Author Topic: Installing a shop sink in my basement. What to use for countertop?  (Read 1369 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
I've been needing a sink in my basement/garage for a while now.. so I picked up a really decent 2'x2' (approx) sink with hardware for cheap at the local Habitat Home Store. I've built a fixture for it to go in with pressure-treated 2x4's and some OSB for the top. Need something to go over the OSB though.. cheap, durable, and easy to install. I thought about just painting the OSB and caulking the edges but I want something more durable. Thoughts?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: Installing a shop sink in my basement. What to use for countertop?
« Reply #1 on: April 12, 2012, 09:31:41 AM »
If it's really a 'shop' basement, I'd say stainless steel...but I don't know how pretty you need it to look.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: April 12, 2012, 09:45:49 AM »
Stainless sheet would be my 1st suggestion too. In lieu of that (pricey) you might try 1/4" hardboard (or "pressboard", like clipboards are usually made of) but I don't know how well it would hold up to water. As the hardboard gets beat up you can always add another layer of 1/8" hardboard right over top. A butcher block top would hold up well but that would also be pricey.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: April 12, 2012, 09:55:12 AM »
...then take your grinder to it and give it a good once over.  it'll give it a nice surface design
Offline jamesb
« Reply #4 on: April 12, 2012, 11:26:27 AM »
try some linoleum you can get remnants at lowes or home depot pretty cheaplay it out on what you need cut your hole for the sink then glue it down.
Offline rb550four
« Reply #5 on: April 12, 2012, 08:09:08 PM »
Have you considered cementboard?  Comes in 1/4", 1/2" , 3'x5' and 4x8'
Hardibacker not effected by water., can run a torch on it won't burn. cut with grinder w/ cement wheel  around $13 per sheet
Offline faux fiddy
  • bike in a box
« Reply #6 on: April 12, 2012, 11:28:03 PM »
You can lay tile on it readily, too.
Look back at your habitat store, I found a small pice of granite cheap. Usually porcelain tile for >75 a sq/foot , too. Harbor Freight has circular and recip  blades that are supposed to cut rock.
« Last Edit: April 12, 2012, 11:29:56 PM by fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline MoMo
  • Ride like you're invisible
« Reply #7 on: April 13, 2012, 03:38:30 AM »
If you do go with OSB use an oil base primer, you can then put latex over it.  The Hardibacker is a good idea, the edges would be a bit rough so you'd need to trim that off...Larry
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #8 on: April 13, 2012, 11:49:00 AM »
You could always go with cast concrete.
« Reply #9 on: April 13, 2012, 03:25:17 PM »
You might check a few lumberyards for a junk/ mismeasured counter top. Galvanized steel might work for you too.
