Author Topic: Engine rebuild options 76 750F  (Read 1321 times)
Offline ceebass68
« on: February 13, 2017, 07:50:59 PM »
Engine is coming out, headed for rebuild. Cam chain is beyond adjustment. Not sure what I'll find when I get in there but, any opinions on standard bore rebuild vs 836 kit? Trying not to go broke during the rebuild but, I don't want to miss out on something if there's a huge difference.
Thanks for any thoughts!
1975 CB550F (long term project)
1976 CB750F (short term project)
1976 CB750A (future project)
2006 VTX1800C (primary rider)
1995 VN800a (son)
2001 VN1500LC (highly modified - for sale)
Lots of others now gone
Offline ceebass68
Re: Engine rebuild options 76 750F
« Reply #1 on: February 14, 2017, 04:38:29 AM »
Thanks calj737. Am I gonna feel any noticeable difference in performance?
1995 VN800a (son)
« Reply #2 on: February 14, 2017, 05:55:22 AM »
 Kind of goes without saying that an extra 100 cc with a fresh bore and a cleaned up head etc. is going to offer a little extra grunt.  On my old RC 836 which still lingers in the shop it always felt like I was a gear lower as far as power compared to a stocker. When I was in 5th I was always fishing for another gear cause it 'felt' like 4th till I got used to it.
Offline ceebass68
« Reply #3 on: February 14, 2017, 09:33:19 AM »
Ok good Tip. I will definitely do some checking around prior to ordering any parts.  This F isn't currently running so, honestly I wouldn't have anyway to compare. ( 836 versus stock ).  My gut feeling is keeping her stock unless the cylinders are in real bad shape etc.  not really looking for a racer, but don't want to sell myself short on the rebuild.
1995 VN800a (son)
« Reply #4 on: February 14, 2017, 09:42:23 AM »
Probably still a 392 head, so the CI pistons would work fine.
(If its a 410 head, it'll need a shave to get the CR back up with the flat CI pistons)
You might just fair well with a hone and re-ring.
« Reply #5 on: February 14, 2017, 03:49:30 PM »
I should mention something: I don't know whether the CI kits are compatible with the F motors. So you need to confirm that.
The early F is basically a early K engine so there should not be a problem.
By early K I should clarify to mean a non 77/78 F or say it is basically the same as the 77/78 K and is compatible with the other K's but it does not use an equivalent top end cylinders-up as the LATE ie 77/78 F so the CI kits will be fine.
« Last Edit: February 15, 2017, 08:21:43 PM by Jerry Rxman Griffin aka MuthaF'er »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: February 14, 2017, 08:19:09 PM »
Aren't the early F heads used on the later K models (77/78)?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline BPellerine
« Reply #7 on: February 15, 2017, 06:07:49 PM »
yes madmotors same casting.bill
1978 CB 750K ard and webers
another anfob
Offline drumstyx
« Reply #8 on: February 15, 2017, 06:35:42 PM »
Camchain beyond adjustment sounds *really* worn to me...My motor had well over 100k miles on it and still had room on the cam chain.
If it's that worn, and you're going into head work, just know it'll be at least a couple grand, and it'll always be more than you expect.
« Reply #9 on: February 15, 2017, 08:12:02 PM »
yes
