Author Topic: serious clutch issue "STILL!" Help!  (Read 4369 times)
Offline Sixgunsrattlesnake
  • Blue Collar Renovator
  • SEMPER PARATUS
« on: May 06, 2013, 01:59:49 PM »
Ok, so I just finished my bike. Took her out for a shakedown run. no issues. Went 25 miles to the next town, ate some lunch, fired her up and went over to a buddies house to rub in the fact that mine was complete and his wasn't. pulled in my clutch lever, and bam, right there in his driveway my case broke. it seems to have broke under the pressure of the clutch actuator? I don't know. anyone have an Idea why this happened. i'm going to replace it (obviously) but I would be double mad if it did it again....
« Last Edit: May 17, 2013, 09:43:30 AM by Sixgunsrattlesnake »
"He wore his gun outside his pants, for all the honest world to fear."
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
Offline greenjeans
  • 1972 CB750K2
Re: serious clutch issue
« Reply #1 on: May 06, 2013, 02:25:27 PM »
Don't usually/ever see that happening.   I wouldn't worry about it happening again.
You have the correct number of steels & plates in there ?
You didn't notice any horrible vibrations in the motor did you ?
« Reply #2 on: May 06, 2013, 02:42:09 PM »
Man! You or someone else been in there?
  • SEMPER PARATUS
« Reply #3 on: May 06, 2013, 02:45:17 PM »
I fought with the number of steels/plates all winter. Finally got it right. Everything else was smooth. No issues. Then as i went to stop in my buddies driveway i pulled in my lever, felt a little resistence then boom.
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
  • SEMPER PARATUS
« Reply #4 on: May 06, 2013, 02:47:06 PM »
Yeah, me. Lol. But i checked and double checked tge number of plates. Put in new fiber plates. Felt great until this
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
Offline CycleRanger
  • No comment about being an
« Reply #5 on: May 06, 2013, 02:51:21 PM »
What kind of springs did you install?
Offline bjbuchanan
« Reply #6 on: May 06, 2013, 04:49:45 PM »
Springs or stack height I think
I dropped you a pm also
Get it diagnosed first before attempting anything with a new cover
Offline SONIC
    • Walnut Wood Works
« Reply #7 on: May 06, 2013, 04:58:31 PM »
Karma for rubbing it in obviously ;)
  • SEMPER PARATUS
« Reply #8 on: May 06, 2013, 06:01:28 PM »
stock springs. NOS i found.
Stack height? not familiar
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
  • SEMPER PARATUS
« Reply #9 on: May 06, 2013, 06:55:20 PM »
exactly what I was thinking.... stupid me. but now my bike is blocking his work space. hahaha
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
Offline bjbuchanan
« Reply #10 on: May 06, 2013, 08:50:20 PM »
Though I don't think it was a tightening procedure issue, from what I have seen it looks like a different failure but here are some good threads I dredged up for you
http://forums.sohc4.net/index.php?topic=106700.0
http://forums.sohc4.net/index.php?topic=37507.0
First two prob aren't too much help directly but maybe indirectly glean some info from it.
The third link this guy broke the cover just like you so I would read through the whole shebang. Has to do with clutch plates, thickness, springs, all types of good stuff. He resolves it at the end too
http://forums.sohc4.net/index.php?topic=109380.0;nowap
  • SEMPER PARATUS
« Reply #11 on: May 08, 2013, 04:51:56 PM »
Ordered a new cover today. Waiting for it to show up. Still cant figure out what happened. The best i can recall is when i took off the cover after it had tried to blow open, i did not find nut lock nut on tge actuator. Lets say that it vibrated off. Ive got another picture of the basket ill post tonite, but could that have anything to do with it. Wouldnt my clutch lever just be out of adjustment? What would cause lever resistence, enough to try and force my actuator out of the case.
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
  • SEMPER PARATUS
« Reply #12 on: May 08, 2013, 07:14:48 PM »
SO i got the bike home today from my buddies house. Inspected my clutch basket a little better, this is what I saw. Then I noticed that I had some freeplay in the basket. I could grab it and pull it out and in a little. maybe a 1/8th inch. removed my springs and fount that the basket nut had backed off. I set the retainer, at least I am pretty sure I did. so when it backed out, it allowed the clutch basket to move outboard, maybe jump a tooth so when I pulled in the lever it met full resistance? Just speculating. I am going to inspect whats there, wait for the new parts, and give her another try.
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
Offline Tews19
  • I am no
« Reply #13 on: May 08, 2013, 07:26:06 PM »
What kind of gun is that in your avatar? I recently bought my first hand gun, springfield xdm.
1970 Honda CB750 survivor.
  • SEMPER PARATUS
« Reply #14 on: May 08, 2013, 07:41:45 PM »
BARF!
no offense, sorry. I'm not an XD fan. GLOCKs, XDs, and the like are not my thing. but at least you got a gun so thats what counts. Seriously, I didn't intend to offend you, just not a fan.
That in my avatar is my Ruger Blackhawk .357 mag... just one of my babies. I actually named my First born son after that gun, no kidding...
I hope you enjoy that XD though. A lot of people do.
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
« Reply #15 on: May 08, 2013, 07:45:17 PM »
IT had to be something like that. I've never seen that kind of damage from any of the run of the mill clutch problems. Usually you can't get the thing together or working at all if everything isn't right. Yours probably was all right, then that nut backed off.
Offline Tews19
  • I am no
« Reply #16 on: May 08, 2013, 08:00:23 PM »
BARF!
None taken. I read lots of negative stuff on the XD but the reviews on the xdm where all positive. I didnt care for the glock19 or the s&w shield or s&p . I liked the 19 rd magazines
  • SEMPER PARATUS
« Reply #17 on: May 09, 2013, 05:26:47 AM »
Once this cover comes in i am going to give it anothe shot. Once I got it all apart and looked at that i am confident that my problem was that nut. Is thread locker ok for right tgere or would it make tgat nut impossible to remove later?
My beretta holds 17. Even 15 rouds suits me. Id trade the mag capacity for overal weapon function any day
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
Offline bjbuchanan
« Reply #18 on: May 09, 2013, 09:11:41 AM »
Given what happened to you I would use the gentlest thread locker. I wanna say there is a green one that is a softer touch than the blue, but I could be wrong. Either way don't use the red
« Reply #19 on: May 09, 2013, 09:40:39 AM »
Right. Keep in mind there are many thousands running around without threadlocker. Meaning a proper assembly, torque on the nut and setting the lock tab, should be enough.
Offline MoMo
  • Ride like you're invisible
« Reply #20 on: May 09, 2013, 10:37:50 AM »
Agree with Ron,  I have never used anything other than proper assembly and torque.   The loose clutch hub nut could easily cause that damage...Larry
Offline bjbuchanan
« Reply #21 on: May 09, 2013, 10:47:02 AM »
I don't use it either but I should have phrased the response better. I meant "if" he uses it then use the one with the weakest bond strength
« Reply #22 on: May 09, 2013, 10:49:31 AM »
Right that's how I took it, and agree.
Offline MoMo
« Reply #23 on: May 09, 2013, 11:36:45 AM »
me too ;)   Larry
Online PeWe
« Reply #24 on: May 09, 2013, 01:03:42 PM »
Maybe this one.
Check the link where the author write "Get them meshed properly...."  after that photos. Other threads here describe this too.
http://honda-cb750-s.456789.n3.nabble.com/How-to-change-a-clutch-SOHC-td4040391.html
