Author Topic: What did you do to your bike today ?  (Read 3895322 times)
0 Members and 26 Guests are viewing this topic.
« Reply #27800 on: June 08, 2019, 06:15:44 PM »
Installed the new 915 pistons and slid the cylinders down over them. Doesn't that sound just sooooo easy. I wish.
Torqued down the head.
Tomorrow is another day to wrench.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #27801 on: June 09, 2019, 04:48:19 AM »
I havent touched either CB this weekend.
Charged the battery on the newly acquired vlx600 and spray bombed the tanl terribly. It was a awful shade of red with over spray all over the tank. The more i look at it the more i want to score a seconf lift and get it in the air beside the cb550....
Not why i got it though... Test rode it more aroind the blocl rear brake sticks a tad.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Kelly E
  • Geriatric Hooligan
« Reply #27802 on: June 09, 2019, 07:00:02 AM »
Got the 73' CB500 running yesterday. The clutch appears to be worn out. If you adjust it till it starts to work the adjuster arm hits the chain, but it runs pretty good for 37k miles.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Lou
« Reply #27803 on: June 09, 2019, 03:49:59 PM »
Thanks to some starter fluid, I finally was able to start my '73 350F after months of not it not running.
The root of its evils was the previous owner coating the gas tank with Kream. Ugh!!! I cleaned the tank several times but ended up having to buy another tank on Ebay. Had a mechanic re-build the carbs but some crap from the old tank must have made it through before I replaced the tank. It wouldn't start until I sprayed starting fluid into the carbs.
With the starting fluid, it started right away but now the engine makes a knocking sound when it idles. It didn't knock after the carbs were re-built though.
Anyone think bad gas in the carbs is causing the knocking sound at idle? It goes away over 2,000 rpm.
« Reply #27804 on: June 09, 2019, 05:55:30 PM »
It's probably coincidental Lou, pull the clutch in while it's idling, if the "knock" disappears or is much reduced with the clutch in, it means that your carbs are out of synch.
There could still be some goop in them thanks to the old Kreem, so pull them off, thoroughly clean them with carb cleaner and compressed air, (first remove the fuel needle valves, every jet, screw etc to ensure that you've blown all the crap out of all of the internal circuits) "Bench Sync" them with a piece of wire as a gauge to set each slide, then stick them back on, and see how it runs. ;D
« Reply #27805 on: June 09, 2019, 06:13:40 PM »
Got the 315 megacycle 125/75 cam and valve train installed along with the clutch cover. Cam degreeing up next.
« Last Edit: June 11, 2019, 09:46:21 AM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #27806 on: June 10, 2019, 01:24:02 PM »
  Yanked a 1975 750F out of storage Saturday.Quick history is I bought it from the older original owner back in 2013.It had sat for a long time in his garage and had things stored around it. He felt bad he could not help move it anymore and I had to laugh when I did pull it out that at one time he had painted the garage walls and painted around the bike because he could not move it. A Honda 'shadow' of a different color paint was there when I left  ;D
  Anyways the winter before last I got serious about getting it back on its feet with new tires,tune-up,fork seals blah- blah- blah-,you know the deal. Got her done and then for whatever reason put just 7 miles on it last summer and member Sean did half of those ! Got a whopping 52 miles on it now. Plan is to run it this summer a little and get some miles on her and do a little more detailing etc.. She is running and handling very nice right now and so quiet I can't hardly hear it over the wind. Must be something inside that HUGE HEAVY muffler---
« Reply #27807 on: June 10, 2019, 01:51:22 PM »
Eric, nice bike you have here!
These bikes look better and better in pristine stock look.
Offline Tews19
  • I am no
« Reply #27808 on: June 10, 2019, 02:01:42 PM »
These Fs are growing on me! Excellent find Eric!
Sent from my SM-G955U using Tapatalk
1970 Honda CB750 survivor.
« Reply #27809 on: June 10, 2019, 02:06:34 PM »
Picked up another K1 tonight. The pipes are absolutely in great shape. Not one hole, not one dent, not one ounce of rust starting on any pipe. Crazy part is I have driven past the house 4 times in the past week and never knew it was there.
Looks nice mate, has the frame been raked? ;D
Thanks Terry. She has not been raked,  merely extended fork tubes.
Nice, I like the paint job! Actually, I like the whole bike! ;D
Terry, I'm sending a bike to Aussie land and if you want the tank, side covers and seat let me know.
Thanks mate, I've sent you a PM. ;D
Offline WhyNot2
  • I'm finally an
« Reply #27810 on: June 11, 2019, 03:25:33 AM »
Finally got the mini sohc running and rideable...............
Took it for a romp around the hood.......rides good.
Just gotta tighten up the loose ends, lights, tires.......she'll be a runabout and possibly back and forth to work.
« Reply #27811 on: June 11, 2019, 09:49:04 AM »
Got the 125/75 cam degreed in. Gets easier every time you do one  ;)
Dialed in to the card numbers IO 26 BTC and IC 56 ABC with a calculated lobe center of 105 vs 106 on the card. Measured lift at .402 vs .400 on the card.
Installation day.
Offline BPellerine
« Reply #27812 on: June 11, 2019, 12:29:01 PM »
Installation day.
you are moving fast jerry!
1978 CB 750K ard and webers
another anfob
« Reply #27813 on: June 11, 2019, 06:59:57 PM »
Thanks Bill. Focused and retired:D And other than having needed 2 green main bearings I have had everything I needed. It's been 8 days so far. A little each day. I have met my daily schedules too. Not pressing myself too much.
Engine installed. All the covers installed. Oil tank installed. Chain and front sprocket installed. Dyna 2000 installed. Few things hooked up. Aired the tires.
My dwindling list still includes install CR31 carbs and Kerker. Oil. Gas. Battery. Adjust chain/rear wheel. Turn on petcock and the key. Another day for this and a day to go over it.
I wish PhotoBucket hadn't hosed us or I would have been posting progress pictures.  >:( ;D
Offline kmb69
« Reply #27814 on: June 11, 2019, 07:55:51 PM »
PhotoBucket not required. You can attach pictures directly to your post from your PC.
« Reply #27815 on: June 11, 2019, 10:41:48 PM »
If I could take them with my PC then it would be easy. They are on my phone and I do not transfer to my computer. Do you have an easy method? PhotoBucket spoiled me.
« Reply #27816 on: June 12, 2019, 01:49:43 AM »
Post from your phone.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #27817 on: June 12, 2019, 08:58:42 AM »
I often write a post on my computer at work or at the office where I can type with a regular keyboard then edit it on my phone to attach the photo. But I also post directly, like the picture of my and Sean's bikes at Gilmore last weekend.
« Reply #27818 on: June 12, 2019, 09:17:20 AM »
Thanks for trying to help guys. I'm not an accomplished hand computer telephonerist. Hell, I even use that damn thing to make calls! Too small and too many thingies to push. It does not have an icon for the forum listed under the "share" icon like it does for text and emails?? I've reverted to sending text pics when needed but that doesn't get to the general population.
Sean, Danny suggestions on how to do that?? To me this is more difficult than degreeing a cam  ;) PM if you can explain.
Thanks guys
« Reply #27819 on: June 12, 2019, 09:33:06 AM »
Hi jerry, I would probably have an easier time degreeing a cam too, as I am by no means good at this stuff.  So if I figured it out, you can too.  Hey!  A couple more lessons and I will have even ekpent texting! Lol
« Reply #27820 on: June 12, 2019, 02:56:15 PM »
LMMFAO.
Low priority.
« Reply #27821 on: June 12, 2019, 03:01:51 PM »
So..... The Kerker is on, the CR31 Special carbs are on, everything (all loose wiring I could find) is hooked up, battery is charged, 3.75qt Castrol 4T oil added with the first 2 quarts going down the valve cap holes, tank located, plugs loose for initial oil pressurization.
Gotta install the throttle cables and gas the #$%* up!!  ;D ;D ;D Oh yeah, check the ignition timing on the Dyna 2000.
Beer30 now. Video tomorrow (maybe, depends on the bike and the video posting BS).
« Reply #27822 on: June 12, 2019, 04:43:08 PM »
Join flickr.com Jerry, even better than Photofukit.  Snap a pic on your iphone and then share it directly to your Flickr acct.
https://www.flickr.com/
« Reply #27823 on: June 12, 2019, 06:14:13 PM »
Android too? Copy and paste link like Photofukit? Forgot about Flickr. Thanks
Looking promising except the battery. Shows 12+/13+ coming off the Tender, hit the starter, turns fairly slowly then the voltage drops to mid 11's. Load test it tomorrow and replace it, install some gas and hit the starter. It is turning albiet slowly. Need better rpms to get the oil pressure up. O'Reilly's has an AGM battery with 220 CCA.
« Last Edit: June 12, 2019, 06:18:14 PM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #27824 on: June 13, 2019, 01:32:04 PM »
Throttle cables installed. Don't like the feel but it will do for now.
Took the battery to O'Reilly's for a load test. He put it on HIS charger for 28 minutes and it tested good. Back home I installed it. Turns over better but not as fast as the 1000. Second pull the pressure popped!
Still need to set the timing advance. Waiting on info for that. Replace the plugs and attach the wires. Running outta #$%* to do except for the starter button.
Anticipation and a gas tank.
