Author Topic: and so it begins, cb550k under the knife  (Read 42392 times)
Re: and so it begins, cb550k under the knife
« Reply #150 on: April 01, 2016, 01:44:56 PM »
Now we won't have to call you Sparky!
« Reply #151 on: April 01, 2016, 07:44:48 PM »
Tremendous work...would be just slightly even more tremendous with more upturn.  Ha ha turn up the up turn and they will be truly tremendous.
Offline DMcD
« Reply #152 on: April 02, 2016, 01:06:43 AM »
Thankyou, I do intend turning up the upturn, but am going to wait until after upturning the upturned bike to get the upturn correct
« Reply #153 on: April 02, 2016, 01:46:48 AM »
that will be awesome
« Reply #154 on: April 02, 2016, 02:08:19 AM »
And provide clearance, Clarence.  ;)
Offline DMcD
« Reply #155 on: May 02, 2016, 01:27:54 PM »
Exhausts finished, stuff going for paint this week, so I'll be back in a few weeks/months for your opinions on my planned paint job. (I know the forks are backwards
« Last Edit: May 02, 2016, 01:47:00 PM by DMcD »
« Reply #156 on: May 02, 2016, 02:30:12 PM »
Very Nice. Are you able to change the oil without moving the pipes or are you going to install a remote filter and oil cooler?
What color scheme for your tank, etc, are you going for?
(never mind on the oil filter...April Fools Day post shows it clearly...)
« Reply #157 on: May 02, 2016, 02:46:20 PM »
Those pipes look like they took some time to weld up.  I am not an exhaust expert but do the sharp bends at the exhaust port present any flow issues?  I like how tightly the tubes tuck on the bottom of the frame.
Offline DMcD
« Reply #158 on: May 02, 2016, 02:57:08 PM »
I'm no expert either!  But there is about 60mm straight pipe before the bends which are 3 x 30 degrees.  I'll be surprised if it runs at all after I'm finished!  Running well will be an added bonus
Offline DMcD
« Reply #159 on: May 02, 2016, 02:59:53 PM »
It's a secret, but be warned, the wife picked it
Offline DMcD
« Reply #160 on: May 02, 2016, 03:35:06 PM »
Interesting funny video on the importance of good gas flow
« Reply #161 on: May 02, 2016, 06:32:07 PM »
Offline Bootsey
« Reply #162 on: May 02, 2016, 07:02:58 PM »
Coming along nicely!
Offline DMcD
« Reply #163 on: May 04, 2016, 03:00:39 PM »
Last pic of the exhausts before HT paint.
« Reply #164 on: May 05, 2016, 11:42:26 AM »
Why HT paint versus Ceramic coated inside and out? Other than an obvious of cost...
Offline DMcD
« Reply #165 on: May 05, 2016, 01:02:53 PM »
Yip cost, doing this on the cheap where possible.   Blew the budget on the CRs and ignition.
Offline DMcD
« Reply #166 on: May 10, 2016, 02:32:18 PM »
Few little details coming along.  Managed to source a rear brake cable from a cl77/72 or something.  Nice and short/chunky with a handy adjuster.
Made an aluminium mount from scrap for the drum end, and started to make a steel mount for the pedal end to weld to the frame.
Offline DMcD
« Reply #167 on: June 15, 2016, 03:25:48 AM »
Would like this on the road in 6 weeks, but the devil is in the detail.  Got the rear cable sorted, hope to make the battery box tonight and weld it to the mudguard.  Got a chain and sprockets ( nearly made the o ring mistake).  Would like new shocks, but they can wait until I get an electronic speedo/rev counter.  (Any suggestions?)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #168 on: June 15, 2016, 06:40:50 AM »
« Reply #169 on: June 15, 2016, 08:13:32 AM »
Shorten your brake anchor, will make the cable look better.
I just read the whole thread, I would like to applaud you on jumping right in, getting a tight, and jumping right into tank making and making your own megaphones..
 I expect FunJimmy is thinking of a tig about now..
« Last Edit: June 15, 2016, 09:01:39 AM by 754 »
Offline DMcD
« Reply #170 on: June 15, 2016, 12:43:36 PM »
Thankyou, I'll probably take the grinder to a few things.  I agree about the brake anchor, i'll probably make it rounder too.
Offline DMcD
« Reply #171 on: June 20, 2016, 03:15:28 PM »
Got the frame, swingarm, and some other bits from the painter today, not going to reveal the final colour yet as I am not sure if it will be a popular choice, and I want to see what it is going to look like with a few bits attached.
Took the sump off to fit a new gasket and check I had seated the cam chain tensioner correctly.  Found a couple of bits of piston ring in the sump, which explains the previous butcher job somebody did on the top end!
« Reply #172 on: June 20, 2016, 06:55:33 PM »
That is pretty nasty looking oil pump screen.
David
Offline DMcD
« Reply #173 on: June 26, 2016, 02:17:53 PM »
Well that should give you an idea of where I am aiming with this.  I made a tank for a mate who is doing the painting.  My wife picked the paint, I actually like it, not sure if the fairing would be too much if painted the same colour.
« Reply #174 on: June 26, 2016, 02:26:51 PM »
I like that alright, and I am generally a "black frame only" kinda guy.  I am thinking more colours the merrier for this race rep but no idea what would look good with that
