Author Topic: My stupid master cylinder rebuild mistake - help!  (Read 3918 times)
Offline j2dawson
« on: April 22, 2015, 05:53:52 PM »
I received my master cylinder kit today and was putting it in. As I was installing the snap ring my hand slipped and everything went flying across the garage. I retrieved everything except the rubber cup that goes over the end of the spring. I've looked for hours and it is nowhere to be found. It appears that it can't be purchased separately. Naturally I have already thrown away the old one.
Does anyone have a used one that they want to part with? I hate to spend another $28 just for that piece of rubber.
Thanks,
Jim
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: My stupid master cylinder rebuild mistake - help!
« Reply #1 on: April 22, 2015, 05:59:53 PM »
I'll take a look, I should have a used one bagged up somewhere, unless someone else beats me to it. I know the rubber ring on the piston is the primary pressure seal, but does anybody know if the rubber cup on the end of the spring is a critical seal, or does it just cushion the spring?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline j2dawson
« Reply #2 on: April 22, 2015, 06:48:32 PM »
Thanks for looking Wilbur, I really appreciate it. If you find one let me know how much you need for it and I'll get it right out.
Jim
« Reply #3 on: April 22, 2015, 06:59:07 PM »
Actually, looking at the schematic in the manual, the rubber cup under the spring is labeled "primary cup" and the rubber around the piston is labeled "secondary cup". This makes sense looking at their orientation, so I would say the cup under the spring is the most important one. I would suggest scouring the garage a couple more times to see if you can find the new one you lost. If it were me, I would not want to install a used primary cup, which is all I would have.
Maybe someone has a partial kit laying around? Sorry I couldn't help with a new seal.
TAMTF...
Wilbur
Projects:
Offline j2dawson
« Reply #4 on: April 22, 2015, 08:01:11 PM »
I would be willing to try a used one if I had one.
Thanks anyway.
Offline krusty
« Reply #5 on: April 22, 2015, 10:36:37 PM »
We wouldn't be talking about the piston dust seal would we?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #6 on: April 23, 2015, 03:46:11 AM »
Thanks anyway.
I'll see what I've got, I know I bagged up the remains of more than one MC rebuild.
TAMTF...
Wilbur
Projects:
Offline j2dawson
« Reply #7 on: April 23, 2015, 04:11:56 AM »
It's the rubber cup that is between the spring and the piston.
I think the primary cup is the one on the shaft of the piston. This might be called the piston dust seal.
« Last Edit: April 23, 2015, 04:13:51 AM by j2dawson »
Offline krusty
« Reply #8 on: April 23, 2015, 02:58:30 PM »
OK its not the dust seal then. If you want brakes you'll need it.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #9 on: April 23, 2015, 04:54:57 PM »
Found a couple. PM me your address and I'll pick out the best one and stick it in an envelope.
TAMTF...
Wilbur
Projects:
Offline j2dawson
« Reply #10 on: April 29, 2015, 12:18:30 PM »
Thanks to Wilbur's generosity, I got my master cylinder rebuilt. I also rebuilt the caliper and all is working well.
« Reply #11 on: June 08, 2015, 07:55:23 PM »
Wilbur's used one will get you going for sure and it is nice of him. If you intend to keep using the bike, when I got a few extra bucks I would purchase new parts in the near future.
« Reply #12 on: June 08, 2015, 08:10:52 PM »
Yep, I made it clear that it was for "testing" purposes!
TAMTF...
Wilbur
Projects:
