by welding together washers and 4mm tapered head machine screws. Then I installed the spring for my center stand. I still need to modify the stop from the Delkevic because it's too high.
Next up was properly tightening the bearings on the triple. I did a tapered conversion last year, but the front end didn't feel quite right. Once I got a pin spanner on the nut it was obvious I didn't tighten it enough when I put it together last summer.
Finally I stripped the paint off the tank and did some prep work on the tail piece.I won't have time top paint it next weekend, but it will be ready for it by the end of the day next Sunday. Now I really need to settle on a color.
« Last Edit: May 12, 2019, 07:49:22 PM by Bankerdanny »
Offline Choppedsohc
« Reply #27740 on: May 13, 2019, 03:36:03 AM »
I ordered a new reproduction wire harness and some forward controls. Small steps in the way of progress.
Offline Bankerdanny
« Reply #27741 on: May 13, 2019, 07:58:57 AM »
What a beauty Nick. When I finish up mine we need to get together for a ride.
Offline Tews19
  • I am no
« Reply #27742 on: May 13, 2019, 08:01:21 AM »
For sure Danny! I'll be riding the hopefully finished K0 or the KZ1000 this summer
Offline Maineiak07
« Reply #27743 on: May 14, 2019, 05:07:34 PM »
Not today, but this past Saturday spent two hours at the CT DMV and left with a classic plate for my 78 750F. Hasn't been on the road for the past two years after moving from WA.  Glad to be out riding again!
Offline wolf550
« Reply #27744 on: May 14, 2019, 08:40:50 PM »
switched my uni pods out for an original air box setup on my 71' cb500/550 and getting it dialed in.
74' CB550 (Sold)
71' CB500/550 (Sold)
« Reply #27745 on: May 15, 2019, 03:53:40 AM »
I bought my current "Swamp Rat" project from a guy from my home town a couple of weeks ago. It was leaning up against his shed outside, in the weather for 10 years, with no carbs, seat, tank, electrics etc, just a rusty frame, rotten wheels and a seized engine.
Terry's Swamp Rat CB750 28 Apr 2019 9 by Terry Prendergast, on Flickr
When I took the head off this was what the two cylinders with valves open looked like:
Friday K2 fiddling 3 May 2019 9b by Terry Prendergast, on Flickr
I replaced two sleeves and two pistons that an old ex-member here sent me many years ago, gave the other cylinders a good hone too, and shoved it back together.
Swamprat replacement sleeves 1 by Terry Prendergast, on Flickr
Sunday Swamp Rat fixing 5 May 2019 by Terry Prendergast, on Flickr
I cleaned the sump pan and oil pump, just to be safe, because "Safety" is my middle name.........:
Swamp Rat Sunday 12 May 2019 5 by Terry Prendergast, on Flickr
Swamp Rat Sunday 12 May 2019 4 by Terry Prendergast, on Flickr
I found an oil tank and hoses, some carbs and coils in my garage, hooked up a battery and temporary fuel tank, and fired it up.
Sweet. I need to replace the wheels as the rusty rims have holes so big you can put your fingers through them, and the tyres have all but rotted off. The frame looks OK, except for a couple of airbox tabs that someone cut off, so next job is to pull the engine, remove all the fcuked parts, and get the frame blasted so I can hit it up with some paint. Then I can turn it back into a bike. ;D
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #27746 on: May 17, 2019, 07:52:29 PM »
Replaced a broken rear turn signal stay and rode 40 miles on gravel.  Stopped by Cascade Lake for a picture.
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
« Reply #27747 on: May 18, 2019, 01:35:44 AM »
good job terry,ya make it look easy!
« Reply #27748 on: May 18, 2019, 01:55:35 AM »
Thanks Dave, these old buggers are second nature to me, I honestly don't know how many I've owned, I used to say "More than 20", but I've been saying that for years, so who knows? Check out my build thread, it's got more up to date pics and video's. ;D
http://forums.sohc4.net/index.php/topic,177220.0.html
Offline Magpie
« Reply #27749 on: May 18, 2019, 07:41:41 AM »
The beat goes on and apart it comes. I hope to have the engine on my workbench this weekend.
