Author Topic: Cobra motor disassembly and rebuild  (Read 117299 times)
Offline Bill/BentON Racing
    • BentON Racing
Re: Cobra motor disassembly and rebuild
« Reply #25 on: December 16, 2015, 08:43:42 PM »
With ring package, 220 grams, pin 39 grams.
BentON Racing Website
BentON Racing Facebook
Offline dragracer
  • CB750F Dragbike
« Reply #26 on: December 16, 2015, 09:06:49 PM »
Dude, you're finally making me happy. Should have pulled the whole damn thing apart to begin with. Remember, when you buy a used engine, you go into the purchase knowing its just a parts motor. I don't care what the previous owner tells you about its condition. I'm speaking from experience here. And know you've gone through this at least two times already - got it now??
Offline gschuld
« Reply #27 on: December 16, 2015, 09:24:15 PM »
Good deal.
Were the pins held in position with Teflon buttons?
George
Offline dragracer
  • CB750F Dragbike
« Reply #28 on: December 16, 2015, 09:31:50 PM »
So what size bore???
Offline gschuld
« Reply #29 on: December 16, 2015, 09:41:45 PM »
They are RC Arias 73s Frankie.  Stamped:
 RC ENG
   73H
under the crown.
George
Offline dragracer
  • CB750F Dragbike
« Reply #30 on: December 16, 2015, 10:01:44 PM »
Those Arias 73mm pistons I have are 190grams. Didn't weigh the rings or pins. In fact the 72mm KZ pistons I have are only 208grams with the rings, pin was 18 grams. Wisecos. What a difference the years make in piston design and material weight.
Offline gschuld
« Reply #31 on: December 16, 2015, 10:07:11 PM »
Pin was 18 grams?  Misprint I hope...
FWIW, the old ring packs for the RC and MTC pistons average 23 grams per piston.
George
    • BentON Racing
« Reply #32 on: December 16, 2015, 10:33:51 PM »
Stocker around 40 something . Lightweight ones usally about 10 grams less.
Offline dragracer
  • CB750F Dragbike
« Reply #33 on: December 16, 2015, 11:30:08 PM »
George
I'll weigh it again tomorrow but I'm pretty sure that's what it weighed.
Offline NickO
« Reply #34 on: December 17, 2015, 01:19:50 AM »
Some epoxy filler from the inlet port broke loose and jammed in the chamber?
    • BentON Racing
« Reply #35 on: December 17, 2015, 05:09:07 AM »
Close. It's a piece of foreign material. We use them all the time......Let's see engine out,been in engine room for a couple months , plugs out....hmmmmm checked with boroscope and blew air in plug hole... should have opened a valve and blew through there. The air moved it that you could see. So what is it? Pic later, Bill
« Reply #36 on: December 17, 2015, 05:24:21 AM »
I never liked that. Going to replace em with better ones, better head nuts also and cylinder stud kit. New cam chain and primary's etc, new mains also. This 1/2 ready for a bath. I cleaned my lens. BF chew toy closest so far!! Closest guess wins a John Stein Drag Racing book!
I have to say the big ends of #2 & #3 rods weigh a noticeable amount less after grinding those steel rod bolts down. Whoever built it should have cut all the bolts to the same size. Why bother balancing the crank?
 This is the kind of stuff I have noticed when disassembling old performance motors.....a lot of sloppy, get it done attitude work.
  Maybe it is ticky tack but it bugs the crap out of me and, as Frank said, demands the complete disassembly of any of these things.  ::)
« Last Edit: December 17, 2015, 05:26:37 AM by MRieck »
Offline bear
  • Leeton in Australia
« Reply #37 on: December 17, 2015, 05:39:29 AM »
Yep gotta agree. You might be able to bolt on HP, but you can't bolt on reliability.
That comes from doing the little things right.
« Reply #38 on: December 17, 2015, 06:07:36 AM »
George
2 teflon buttons weigh 10 grams Frank. ;D
Offline gschuld
« Reply #39 on: December 17, 2015, 06:10:26 AM »
That's a good one ;)
George
Offline dragracer
  • CB750F Dragbike
« Reply #40 on: December 17, 2015, 06:31:02 AM »
George
I'm probably way off the mark on my pin weight then. Lol. A mind is a terrible thing to waste. Blame it on old age.
Offline NickO
« Reply #41 on: December 17, 2015, 07:01:58 AM »
You and I sound like we could put the world to rights Mike, the older I get the more pedantic I become? I look forward to sharing a beer sometime maybe....who knows?
Happy Christmas BTW.
Offline NickO
« Reply #42 on: December 17, 2015, 07:03:18 AM »
Discarded ear-plug maybe (or a Leprechaun)?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #43 on: December 17, 2015, 07:29:09 AM »
Almost looks like one of the valve keeper wedges? Dropped down the spark plug hole during assembly?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #44 on: December 17, 2015, 09:58:45 AM »
Looked a bit like a dowel to me , maybe like the camholder size...
« Reply #45 on: December 17, 2015, 10:03:19 AM »
Roach clip??
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #46 on: December 17, 2015, 10:11:53 AM »
[/quote]
Roach clip??
[/quote]
maybe if he was in denver
...Save a tree, eat a beaver...
Offline gschuld
« Reply #47 on: December 17, 2015, 10:13:18 AM »
Close. It's a piece of foreign material.  We use them all the time......, Bill
Roach clip??
LOL.  Damn that was funny... ;D
George
« Reply #48 on: December 17, 2015, 10:23:41 AM »
Thanks Nick and the same to you. I don't think I'm up to the job of putting the world to rights but a motorcycle engine is a task I can handle. ;D
 And I shouldn't just say "older" performance engines.....I have seen some real bonehead stuff in modern engines too ;) ;D
Offline dragracer
  • CB750F Dragbike
« Reply #49 on: December 17, 2015, 10:25:36 AM »
Come on Bill, go ahead and let us in on the truth. I know you were waiting for someone to beg you. Lol
