Author Topic: 1977/78 cb750F Rubber Intake Manifolds  (Read 745 times)
Offline BenelliSEI
  • 1969 cb750
« on: February 13, 2024, 11:58:46 AM »
Digging out what I need for the cb750K6 and came across these (in front). All four stamped with a number: 410 and numbered individually 1,2,3,4. They are definitely a set. May have come with my Carlini cb750 Chopper that had a different set of carbs. Anyone know what they are?
« Last Edit: February 14, 2024, 12:26:41 PM by BenelliSEI »
Re: Rubber Intake Manifolds
« Reply #1 on: February 13, 2024, 12:12:04 PM »
410 means 77/78 cb750f2/3.  If those are in good, soft, flexible shape, someone definitely needs them.  Might fit k's too?...I think the f's had bigger outside diameter spigots
Offline newday777
« Reply #2 on: February 13, 2024, 01:08:57 PM »
77/78 K use 405 rubber intakes.
77/78 F use 410s
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: February 13, 2024, 01:24:03 PM »
Thanks Stu! Good to know. Odd they are numbered 1,2,3,4.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: February 13, 2024, 01:25:24 PM »
If anyone needs these, get in touch!
Offline bustech51
Re: 1977/78 cb750F Rubber Intake Manifolds
« Reply #5 on: February 13, 2024, 02:26:11 PM »
The numbers refer to the cylinder that they go onto.  That way the installation angle is correct.
Sent from my SM-G950W using Tapatalk
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: February 14, 2024, 05:02:35 AM »
PM forthcoming!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: February 14, 2024, 12:27:38 PM »
Gentlemen….. Thanks for all the info. I think these might work on my Rickman CR so I’m going to put them away!
