Author Topic: What sprocket size you running? CB750  (Read 30633 times)
Offline brandEn
« on: May 15, 2011, 05:24:47 PM »
At the risk of getting flamed I am asking... What size sprockets/gearing you using?
After a few miles on my new build I am thinking the 17T front 48T rear with 630 chain is in need of a change. I don't anticipate much slab time with this bike so I am thinking about changing sprockets size for a bit more pep. Thoughts? Input?
« Last Edit: May 15, 2011, 05:36:46 PM by brandEn »
Offline Gordon
  • 750K1, 550K2
Re: What sprocket size you running? CB750
« Reply #1 on: May 15, 2011, 05:28:06 PM »
Going with a smaller rear sprocket will do the opposite of giving the bike more "pep".  You either need a smaller front sprocket or larger rear (or a combination of both) to increase the low-end torque.
Offline brandEn
« Reply #2 on: May 15, 2011, 05:31:07 PM »
Ah, thanks for the clarification. Now that I think about it that makes sense. Thats why those stunt bikes have those huge rear sprockets.
fixed...
« Last Edit: May 15, 2011, 05:37:13 PM by brandEn »
Offline tweakin
  • tear down
« Reply #3 on: May 15, 2011, 06:01:16 PM »
Dude,  Why don't you at least get more than 50 miles on the thing before you think about changing the gearing.  J/K,  ;D
edit: you are worse than me...
Offline brandEn
« Reply #4 on: May 15, 2011, 06:08:18 PM »
haha, 50 miles? How bout 79.3! Yea get some!
Offline brandEn
« Reply #5 on: May 15, 2011, 06:09:05 PM »
 And by the way...nobody is worse than you!
 ;D
Offline wookie
  • I would get up if i knew i fell
« Reply #6 on: May 15, 2011, 07:22:17 PM »
Break your motor in, get it tuned properly and then think about gearing.  I run a 17/48 520 with no complaints.
J
Online Don R
« Reply #7 on: May 15, 2011, 08:26:12 PM »
Way back in the olden days we used a 17 on the front for performance, sometimes with a 50 rear then an 18 / 48 for highway use. If we were pushing a windjammer or a lot of weight we left the 17 on all the time
« Reply #8 on: May 15, 2011, 08:26:13 PM »
The 17/48 combo is usually with a 530 chain. The increase in size to a 630 drops the number of sprocket teeth front and rear. Sure we're talking about the same thing?
In my opinion 17/48 is the best al around compromise, as the stock setup was 18/48. You could go to a 16/48 but you'd be turning alot of revs at highway speeds. Increasing the rear may foul the chainguard, if you're running one.
Wookie: I didn't know there was a 520 conversion either. Sources?
Offline brandEn
Re: Re: What sprocket size you running? CB750
« Reply #9 on: May 15, 2011, 10:46:01 PM »
Thanks for the input. Yes I am running JT sprockets 17 up front and 48 rear with a 630 DID chain. What ratio is that comparable to with a 530 chain?
« Reply #10 on: May 16, 2011, 04:41:56 AM »
If in fact you have a 17/48, its the same ratio as any other 17/48. The chain size doesn't change the ratio. But your sig says its a 78 750F and they came with a 14/43 using a 630 chain, which is "more power" than a 17/48 ratio.
« Last Edit: May 16, 2011, 04:44:55 AM by MCRider »
Offline wookie
« Reply #11 on: May 16, 2011, 06:27:37 PM »
Yeah, it was something that cycle x offered at one time.  O-ring chain, decent quality, so far so good.
J
« Reply #12 on: May 16, 2011, 06:36:14 PM »
SNIP
J
Cool. No reason a modern 520 can't be used. Such a conversion is hot setup on HawkGTs (I have one) and many make a lot more hp than our CBs ever will.  Much lighter.
Offline TaylorG
  • Restoring a 78 750f
  • Restoring my childhood 750f
« Reply #13 on: May 28, 2011, 11:58:34 AM »
Hmm, I got my 750f running and replaced the rear sprocket and chain with what I thought was the stock sprocket combo: 14/43 630 chain.  I road tested the bike and gearing seems way off.  I'm in second before I'm out of first and at 60, the RPM's are screaming!  Should I look at a new gearing combo?  17/48?  Or do I have another problem?  With the exception of a leaky carb, bike starts, runs and sounds great.  Any thoughts from the forum would be really appreciated.
« Reply #14 on: May 28, 2011, 01:04:15 PM »
 I am sure its 530 chain, if you have 17/48
 17 /54 is fun on the street, just change to 19 for longer distances..
 Any 530 can be switched to 520, just thin the sprockets..
Offline Spanner 1
« Reply #15 on: May 28, 2011, 02:58:28 PM »
17/48 K1 750 @ 60 mph 5th. gear = exactly 4,000 rpms....... nice :) ;D
Offline Tripps
  • Perpetual Beginner
  • 1978 CB750K
« Reply #16 on: May 28, 2011, 06:24:57 PM »
?Stock?  78 750K, 4200 at 60 mph.
The greatest obstacle to discovery is not ignorance, it is the illusion of knowledge- Daniel J Boorstin
Offline Spiider
  • '73 CB750k
« Reply #17 on: May 28, 2011, 06:29:21 PM »
17/48 with a 530 chain.
Offline InAquaVeritas
« Reply #18 on: April 04, 2015, 12:02:28 PM »
I'm bringing this topic back to life a little, since I'm in the process of deciding what front sprocket to get and might as well go with the info here so far. What are the experiences from the option above?
It's 78 F2 engine and I've got a brand new 43 520 rear which I would like to keep if possible. Tire circumference is a little smaller: 2074.7 stock mm vs 1959.7 mm current. It's a 160/60/17 wheel/tire. I'm not sure what to get for the front.
The engine is stock, with a ported head, so I've got a little bit more power. Will be running a bread box style air box, because pods won't work well in wet and windy weather, and the stock one doesn't look too good. I know the bread box is far from perfect and doesn't flow as well as the stock.
The F's came with a 14/43 630, for a little bit of extra power and ran that initially. I liked it, but it's a little high revving on the highway. It will be both a city and highway bike, but mainly highway.
What are the best options? Including changing out the rear, but preferably keep it.
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline Bailgang
  • Scott
  • Indiana
« Reply #19 on: April 04, 2015, 01:54:39 PM »
My 77 F2 currently has 15/43 with 630 chain. It ran just fine with the 14 tooth front sprocket but I threw the 15 tooth in just to bring the rpms down a bit on the highway but my left foot is still searching for that phantom 6th gear from time to time. :)
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #20 on: April 05, 2015, 03:07:00 PM »
I liked 17/48 with 530 chain back in the 80's. Even on long touring in Europe
Had it last year but the bike was screaming too much with my load 4-1 so I went back to K stock 18/48. Still very load!
Offline Spanner 1
« Reply #21 on: April 05, 2015, 07:50:03 PM »
I just did the conversion from ( stock ) 630 chain and 15F, 41R sprockets to 530 chain and 17F, 48R sprockets.... and the final drive ratio is almost exactly the same... on my K8 and love it !
Online scottly
« Reply #22 on: April 05, 2015, 08:07:55 PM »
To use a 43 tooth rear, you would need a 15 tooth front sprocket to get close to the same ratio as the preferred 17/48 combo for 5xx series chain. The smaller pitch diameter of a 15 tooth 5xx sprocket is harder on the chain and sprocket than a larger 15 tooth 6xx sprocket.
Offline enwri
  • So that noise is normal?
« Reply #23 on: April 05, 2015, 10:27:21 PM »
That's about what I get with a 16 x 38, 630 and 17 inch wheel on my 77 K.
I'm not sure if I could get a 17 front sprocket on, there's not much room left in there.
Approx 80kph/50mph in first, about 2600 at 60kph/37mph,  100kph/60mph  4200, 160kph/100mph at somewhere between 6500 and 7500, depending on when you look at it.
 Was even taller with the 18 inch wheel. 2200 at 37mph, 3800 at 60mph, 100mph at 6000.
At least I don't have to worry about unexpected wheelstands.
(above results were obtained using 35+ year old Honda instruments of unknown history).
Too tall for regular two-up riding, IMO. I'm 70kg and rarely go two-up. Can't go over 6000 (speed limit in first gear,) unless I'm on the highway.
« Last Edit: April 06, 2015, 02:30:35 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #24 on: April 06, 2015, 12:30:18 AM »
Use the Excel file to check. Found it on this forum. Rear wheel (with tire) diameter is an important parameter too.
I have added kmh.
