Author Topic: physics question  (Read 1251 times)
Offline grumpy
  • ..... '73 750K3 .....
physics question
« on: February 26, 2017, 05:27:47 PM »
All else being equal, is the force necessary to move the weight the same if a rope is attached to point A vs. point B?
just eyballing it, it seems like there would be an inverse relationship between the force and the distance the weight must move
IE at point A the weight must travel farther than at B for each degree of arc the lever is moved, hence the force required at B would be less since it ain't moving as far... or something... maybe...
« Last Edit: February 26, 2017, 05:34:33 PM by grumpy »
Offline eigenvector
Re: physics question
« Reply #1 on: February 26, 2017, 05:41:24 PM »
That seems like a reasonable assumption.
Be easier to understand with a decent example though.  Mind you - if the weight tips at all, there's more to this.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline jgger
« Reply #2 on: February 26, 2017, 05:43:44 PM »
No. Point B would make the lever longer and give more leverage. But it would move the weight a shorter distance.
Offline Gene
  • Chat enuf you too can be a
« Reply #3 on: February 26, 2017, 05:51:26 PM »
It depends on the balance of weight in the "weight" square. Balance at the top?" bottom? How do the 2 ropes attach to the weight? There are a lot of questions unanswered to be able to answer your question. ;D
*1973 CB750K3 (Bow)
Offline grumpy
« Reply #4 on: February 26, 2017, 06:14:58 PM »
northern hemisphere, a Tuesday in May, standard temperature and pressure.
That's why the caveat "all else being equal". The only thing changing is the attachment point. Assume all other confounds are completely controlled.
Offline grumpy
« Reply #5 on: February 26, 2017, 06:20:49 PM »
how about this?
 :P
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: February 26, 2017, 06:25:05 PM »
This. Same for both examples.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: February 26, 2017, 06:45:48 PM »
B will move it with less effort, and move it less distance.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #8 on: February 26, 2017, 09:49:10 PM »
Screw the rope, I'm using the bulldozer with hydraulic winch and cable!
« Reply #9 on: February 26, 2017, 10:05:45 PM »
 B gives more leverage then A so it will move easier but not as far.
 My Niece's husband told her a full tire weigh 32 lbs. more than a flat tire because the full one has 32 lbs of air in it.
« Reply #10 on: February 27, 2017, 03:48:36 AM »
That's a good one.  ;D
I've also been told that when water pipes are full of water they don't weigh any more than pipes that are empty because the water is moving...  ::)
TAMTF...
Wilbur
Projects:
