Author Topic: What did you do to your bike today ?  (Read 3770008 times)
0 Members and 11 Guests are viewing this topic.
Offline Ace
« Reply #16850 on: March 09, 2014, 01:54:44 AM »
They both look great Adam, which one is yours? Still hot here, I'm looking forward to some cooler weather! Cheers, Terry. ;D
Your bloody kidding me Terry 'which one is yours', well it aint the blue one cause that's a K2/K3 hybrid thing!
Hit 27 degrees here today, cold southerly breeze. It will probably get to you in 3 days.
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
Offline Sgt.Pinback
« Reply #16851 on: March 09, 2014, 09:58:22 AM »
Sunday...blue sky....20°... took the Super 4 out and found some nice little roads
« Last Edit: March 09, 2014, 10:04:33 AM by Sgt.Pinback »
Doc, I love a motorcycle!
Offline fire113
« Reply #16852 on: March 09, 2014, 11:47:57 AM »
...same weather here  ;D got up early and cleaned the K0 and gave her a little bit of fresh oil and drove all day.
« Reply #16853 on: March 09, 2014, 02:52:14 PM »
Drain the oil, changed filter and realized the drain bolt thread is stripped.
The bike came to me with oil drain hole welded shut and I drilled and tapped it to 5/16 thread which was one spinning not free but close enough.
Took the pan off and this time made it M10x1.25, squared and cleaned the sealing surface and found new copper washer.  Hopefully it's gonna last now.
« Reply #16854 on: March 09, 2014, 03:29:44 PM »
Ha ha, well they both look great mate, and what do you mean "K2/K3 hybrid thing"? We didn't get K3, K4 or K5's in Oz, (it was a US/Japan thing only) so your mate's bike looks to be "Period Correct" for an Australian K2. Cheers, Terry. ;D
Offline marknpb
« Reply #16855 on: March 09, 2014, 09:21:35 PM »
I went to ride it and it wouldn't start. The fuse in one of the Hondaman relay kits ( starter button and ignition switch kits) keeps popping,
so now I get to track down a short. Yay.
It's probably one of the relays. The guy I had doing some wiring on the bike (a whole new harness, regulator, rectifier, handlebar controls, etc. )
installed the relays on the crossmember just above the head and coils. I think they're getting too hot there. I'm going to check them out tomorrow
after work and relocate them to the electrical area under the side cover. There is room, barely.
1974 CB750
too nice to cafe, going to make it nice and ride it,
looking for second frame with title to cafe out
Offline Ace
« Reply #16856 on: March 10, 2014, 03:56:28 AM »
It's a US import. K2 engine/frame with K3 particulars. That's the engine in the K2 cam shaft I got from you went into. Idles very quiet. They do both look good.
« Reply #16857 on: March 10, 2014, 07:29:11 AM »
They both look nice,I'm partial to the gold one  :).
« Last Edit: March 10, 2014, 07:30:44 AM by grcamna2 »
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #16858 on: March 10, 2014, 01:07:14 PM »
Beautiful NC day....I got to ride!!!!!  Added some more drilled holes in the baffle ends on my almost 40 year old Jardine 4-2 pipes just to open them up a little more.  Ran the rest of the winter gas out of the bike n filled her up with fresh ethanol free high test.  It felt great to be out on the road again and not dressed like an Eskimo!
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline Magpie
« Reply #16859 on: March 10, 2014, 02:28:51 PM »
« Reply #16860 on: March 10, 2014, 02:57:43 PM »
Those are nice looking gauges Magpie,are those dampeners the ones that come w/ them ? are they adjustable,how do they work ?
Offline Sgt.Pinback
« Reply #16861 on: March 10, 2014, 03:33:49 PM »
« Reply #16862 on: March 10, 2014, 03:51:14 PM »
Must be sync your carbs week, did the 550 yesterday!
« Reply #16863 on: March 11, 2014, 03:01:26 AM »
must be sync everyones carbs week?i did my mates xs650 the other day.
« Reply #16864 on: March 11, 2014, 03:32:51 AM »
Well it's my 54th birthday today, so I took the day off work so I could spend my birthday playing with my 'Wang.
The weather hasn't cooled down here yet, so my poor old 'Wang was suffering in the heat. 'Wangs are much more fun in winter than summer anyways, but as it's the only bike in my garage that's currently registered, I've been riding it in weather much better suited to my CB750.
I took it for two rides on the extra long weekend (I had yesterday off as well as it was the "Labour Day" public holiday) and both times it ran hot. Now it did run hot, despite the fact that there was plenty of nice new coolant, no leaks, the rad doesn't appear to be blocked, the thermo fan is working fine, it just ran hot.
So today I woke up early (like I do every birthday) and went out to the garage with a cup of coffee, and attacked my big black 'Wang. Like every repair job, it's always easy to rip it apart and I had the radiator out in next to no time. I tested the thermostat and the rad cap and they both seemed fine, although I decided to replace the cap with a Subaru cap I had here that looked to be in better condition. After my recent Subaru issues, and considering that the 'Wang engine is a Subaru design anyway, I "modified" the thermostat by enlarging the "Jiggle Hole", (and adding a few more) to reduce the chances of an air lock in the cooling system.
While I had everything apart, I decided to check the cam timing. When I did the engine swap a year ago I wasn't 100% happy with my valve timing attempt, but hey, the bike ran and I didn't bend any valves, so I put it's slightly "Cammy" idle and flat spot off idle down to the fact that I didn't even clean the carbs that have been ignored for the (almost) 100,000 miles that the old 'Wang has covered since 1986, on at least 3 continents.
It only took a minute to realize that the timing was retarded by a tooth on each bank of cylinders, so another 20 minutes had the timing spot on, and when I hit the starter it ran way smoother, and the "flat spot" disappeared too, so I can ignore the carbs for another 100,000 miles, or 28 years, whichever comes first.
On top of that, regardless of the near 90 deg F weather, I couldn't get it to overheat. All in all, a wonderful birthday. Excellent............ ;D
« Reply #16865 on: March 11, 2014, 03:52:31 AM »
Happy Birthday!
Offline WhyNot2
  • I'm finally an
« Reply #16866 on: March 11, 2014, 03:53:40 AM »
Yep........"Happy Birthday"...!!!
Nice way to enjoy it.
Offline MoMo
  • Ride like you're invisible
« Reply #16867 on: March 11, 2014, 04:09:13 AM »
So playing with your Wang is beneficial  ::).  Happy Birthday Terry, I just had my 67th ???...Larry
« Reply #16868 on: March 11, 2014, 04:36:15 AM »
54... sooo much...! Is It Ok anyway?
I have to enjoy my 53 that is still going on until November. Hopefully ride my CB750 this 53, last time I rode it I was 29...just a kid ::)
« Reply #16869 on: March 11, 2014, 04:48:41 AM »
I don't know why I hang out with all you geezers  :D
Offline edwardmorris
  • Youngish
« Reply #16870 on: March 11, 2014, 10:27:00 AM »
Happy Birthday Terry!
« Reply #16871 on: March 11, 2014, 11:16:06 AM »
thats the missus' job, no?   ::) ;D
Offline Tintop
« Reply #16872 on: March 11, 2014, 11:45:31 AM »
jeess your just a young pup. ;D  Happy Birthday Terry.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline nccb
  • 1974 CB750 Four
« Reply #16873 on: March 11, 2014, 12:04:28 PM »
Terry is a real man, he plays with his 'wang and then gives it to the misses when she gets home.
Wobbly
« Reply #16874 on: March 11, 2014, 12:22:18 PM »
@ Terry
Happy Birthday Old Fart! I am right behind you: April 4th, I turn 54--if I don't drop dead before that. I wish you all the best!
Tom
