Author Topic: JIS bit  (Read 913 times)
Offline beemerbum
JIS bit
« on: August 10, 2017, 01:54:26 PM »
Does anyone know where a guy could buy a 3/8 drive JIS "Phillips" bit? The PO puke drove the cam cover screws with what must have been an air impact wrench.
Re: JIS bit
« Reply #1 on: August 10, 2017, 02:01:16 PM »
All over the interwebs...ebay, amazon, etc....
Vessel even has the Impacta Line of JIS screwdrivers.
Offline beemerbum
Re: JIS bit
« Reply #2 on: August 10, 2017, 02:14:27 PM »
I have a #$%*load of JIS Vessel screwdrivers. I'm looking for a bit that fits on a 3/8 drive ratchet handle with a JIS cross bit on the business end. The Impacta Vessel screwdrivers are not cutting it. I need to use an impact driver and not screw up the screws further with an American Phillips bit.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: JIS bit
« Reply #4 on: August 10, 2017, 02:22:04 PM »
If the JIS drivers on hand are not cutting it, drill off the heads and be done w it  ;D
Re: JIS bit
« Reply #5 on: August 10, 2017, 02:24:05 PM »
Use the bits linked to above with a true impact driver. The "impact screwdrivers" are not as heavy duty as a true impact driver.
TAMTF...
Wilbur
Projects:
Offline magnum56
Re: JIS bit
« Reply #6 on: August 10, 2017, 02:24:25 PM »
I found and purchased all sizes of these from motion Pro on Amazon.
Only 1/4" drive size, but I used a standard 3/8 to 1/4 adapter in a 3/8 hand impact driver I've had for years.
And they fit all my other screwdriver handles.
https://www.amazon.com/gp/product/B06ZY8DMFB/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
'74 CB750K
Offline 540nova
Re: JIS bit
« Reply #7 on: August 10, 2017, 09:06:38 PM »
A #3 Apex bit works perfectly. Available at Lowes or Home Depot.
Sent from my SM-G955U using Tapatalk
Offline bochnak
    • How-To Motorcycle Repair Blog
Re: JIS bit
« Reply #8 on: August 11, 2017, 01:44:13 PM »
Search for vessel 2500 impact on ebay. I bought mine for $12 with all the bits. The vessel impacta screwdrivers are nice, however they won't loosen the stubborn ones.
