Author Topic: "Mouse" - a 1978 CB750K project [PICS]  (Read 17809 times)
Offline Phinn
  • Subversive
« on: January 28, 2015, 10:58:23 AM »
This is "Mouse," my 1978 CB750K project.
Mouse has led a hard life, and is not what I'd call a "survivor."  Nor is it a candidate for stock restoration.  The engine is seized, and there are a few parts that are both (a) important and (b) missing.  But it was practically free (and worth every penny!), and it's mine, so I'll be getting it back on the road in a few weeks.  (Stop laughing.)
The electrical system is non-functional.  I've expertly diagnosed the problem as a "missing power cable" issue.
There's also the small matter of the ignition switch being packed with sand to the point of, well, not-turning.  A new one is on the way.
The chain adjuster on the right side is missing the little "key" that HOLDS THE REAR WHEEL ON.
I'm not sure what this hose is supposed to attach to, but it looks important.
The PO put crash guards on it, but then apparently crashed them, so they are both bent.  But that's not all -- the alternator cover bolts were probably leaking, so he installed longer bolts and inserted little brass sleeves over them to act as a kind of washer-type system, and then cranked the living **#$ out of them.  This backyard mechanic scheme plugged the leaking cover, but because they stick out even when fully inserted, they are susceptible to being bent, which they were.  By the aforementioned crash guards.  And ... then started leaking again.
The brakes will need a little cleaning.
I removed the airbox (which is in good condition, actually), and discovered something that gave this project its name -- a rodent nest.  It probably interfered with the air flow.  My 11 year-old son came up with the name.  It fits, I think.
When I removed the carbs, I found a strange problem -- intakes for Nos. 1, 2 and 4 are coated in chalky substance.  I assume that's bad.
The carbs themselves seem to be intact, on the outside, apart from missing two of the little bolts that hold the crass-brace on.
The carbs don't look that good on the inside, though.
This one has a moisture problem
This one has sand inside.  Also bad, right?
I now assume the bike was stored at the bottom of the ocean -- the exhaust outlet (especially No. 1) has sand inside.  Sand.  Not crud.  Not carbon.  Not miscellaneous gunk.  I'm using my expert powers of scientific diagnosis and speculate the sand might have something to do with the engine seizing.
Here's spark plugs 1 through 4.  No. 4 wasn't seated more than about 3 turns.  No. 1 was welded in so tight that it broke my breaker bar.  But, I was victorious in the end.
Getting the transmission cover off proved to be difficult.  The upper-most rear bolt (the long one) didn't want to budge, no matter how many different tactics I threw at it.  I McGuyvered a "tool" to cut a new slot in the head --
I said a few curse words, and maligned the invention of the Phillips head screw/bolt/whatever and its use on motorcycles. But I was victorious in the end.
This is what I found when I finally got the cover off.
And the sprocket area is a little ... dirty.
So, the next step is to remove the engine, de-gunk-ify it, and get Mouse back on the road.
« Last Edit: July 26, 2015, 03:21:45 PM by Phinn »
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline dave the welder
  • dave the welder
Re: "Mouse" - my 1978 CB750K project [PICS]
« Reply #1 on: January 28, 2015, 11:06:14 AM »
2 weeks tops and it will LIVE
don't buy it build it
Offline scunny
  • don't call me expert
« Reply #2 on: January 28, 2015, 11:07:57 AM »
enjoy the experience.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #3 on: January 28, 2015, 12:07:03 PM »
Sand!? WTF!?  At least the "mouse" took good care of the airbox.
This one is pretty rough -- looks like a ground up rebuild.  Are you simply trying to get it to be a runner, or any design changes during the process.
« Reply #4 on: January 28, 2015, 01:53:45 PM »
Subscribed and good luck.
If you mean the relay by ignition switch, it is rebuildable too.
Honda cross head bolts are JIS, not Philips. It can make a difference on stuborn bolts. If you dont have one, get an impact screwdriver, you will use it a lot.
« Reply #5 on: January 28, 2015, 02:19:54 PM »
+++++1 on the impact driver.  It will save you a boatload of time and frustration.
Offline edwardmorris
  • Youngish
« Reply #6 on: January 28, 2015, 02:23:11 PM »
+1 JIS drivers and impact driver.
Best one http://shop.rrrtoolsolutions.com/4-Bit-Mechanics-Shop-Impact-Driver-Vessel-2500-RRR4IMPACT.htm
Sold by a long time member here, Gordon/ilbikes. He's sold out of the 4-piece set that covers everything for the 750s but you can PM him for special orders.
Offline Restoration Fan
  • My wife will never call me
« Reply #7 on: January 28, 2015, 02:25:03 PM »
That hose you mention is connected to the breather that sits on the bottom of the battery box.  Yours actually has the stopper still in it, like it is supposed to have.  Mine was missing that stopper.
Also, you can download the 78 specific manuals here, which are more detailed than the 69-78 one.
https://drive.google.com/folderview?id=0B4nqeBb662mZZjZjTWdGRk9Qd0E&usp=sharing
« Last Edit: January 28, 2015, 02:29:50 PM by Restoration Fan »
Offline goldarrow
  • one day, i'll be an
« Reply #8 on: January 28, 2015, 02:28:39 PM »
Curious what the engine bottom end tranny stuff look like, splitting the cases???
Subscribed...
CB550 K0
Offline rb550four
« Reply #9 on: January 28, 2015, 02:57:10 PM »
Being that you are in  Gold Coast Florida, which does have allot of sand, high water table ,and hurricanes. I would guess the "mouse" would have been on it's  left side for a bit ,and possibly in high water , maybe not sunk but close enough to the ground to get a sandy splash back or something like that, ... anyways , I was wondering how much sand was in the exhaust pipes and if the sand could have entered the pipes and air cleaner, dried out, and just settled where you found it ?Did PO live close to the surf?
  You are just removing the engine and taking it down without trying to make it turn right? I've seen that powdery fuzz inside a motor that I suspect was under fresh water before, fresh water-salt water doesn't make much diff really.My motor had fuzz throughout the entire inside of the tranny too, found all bearings un-useable, cases and aluminum parts difficult to clean ( Thought about bead blasting all aluminum parts) Shifter forks nearly rusted together.... Not trying to bum you out , but you are going to have to be super thorough with this engine and transmission so your investment of time and money does not go to waste.
  I like projects that are just beat, looks like a fun time,  and I'm interested to see how you treat  this project.
« Reply #10 on: January 28, 2015, 03:06:09 PM »
With the SAND issue and it likely being submerged in water, this one makes me wonder if Phinn might be better off parting this one out for money towards a bike in better shape.  You could spend the time tearing it down and keeping any good items and then selling off the questionable parts.
Offline rb550four
« Reply #11 on: January 28, 2015, 03:46:38 PM »
Could be , never know until he takes it all apart to see what he's got.
 Everything is repairable with enough parts and the 750 seems well covered. The thing that I'm wondering about besides the overall interior condition, would be the  cover/case that has been taking a beating even after the crash bars were installed...would also include searching for stress cracks in that area on the engine , and a close look for tell tale tweaks on the frame since it's been down so many times. And overall frame condition ( Rust ) should also checked out... is it just surface or pinholes too or  rot.  The left side bar next to the spine ,over the engine going to the neck didn't look good to me ,like it has separated at the weld. maybe it's just the picture angle. Also behind the swing arm bolt mount on the weld at the V , is that a weep hole or rot?Think everything needs a good lookin' over .
   I was checking out the pics on the left side under the tank...did that look like the petcock nut was rusted? as was the lower end of the tank...wonder what the bottom and inside looks like.
« Last Edit: January 28, 2015, 04:04:16 PM by rb550four »
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #12 on: January 28, 2015, 03:48:22 PM »
On the road in a few weeks? What's wrong with you man? Just clean up those plugs and you'll be up and running by the weekend! ;D
Best of luck. looking forward to this one :)
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #13 on: January 28, 2015, 04:32:05 PM »
For getting rid of rust, I also highly recommend getting yourself some Metal Rescue.
Offline Phinn
  • Subversive
« Reply #14 on: January 28, 2015, 07:50:33 PM »
Phase I is just to get it running.  It's so beaten up that it will never be close to original again, but I'm not planning to go crazy with the customization either.   I'm just pulling together an image folder with a collection of ideas.  I'll sift through it as I go along and come up with something.  My brain is kind of random that way.
No, the main ignition switch, with the key.  I had to cut the plastic bottom piece off of the assembly.  It was so packed with sand that it was impossible to push the key in to engage the "Park" bolt.  The relay under the seat appears to be fine.
The "under the ocean" thing was a joke -- I sure hope it's not true!  I had the bike shipped to me here on the Treasure Coast from Michigan.  As far as I know, it spent its whole life in the frozen North.
I am not trying to turn the engine.  As soon as I stuck my finger in the exhaust port and came out with a clump of sand, I figured the cylinders had to come off.  There's no amount of Mystery Oil and PB Blaster that's going to convince me that it's safe to run, until I see it with my own eyes.
Yes, the petcock nut is rusted, but the inside of the tank isn't bad!   No leaks.  No major rust.  Strange, I know.
« Last Edit: January 28, 2015, 08:10:39 PM by Phinn »
Offline Phinn
  • Subversive
« Reply #15 on: January 28, 2015, 07:59:20 PM »
I got the various bolts removed, with several cans of PB Blaster, a rudimentary knowledge of metallurgy, burning hatred and sheer force of will.  The "B" engine mount hanger bolt was bent, on the right side, as it emerged from the right side of the frame.  I guess the bike must have down on that side, at least once.  I tried to pull the bolt out for a while, before giving up and just cutting off the offending bent part.  It came right out after that.
I even managed to get the engine out without injuring myself.
The valve cover came off.  Since the engine is seized, and it's exactly 90 degrees out of position, I couldn't reach both of the bolts that hold the cam sprocket in place. So I had to break the cam chain to get the cam out.
I think some of the oil return holes aren't open.
The problem is the left-most cam bearing.  Not good.
This isn't supposed to be in between the bearing surfaces.
The camshaft might as well have been mounted on a lathe.  It's missing some mass.
It looks like I'll be upgrading the cam ahead of schedule.
« Last Edit: February 02, 2015, 01:56:12 PM by Phinn »
Offline rb550four
« Reply #16 on: January 29, 2015, 04:54:05 PM »
Getting down to the nitty gritty. Custom cut cam, don't see that every day. Can hardly wait to see the rest of it.
Offline Phinn
  • Subversive
« Reply #17 on: January 30, 2015, 05:29:31 AM »
Yeah, this one's more gritty than nitty.
The strange thing is that the rest of the camshaft seems to be relatively ok. The other three bearing surfaces are in spec, while this one (on the far left) had two clumps of metal in it that ate away maybe 10-15% of that bearing's mass. The lobes look good too. I wouldn't have expected the damage to be so extreme yet so isolated. Considering the general abuse the bike has suffered, I assume the root cause was oil deprivation (although the Vindictive Girlfriend theory is more interesting.)
Since I'm already impelled to do a fairly invasive rebuild, I may go ahead and bore it out to 836cc while I'm here. Does anyone have any thoughts on a good all-around camshaft for a '78 with the 836 kit? (I'm not looking to maximize low end acceleration.)
Offline Phinn
  • Subversive
« Reply #18 on: February 02, 2015, 07:25:03 AM »
I got the head off.
I see why the engine is seized, but I honestly have no idea how you could cause the inside of a cylinder to end up like this.
There's about a tablespoon of sand, grit, carbon and general debris inside each one.
« Reply #19 on: February 02, 2015, 08:12:46 AM »
Was the bike sitting outside?  If so, were the spark plugs taken out?  If so, some debris, dirt, moisture, etc will naturally make it's way down into those holes and into the cylinders.
Offline Phinn
  • Subversive
« Reply #20 on: February 22, 2015, 10:08:19 AM »
The spark plugs were in.  The seller says it was in a garage, but who knows?
Offline Phinn
  • Subversive
« Reply #21 on: February 22, 2015, 10:12:46 AM »
After a few failed attempts (solvents, prying, fire, etc.), I was able to get the seized pistons out and the cylinders off.  I used a rented 2-jaw puller from my FLAPS, and pressed the offending piston out.  It was the No. 1 that was stuck the most.  The bike was leaning in that direction for 15-20 years, I guess, with the exhaust valve open.
It was a bit messy in there.
« Last Edit: February 22, 2015, 10:15:29 AM by Phinn »
« Reply #22 on: February 23, 2015, 03:48:42 AM »
Congrats on your persistence.  Looks like you'll be going with an overbore kit and a new camshaft.  Have you decided what kind and what size yet?
Offline FridgeRaider
« Reply #23 on: February 23, 2015, 06:50:26 AM »
+1 and subscribed
1972 CB750K2 Resto-mod (836cc Upgrade) - http://forums.sohc4.net/index.php/topic,161782.0.html
Offline Phinn
  • Subversive
« Reply #24 on: February 23, 2015, 09:46:02 AM »
836cc seems like the simplest route, but I'm still researching the options and the cam/valvetrain choices that would go with it. I have a couple of weekends of disassembly to go before I turn the corner and start putting it back together.
