Author Topic: What did you do to your bike today ?  (Read 3570725 times)
Offline BenelliSEI
  • 1969 cb750
« Reply #33375 on: June 12, 2025, 07:53:26 PM »
Put 20mi on it this afternoon. First time it's been on the road in since 2001.
Sent from my Pixel 8 Pro using Tapatalk
Nice job resurrecting your bike.
What took so you so long? 8)
Technically it only took about three and a half years to rebuild it. It sat from Nov 2001 to Nov 2021 after a bit of an accident.
Nice work! That’s a pretty unique fairing. Where from?
It's an AF Asahi No.99 Mini Sport windshield straight from Japan. Got it new from an ebay seller for $100 USD. Used by commuters, gangsters, and bosozoku riders across Japan since the '50s.
Very funky and I like it!
Offline spotty
« Reply #33376 on: June 12, 2025, 10:54:04 PM »
Started refurbish on a set of drag pipes I got from a swap meet, they had to be cut apart but have survived my brutal treatment, need a good clean and maybe assess for ceramic coating if there's too much rust damage.
i blame Terry
Offline fire113
« Reply #33377 on: June 13, 2025, 02:30:36 AM »
Nothing better than rolling together with our squeaky front brake brethren!
...mine isn't squeaky :)
« Reply #33378 on: June 13, 2025, 03:23:07 AM »
Took the K2 again and did ~80km and took some drinks and food with some cb750 friends.
Nice ride, Georg!
A gang of old CB's is never wrong!
Have you seen this thread were we can report our rides?
http://forums.sohc4.net/index.php?topic=196197.msg2306648.msg#2306648
Min 50miles (80km).
This year 25 rides in 2025. Last year 24 rides.
« Reply #33379 on: June 13, 2025, 05:56:29 AM »
well, then...maybe all turn signal buzzering together in unison?
Offline fire113
« Reply #33380 on: June 13, 2025, 01:11:22 PM »
Nice ride, Georg!
Min 50miles (80km).
...no, I didn't know, thank You for the info and the link, think next week I will do an ride about 300-350 km one way, think it will fit there.
Offline fire113
« Reply #33381 on: June 13, 2025, 01:22:53 PM »
No one of my cb's has a electronic turn signal buzzer but the idea sounds great to me to install one  ;)
Offline pickleknuckles
« Reply #33382 on: June 14, 2025, 10:04:35 AM »
Hope you had the frame checked, and il be certain bottom tree was toasted
I did. I actually replaced the trees w/a complete '76/'77 F front end dressed up w K4 tins and boots, as my trees were visibly broken and fork tubes bent to hell (hence the taller lowers and Tarozzi fork brace that can kinda be seen if you zoom in on the pic).
I also had the frame professionally checked out and straightened by Velocity Calibrations.
« Last Edit: June 14, 2025, 10:09:28 AM by pickleknuckles »
Offline fire113
« Reply #33383 on: June 15, 2025, 02:06:45 PM »
...installed the luggage straps and found out that I loast a screw from the licence plate.
Offline BenelliSEI
  • 1969 cb750
« Reply #33384 on: June 17, 2025, 01:48:01 PM »
Uncovered the K1 and the K3 to make a “to do” list. My son and I are signed up for a +600 kilometre, two day ride with the guys (and gal) from the Ganaraska CVMG section, this coming weekend. Chris lives in Toronto and expects to “arrive and ride”. No complaints, I’m really looking forward to it! We don’t often get to just buzz off on our own (he has three kids and a very busy life). Photo from the ride we took last Fall. The weather sucked, so I bailed and took the Varadero……
Offline grcamna2
« Reply #33385 on: June 17, 2025, 03:32:35 PM »
The Varadero looks to have a very protective shield  :) Did it keep you 'less wet' ?  :D
75' CB400F/'bunch o' parts'
Offline BenelliSEI
  • 1969 cb750
« Reply #33386 on: June 17, 2025, 04:11:17 PM »
It works well in light rain. It was pouring and we ended up equally wet!
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« Reply #33387 on: June 17, 2025, 05:46:20 PM »
Pulled both wheels, cleaned them up and re-balanced the tires.
Offline grcamna2
« Reply #33388 on: June 17, 2025, 09:25:01 PM »
You ride it much lately ?
Offline BenelliSEI
  • 1969 cb750
« Reply #33389 on: June 18, 2025, 04:45:34 AM »
I do. It’s Definately my “errand bike” and gets more use the the 750K’s.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #33390 on: June 18, 2025, 05:51:54 AM »
Last night I brought my first cb550 and my amen savior cb750 bikes home from my buddies place. He needed the space back. Getting his family back together.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline BenelliSEI
  • 1969 cb750
« Reply #33391 on: June 18, 2025, 07:37:49 AM »
Cleaned up the K3 for my son. We are off all weekend riding together!
« Last Edit: June 18, 2025, 06:48:51 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #33392 on: June 18, 2025, 08:05:32 AM »
Chain lube without a centre stand. Awkward!
« Reply #33393 on: June 18, 2025, 09:14:51 AM »
I use a 4" ratchet strap attached to the rear grab and piece of angle iron bolted to the ceiling joists in my garage and just "jack" it up.  Not awkward!
Offline BenelliSEI
  • 1969 cb750
« Reply #33394 on: June 18, 2025, 10:16:33 AM »
This works pretty well. It sits on the side stand and the front wheel and I just Jack the RR foot peg enough so the rear wheel is clear of the ground.
« Reply #33395 on: June 18, 2025, 11:02:29 AM »
This is how I lube chain and remove the rear wheel.
Last tire change.
Lift under left footpeg, jackstand under the other.
Pegs can rotate a little. Easy to adjust.
« Last Edit: June 18, 2025, 11:07:37 AM by PeWe »
Offline BenelliSEI
  • 1969 cb750
« Reply #33396 on: June 18, 2025, 06:14:23 PM »
PeWe…. I’ll try that. Looks very solid.
Offline BenelliSEI
  • 1969 cb750
« Reply #33397 on: June 20, 2025, 12:13:39 PM »
Ready for two full days of riding with my son and a group of the CVMG guys…..
Offline BenelliSEI
  • 1969 cb750
« Reply #33398 on: June 20, 2025, 12:17:13 PM »
This is the intercom I got for us. Work very well (almost any distance, within line of sight). They stay charged for a couple of days at least. Very clear too. Older version, quite cheap on Amazon.
Offline Dr. Frankenstein
« Reply #33399 on: June 22, 2025, 09:32:40 AM »
I installed the cam shaft AND cam chain on my 550/4 project and timed correctly!  - IN UNDER A MINUTE!!   :o  I couldn't believe it either! I must be getting Good at this...!
(Funny how that happens when you do it 8 to 10 times... ;)
