Author Topic: Anyone know where this nut goes in the CB750 K7 airbox?  (Read 1171 times)
Offline timmerk
« on: June 29, 2019, 09:05:53 PM »
Part 15 on this diagram:
Is apparently:
But I'm missing them. Anyone know where they go? I put the airbox together, and don't see an obvious place to put it, even with the part diagram. I'm asking so I can see what will fit at the hardware store. Thanks!
Offline useful_idiot
Re: Anyone know where this nut goes in the CB750 K7 airbox?
« Reply #1 on: June 30, 2019, 12:28:58 PM »
Ihave a k8. Airbox appears to be the same. I'll check tomorrow morning since I already have the box off anyway.
« Reply #2 on: June 30, 2019, 12:34:55 PM »
 I think it's a stop nut for the thru bolt. it keeps you from over tightening and crushing the air box. But I might be wrong. The description is cover nut and the bottom is the cover.
 I use double nuts on the K0 airboxes to accomplish the same thing.
Offline timmerk
« Reply #3 on: June 30, 2019, 01:37:44 PM »
Ah, makes sense. Thank you!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: June 30, 2019, 05:47:35 PM »
It's a stop nut for the thru bolt. it keeps you from over tightening and crushing the air box.
Correct. It also holds part number 12 to the upper half of the airbox.
Here's a writeup I did regarding disassembly of the airbox:
http://forums.sohc4.net/index.php/topic,114485.msg1290000.html#msg1290000
« Last Edit: June 30, 2019, 05:51:48 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline timmerk
« Reply #5 on: June 30, 2019, 09:29:52 PM »
Thank you, too! This is exactly what I was looking for.
« Reply #6 on: July 01, 2019, 10:02:15 AM »
Here's a picture
