Author Topic: Anyone shim out their second rotor instead of the caliper?  (Read 6733 times)
Offline mrrch
« on: August 04, 2010, 07:39:22 PM »
I'm going with dual disks up front on my 750 and I understand that the second caliper mount needs to be shimmed out to line up properly. I was going to shim out the disk instead (I'm using an electronic speedo so there will be no cable fitment problems.
Anyone one else done it this way? any tips?
Thanks
Ray
my build
Offline Shenanigans
  • Right turn?
Re: Anyone shim out their second rotor instead of the caliper?
« Reply #1 on: August 04, 2010, 08:02:06 PM »
I have only done one dual disk conversion but if I remember right the shimming was not to bring the disk in the right spot, but to even out the second caliper mounts because they were not flush with each other from the factory. I also think there is also very little room between the disk and the fork leg and the disk when you add that second disk.
I think anyways...
« Last Edit: August 04, 2010, 11:04:45 PM by Shenanigans »
Online scottly
« Reply #2 on: August 04, 2010, 09:21:12 PM »
If any shims are needed, shim the caliper. What year 750 forks are you adding the right-side brake to, Ray? The earlier forks have different caliper mounts.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: August 04, 2010, 10:00:05 PM »
I filed off what was to high on the fork itself.
Online scottly
« Reply #4 on: August 04, 2010, 10:08:54 PM »
What year forks, seaweb? Got any pics?
Online scottly
« Reply #6 on: August 04, 2010, 10:45:58 PM »
My 78k no photos.
So with 78k forks, and "T" caliper mounts, you had to file the fork bosses off? Was this to center the caliper over the disk, or to make the pads parallel with the disc? Was more material removed from one boss more than the others?
Offline scunny
  • don't call me expert
« Reply #7 on: August 04, 2010, 10:53:00 PM »
My 78k no photos.
I think MC Rider mentions this in his build
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Online scottly
« Reply #8 on: August 04, 2010, 11:00:01 PM »
Well, I guess it's a bit of a moot point for now, as I have been unsuccessful locating a later caliper with a bracket. :( Also, I'm not planning on running a speedo, so that may affect the spacing.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #9 on: August 04, 2010, 11:58:47 PM »
My 78k no photos.
One of the mounting areas on the top is high, so it's to make it parallel.
Offline mrrch
« Reply #10 on: August 05, 2010, 05:44:51 AM »
My bike is a 77 CB750K. The speedo drive side disk sits closer to the centerline of wheel because of the speedo cable. The tabs look the same on both fork legs but I will double check and make sure all the tabs are parallel. I've seen the caliper mounts shimmed up with washers but I want a cleaner look.
my build
Offline kos
    • m3racing.com
« Reply #11 on: August 05, 2010, 07:41:39 AM »
Shimming out the rotor is the proper way to do this and in fact was they way Honda did this on kit bikes. Part #44642.300-970 spacer plate was offered in kit parts listing.
KOS
220...221, whatever it takes.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #12 on: August 05, 2010, 11:29:00 AM »
Although I don't have the parts to look at here, I am reading from my notes.  I did this last year and made a 2mm spacer which put both fork legs at 4.15mm from the discs, CB750F1 1976.
http://i192.photobucket.com/albums/z293/galaxy8155/spacer.jpg[/img]]
This meant I only ended up filing about 2.5mm off one of the mounts on the fork leg to make the caliper line up and run parallel.  be very careful, I nearly took too much off!
I also intend to run an electric speedo, so one side of the axel has the normal 17mm wide spacer and the other side I have had made a 28mm wide spacer, which has a large flange incorporated to protect the wheel bearings.  Sorry no photo of this.
http://i192.photobucket.com/albums/z293/galaxy8155/DSC02498.jpg[/img]]
http://i192.photobucket.com/albums/z293/galaxy8155/DSC02499.jpg[/img]]
Note that the adjuster has to have the lock nut on the inside of the added caliper!
Offline SKTP
« Reply #13 on: August 06, 2010, 09:51:36 AM »
This is the first I have heard of this...don't most people file their forks? Adding this 2mm spacer sounds like a much more elegant solution
I pray to HONDAMAN for spacer confirmation  :)
edit* I just read Gamma's post more thoroughly and you still have to file with the spacer...so the fork-mounts are about 4.5mm too tall generally? That seems like a lot...
« Last Edit: August 06, 2010, 12:09:45 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline mrrch
« Reply #14 on: August 06, 2010, 11:55:39 AM »
I looked at my fork tubes last night and one of the 8mm lugs is too long and would require filing to let the T bracket sit properly. I'll try to remember to take a picture and post tonight showing the lugs.
my build
Offline mrrch
« Reply #15 on: August 07, 2010, 06:35:21 PM »
Here is the picture of the lugs on the fork legs. The lug that the 8mm bolt goes into is slightly longer on the leg ion the right in the picture.
my build
Online scottly
« Reply #16 on: August 07, 2010, 06:46:29 PM »
I couldn't see it in the picture, until I held a ruler up to the screen: the boss on the right is definitely longer. I haven't had a chance to look at mine yet.
Offline mrrch
« Reply #17 on: August 07, 2010, 07:04:47 PM »
I take lots of pictures when I do the conversion (hopefully this week) and post.
my build
Online scottly
« Reply #18 on: August 07, 2010, 07:07:18 PM »
Thanks. I will be watching...
Offline Tintop
« Reply #19 on: August 07, 2010, 07:30:23 PM »
will also be watching with interest.
I am finishing a dual disk on my 550, but with the calipers on the back.  My leg with the longer boss is now on the left.  From this thread it looks like I can either put spacers behind the upper bolts, and then shim the disk / or just file the boss to get the proper alignment.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #20 on: August 08, 2010, 08:03:32 AM »
You can also thin the flanged section of the pivot bolt instead of the forkleg boss. See picture (this is a 550). Remember the caliper bracket can become close to the leg. Everything becomes clear what needs to be shimmed or machined when the parts are mock mounted.
I just made a 1.5mm rotor shim to make both equidistant from the forklegs for another project but am using different calipers. Two other bikes I didn't bother.
« Reply #21 on: August 08, 2010, 09:04:05 AM »
Been off this thread a bit..
 On my 73, I have shimmed (and maybe even reversed) the top mount for the 2nd caliper, then shim the the other one..end of problem.. I would rather do that than file the fork.
 Would I move the disc out.. no way.. Reason try changing a tire or fixing a flat on side of the road,, I could do mine with fender and calipers on.. Id hard enough to get a dual disc wheel off, let alone start removing fender or caliper, to fix a flat..
 The adjusters.. after the first time removing the wheel with dual disc, I took them out forever.. and never looked back. Yeah some folks feel there is a need for them, but I never missed them... just too big a PITA for a ridden road bike...
 Scottly..if you still need a calper and bracket PM me, I will start looking..
« Last Edit: August 08, 2010, 10:23:11 AM by 754 »
Offline Tintop
« Reply #22 on: August 08, 2010, 03:17:40 PM »
thanks bwaller - great suggestion, will check this out tomorrow.  everything is mocked up, just need to get correct measurement of the change required.  Removing a couple of mm's from the lower mount makes more sense than filing the boss.  If I still feel a shim is needed, I can get it cut by the waterjet guys quickly.
Tintop
77 CB550 Cafe build
« Reply #23 on: August 08, 2010, 03:20:28 PM »
Boy that assembly looks tight and clean Brent. You rule.
« Reply #24 on: August 10, 2010, 10:19:18 AM »
Geez, I weighed the calipers yesterday. Both halves, bolts, no piston, non moving pad..
Finned was 802 grams
77/78 was 625 grams..
