Author Topic: What did you do to your bike today ?  (Read 3563816 times)
Offline MoMo
  • Ride like you're invisible
« Reply #16600 on: January 27, 2014, 06:19:49 PM »
The 750 K7 and K8 are not the Lepers of the SOHC world.
I honestly believe that distinction should rest with the CB650....
Just saying........
Agree...Larry
« Reply #16601 on: January 27, 2014, 06:37:26 PM »
Installed valve + spring for measurement.
« Reply #16602 on: January 27, 2014, 10:46:52 PM »
...footpeg
Edit--> ...here is a picture of the K1 without the stopper.
Ah yes, the footpeg would work. Kinda lame though.  :o
My K0 and K1 don't have the little bracket welded to the frame to take up the slack in the pedal, or the little bracket welded onto the pedal. To adjust the angle, you just turn the pedal on the spline. Cheers, Terry. ;D
« Reply #16603 on: January 27, 2014, 10:51:20 PM »
Just saying........
Sorry Tim, I should have said that they're the Lepers of the SOHC750 world. I don't know much about the 650, when it came out it was too little, too late, and there were much better bikes on offer from Suzuki and Kawasaki. I'm sure they're a competent bike, just forgettable in the SOHC4's history. ;D
Offline krusty
« Reply #16604 on: January 28, 2014, 01:45:17 AM »
I restored a CB650Z a few years ago - my first sohc4 Honda. Brilliant little bike. Almost the power of the 750 without the weight.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline jonda500
« Reply #16605 on: January 28, 2014, 01:50:53 AM »
I fitted a throttle friction control to my 550F
A starter clutch thread:
« Reply #16606 on: January 28, 2014, 02:16:56 AM »
Yeah mate, looks good, but being that the Kawasaki Z650 or Suzuki GS750 was selling DOHC bikes that were faster than CB750's at the same time that the CB650 came out, it was, as I said, too little, too late. Cheers, Terry. ;D
AJK
« Reply #16607 on: January 28, 2014, 02:25:03 AM »
I ended up fixing my horn. It was actaully an enjoyable experience  ;D
http://forums.sohc4.net/index.php?topic=131276.0
« Reply #16608 on: January 28, 2014, 02:28:35 AM »
Hmmnn, that sounds suspicious! ;D
AJK
« Reply #16609 on: January 28, 2014, 02:48:16 AM »
I know, its sounds sus doesn't it. I've got rego coming up in a few months so had to get it in order. Not to mention that you need one on our OZ roads, as you well know.
PS: Is your bike yellow or gold? Looks nice.
Offline fire113
« Reply #16610 on: January 28, 2014, 08:15:47 AM »
...did a paintjob inside the K0 housings, was missing the turquoise green.
Offline harisuluv
« Reply #16611 on: January 28, 2014, 02:26:08 PM »
I fixed my pesky little K0 carb plate problem.
Offline krusty
« Reply #16612 on: January 28, 2014, 03:02:01 PM »
After stripping off the old paint from my F2 tank, I found pin holes and soldered them up. Then went over the tank with bog (Oz for bondo) to smooth out minor imperfections. Even though it was a hot day It didn't go off completely so I have to scrape it all off and do again. Maybe this should be in the pissed off thread?
« Last Edit: January 28, 2014, 03:18:15 PM by krusty »
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #16613 on: January 28, 2014, 03:06:05 PM »
Very nice.  I see a need for those....
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #16614 on: January 28, 2014, 03:51:54 PM »
At the right price there definitely is.
Offline harisuluv
« Reply #16615 on: January 28, 2014, 04:02:47 PM »
I have 10 of them.  I would sell them to forum members for..  $65 shipped?
Offline Tintop
« Reply #16616 on: January 28, 2014, 06:31:12 PM »
harisuluv, nice work....was that waterjet cut??  Kind of looks like it because of the dull inner edges.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline MoMo
« Reply #16617 on: January 28, 2014, 06:53:31 PM »
don't need one now(did before) but I think that is a fair price for very nice work...Larry
Offline harisuluv
« Reply #16618 on: January 28, 2014, 07:00:39 PM »
Exactly right, water jetted. I countersunk the holes and then lapped both sides on a granite surface plate to flatten it perfect.
Offline Vicman
« Reply #16619 on: January 28, 2014, 08:12:47 PM »
...just checked the VIN, 1087xxx has the stopper and VIN 1108xxx has no stopper  ???
My K1 doesn't have a stop either. 1084159 8)
Fluent in three languages, English, sarcasm, and profanity.
Offline Ace
« Reply #16620 on: January 28, 2014, 09:38:51 PM »
My K1 doesn't have a stopper either.
Changed master cylinders as I got one re-sleeved but the shop that did it drilled a bigger hole than they were supposed to. Now the pin hole is bigger. Filled it with fluid and got the air out. Firm lever now.
Also ran the K1 and topped it up with oil. Washed it as well. Time for a ride...I wish.
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
Offline krusty
« Reply #16621 on: January 29, 2014, 02:22:02 AM »
Took the 750F1 out for a VJMC run to Harry's Cafe de Wheels. Pie and mushy peas for dinner tonight.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline jonda500
« Reply #16622 on: January 29, 2014, 04:57:20 AM »
Pulled the trigger on a new set of 4 vacuum guages today! :)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #16623 on: January 29, 2014, 05:02:40 AM »
Picked up my muffler from the welder.
Better Half and I are moving into a house with a garage and workshop this week, so bike will be coming to me soon! No more driving to the in-laws to work on it! Things will get done MUCH faster now. Will be utilizing my father in law's chain hoist one last time to do front end work, then it is back to me for re-assembly!
--Evan
1975 CB750K "Rhonda"
Offline MoMo
« Reply #16624 on: January 29, 2014, 06:28:25 AM »
congrats on the new house and garage-always nice to have a work area...Larr
