Author Topic: What did you do to your bike today ?  (Read 3764808 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #28450 on: April 26, 2020, 10:32:11 PM »
Put some air in the tires and ran it down the farm roads.
Did an oil change when we got back.
Offline spotty
« Reply #28451 on: April 27, 2020, 01:43:03 AM »
Got my new vacuum bleeder today so did the clutch and front brakes on the zzr
No result on the clutch so it seems the m/c is probably shagged
Minor result on the brakes so probably some air hiding in there somewhere ( new lines)
Being all enthusiastic I got the vmax up on the lift and flushed the fluid on the clutch and front brakes , all went well and the from brakes are now rock hard, just how they should be
Changed the oil while it was up there and just realised I forgot to change the filter
 Bollocks
Will have to do that tomorrow and balance the carbs while I'm at it
i blame Terry
Online Stev-o
« Reply #28452 on: April 27, 2020, 07:03:17 AM »
   Fired up my ever faithful Freedom Green K4 750 Friday after its long winter slumber. Did not do any 'winterization', just parked it.
Hey Eric...you didnt drain the carbs or tank? Thats amazing in this day with ethanol fuel.
Offline fire113
« Reply #28453 on: April 27, 2020, 04:39:49 PM »
...punched out the fork legs and cleaned them. Think I am going to polish them.
As I took a clother look at the front wheel :-X I found a wrong hub.
Think it is an complete K1 wheel.
Have a good one...Georg
« Last Edit: April 27, 2020, 04:42:29 PM by fire113 »
« Reply #28454 on: April 27, 2020, 04:56:26 PM »
Nope,I just parked it after a ride in late September or early October and walked away from it to finish the season on another bike. I pulled the battery when the season was officially over and kept it on a tender. I did not fiddle with or start the bike or anything all winter. Rode it again today and all is fine running wise but had to cut it short as it started to rain. Always been lucky being lazy I guess. Might drop a carb bowl or two though just to take a peek inside. Have to fire up some big Suzuki's next - fingers crossed !!
« Last Edit: April 27, 2020, 09:20:10 PM by ekpent »
Offline Tews19
  • I am no
« Reply #28455 on: April 27, 2020, 05:38:43 PM »
Picked this up yesterday.  Cleaned the front caliper today and swapped on the ducktail... Then took her for a spin.  This summer's rider.
Sent from my SM-G955U using Tapatalk
1970 Honda CB750 survivor.
« Reply #28456 on: April 27, 2020, 09:24:54 PM »
Nice K1 Nick. Sounds like a runner right out of the box then without having to do muck work. Did the PO restore it or is it mostly original ? You have had them in the past,very nice runners.  Is your new CBX up and running also ?  Save some nice bikes out there for us lowlifes  ;D ;D
Online BenelliSEI
« Reply #28457 on: April 28, 2020, 01:15:11 PM »
Georg....... WHAT did you paint that oil tank with?
Online Stev-o
« Reply #28458 on: April 28, 2020, 01:48:29 PM »
Nice K1 Nick.  Save some nice bikes out there for us lowlifes  ;D ;D
He's been gettin' em all, Eric.  Guy must sleep with his smartphone and get fakebook alerts!
He picked that CBX out of my Texas jurisdiction!!
Offline BoneDigger
« Reply #28459 on: April 28, 2020, 06:03:58 PM »
Fixed the horn on my 1972 CB750.  Was on eBay looking for used ones, only to see scores of non-working ones going for 15 to 25 bucks.  Saturated at that, I came to the forums here to see if anyone has fixed these before.  Hmmm, a few threads.  OK, I'll try it.  Took the horn apart, cleaned it up a bit, played around with how tight to screw everything back together, and suddenly had a working horn again.  A bit of touch up paint, and I'll install it in a day or two.
« Reply #28460 on: April 28, 2020, 09:18:37 PM »
Hey Georg, how are you mate? If that's a late model K0, it will probably have a K0 disc on a K1 hub, I've found a couple like that that were built near the end of the production run, when Honda was just slapping together what parts they had. ;D
Offline Tews19
  • I am no
« Reply #28461 on: April 29, 2020, 07:55:08 AM »
She is a runner as the PO stored it w 100AV gas. I did pull the carbs yesterday and cleaned them in the Ultrasonic cleaner. Tires have low miles with the paint lines still on them. They are 8 yrs old. I assumed they were new but after talking to the PO he said otherwise. As for the K1, it's original minus the 341s and hand controls. I have the original hand controls as he gave them to me. I'll post a few more pics once I get her together.
As for the CBX, she is still sitting in the garage and a non runner.
« Last Edit: April 29, 2020, 08:00:55 AM by Tews19 »
Offline 750K5
  • agentsmith5
« Reply #28462 on: April 29, 2020, 09:47:39 AM »
Tires mounted and balanced.  Engine mocked up in frame.  Currently waiting for parts while polishing sprocket hub and brake.
« Reply #28463 on: May 07, 2020, 12:24:18 PM »
I made the 900 an 'onest woman today.  ;D
No more running round with borrowed licensed plate, she has her own, plus stickers and I just got her inspected.
Online PeWe
« Reply #28464 on: May 09, 2020, 10:21:58 AM »
2 rides today to finalize carb jetting.
First a shorter of 70km. Back to garage, tank off and raised the needles 1 notch.
Back on the road and enjoyed a 200km ride, mostly in legal speeds except when testing how much better it pulls with higher needles when twisting from 4000rpm on 5:th gear. Same power up to almost 8000 rpm!
When back home changed main jets, 1 step smaller from 147.5 to 145.
Look forward to next ride cruising around in legal speeds, low fuel consumption, 53mpg.
Probably less if not twisting to check main jets! :D
55mpg is possible if riding 70-90kmh (43-56mph) ;)
Those 147.5 Mikuni jets were earlier mounted in my stock K6 Keihin carbs with pods, 836cc, ported head and cam. Ran fine in the 80's. Not too rich! 3 long tourings in Europe.
Same jets too rich on my TMR32 carbs , same engine, now 1000cc  ;)  Strange.... Different fuel 30-35 years ago.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #28465 on: May 09, 2020, 12:05:30 PM »
Didn't do anything to my bike other than order a new battery as the existing one doesn't want to hold a charge. A new Bikemaster Platinum AGM will arrive Monday.
I did a couple things to the 750F3 I bought for my buddy a while back, a fresh seatcover and new superbike bar and new grips
« Reply #28466 on: May 09, 2020, 12:16:21 PM »
Red got rebuilt PD carburetors and I took her for a spin.  Holy #$%*, what a difference!  She will rev to 8 000 in second gear and third gear and that's how far I got, she is too fast for my local roads.  No more problem accelerating in 5th.
Still want to get a 78 F air box and reroute throttle cables and figure out an adapter for the petcock, but what a difference.
« Reply #28467 on: May 10, 2020, 05:12:29 AM »
Just be careful when you get that F airbox mate, your K series sidecovers won't quite fit (the K7/8 and F2/3 airbox is slightly wider) and if you give them a whack to pop the knobs thru the rubbers, you'll crack them. Don't ask me how I know......... ;D
Offline Jarrett_Honda
« Reply #28468 on: May 10, 2020, 07:42:05 AM »
Replaced the Fork Oil for the first time. Looked more like mud than oil. There also was not very much in the forks.
I'm waiting on new brake pads and shoes to arrive. I might have to stop riding for awhile until new brakes get here. My stopping power is fading and the brakes are getting loud.
Sent from my SM-N950U using Tapatalk
« Reply #28469 on: May 10, 2020, 07:42:17 AM »
Good to know, I guess I will widen up holes in the old airbox than.
Thanks, Terry.
« Reply #28470 on: May 10, 2020, 11:20:22 PM »
Thanks, Terry.
That's probably what I should have done mate, good idea. ;D
  • Holy Cow! I'm a
« Reply #28471 on: May 11, 2020, 08:51:46 PM »
Found a shiny cargo plate in the local parts shed.
A few fasteners, some cuts and a couple of holes later, got it fixed to the fj.  Drilled a couple more holes to get hooks through.
Project cost $38 and two (drill) bits.
« Reply #28472 on: May 12, 2020, 03:59:20 AM »
Looks good!
Offline Bankerdanny
« Reply #28473 on: May 13, 2020, 04:40:12 PM »
Yesterday I installed my new AGM battery in the 750 and hooked up the maintenance charger to top it off. Today I pulled the advancer and cut a coil off each spring. Tomorrow I redo the timing, double check the point gap then deep dive the ignition wiring. Hopefully by the weekend I will get out for the first ride of the year
Online PeWe
« Reply #28474 on: May 14, 2020, 12:31:45 PM »
Changed plugs on my K6 again. It had new Denso X24ES-U to verify fuel consumption after NGK D8EA that replaced another set of Denso a little bit fouled by carb jets testing.
Now Denso IX24 to give my old and not much used Iridium plugs another ride when carbs work much better.
Denso Iridium is a resistor plug.  NGK cap on that will end up in 5+5kohm.
I'm eager to see the result when weather turn back to rideable without snow, hail and rain I had had the last days.
The tests of carb jets is finalized with a sync.
Now ride tests of plugs. A 100km long ride in legal speeds, refill tank and see how much fuel. Check how plugs will look like.
Edit: Not worth the 4-5 x price than std Denso X24ES-U.
Maybe better with 0 ohm caps if found.
« Last Edit: May 17, 2020, 06:25:06 PM by PeWe »
